There is a lot of "may", or "can" in their article, but no data. On the
other hand, Cirrus as well as the folks at TAT actually present data, something that Lycoming and Continental have yet to produce. I suspect that both companies are not interested in doing any testing or changing their many year old operating instructions in order to limit their liability exposure. |
![]() On 3-Jan-2009, "Viperdoc" wrote: I suspect that both companies are not interested in doing any testing or changing their many year old operating instructions in order to limit their liability exposure. You may be exactly right. Somewhat irrelevant for me, since my 1978 Cessna 172N doesn't have an EGT gauge or cylinder head temp gauges. My POH says to lean until the tach drops 25 to 50 RPM, which I've read is supposedly somewhere slightly lean of peak. My partners say they lean until the tach drops off, then twist the mixture knob back rich a couple of turns. I do the 25 RPM drop-off method, but I've always been worried I might be causing damage to the engine, based on what I've read in some of the on-line articles people on this group recommended. Or maybe my partners are damaging the engine by doing it their way, if not just wasting some gas. I wish there was a way to be absolutely sure. Scott Wilson |
... In rec.aviation.piloting wrote: On 3-Jan-2009, wrote: There is; it is called an engine analyzer. -- Jim Pennino Ah yes, the Holy Grail of operating an engine. Not in our budget unfortunately; our airplane is completely original, including paint, interior and the original Cessna avionics. The best thing about our airplane is that we have a little less than 2600 total hours on it, and she's been hangared all her life so she's in remarkably good condition. But, we need to upgrade the radios and transponder before we start looking at engine analyzers. Guess I should've been more clear; I wish there were a way to be more sure of operating the engine properly without an analyzer. Thanks for the thought, though! Scott Wilson Unfortunately monitoring CHT and EGT on all cylinders is the only way to be absolutely sure. Monitoring a single cylinder IMHO is a waste of time and money. Using the POH leaning method won't achieve either maximum power or economy, but it will be close enough and it will be safe. The other plus for monitoring all cylinders is if a problem is developing, it will usually show up on the monitor before any other symptoms become noticable. -- Jim Pennino Remove .spam.sux to reply. IIRC, that last was the primary benefit that was originally advertised long ago. Peter |
.. . On 3-Jan-2009, "Viperdoc" wrote: I suspect that both companies are not interested in doing any testing or changing their many year old operating instructions in order to limit their liability exposure. You may be exactly right. Somewhat irrelevant for me, since my 1978 Cessna 172N doesn't have an EGT gauge or cylinder head temp gauges. My POH says to lean until the tach drops 25 to 50 RPM, which I've read is supposedly somewhere slightly lean of peak. My partners say they lean until the tach drops off, then twist the mixture knob back rich a couple of turns. I do the 25 RPM drop-off method, but I've always been worried I might be causing damage to the engine, based on what I've read in some of the on-line articles people on this group recommended. Or maybe my partners are damaging the engine by doing it their way, if not just wasting some gas. I wish there was a way to be absolutely sure. Scott Wilson I don't know about the 172N, but the manual for the 152 had a very similar recommendation for lean operation--but it was stated for 60% power (and was obviously appropriate for less than 60% as well). What does your POH say about the power setting? Peter |
On Jan 3, 10:10 am, wrote:
You may be exactly right. Somewhat irrelevant for me, since my 1978 Cessna 172N doesn't have an EGT gauge or cylinder head temp gauges. My POH says to lean until the tach drops 25 to 50 RPM, which I've read is supposedly somewhere slightly lean of peak. My partners say they lean until the tach drops off, then twist the mixture knob back rich a couple of turns. I do the 25 RPM drop-off method, but I've always been worried I might be causing damage to the engine, based on what I've read in some of the on-line articles people on this group recommended. Or maybe my partners are damaging the engine by doing it their way, if not just wasting some gas. I wish there was a way to be absolutely sure. Lycoming says you can lean your normally-aspirated engine anyway you like if you're at or below 75% power without damaging it. See your cruise charts. Detonation is seldom any risk at 75% or less. Dan |
I have an engine analyzer in my twin, and it is extremely useful for
monitoring CHT on those hot days, as well as finding out the bad plug that occasionally occurs on runup. I always run LOP in cruise, and can generally get down to around 25gph at 8-10k and 174KTAS. I need to adjust my GAMI injectors, since the cylinders all don't peak at quite the same fuel flow. It may not be as useful in a 172, but for IO 470's or larger an dngine analyzer may make more sense. On the other hand, I also have an AEIO 540 Lycoming, and even without GAMI injectors, the engine peaks symmetrically, probably due to better fuel flow in the Lycoming versus the Continental. |
Full Stalls Power Off | w3n-a | Soaring | 5 | December 4th 08 10:29 PM |
Full Stalls Power On | w3n-a | Piloting | 0 | December 4th 08 02:30 PM |
Can hydraulic lifters cause inadequate full power? | [email protected] | Owning | 13 | October 23rd 08 07:40 PM |
Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 07:52 PM |
4--O-470 pistons,used | jerry Wass | Aviation Marketplace | 0 | August 17th 04 05:07 PM |
