![]() True, but nowadays most of the complexity is in the G1000, not the engines. I'd trust a FADEC in an airliner long before I'd trust a G1000. Many glass cockpits are far too complex and far too poorly tested. An airplane will keep flying without a PFD, all of which require backup. It will not keep flying without an engine- another example of your flawed logic. It's odd that pilots would object to a more modern engine on the one hand, but are more than willing to install the iffy technology of a glass cockpit. In your limited opinion it is iffy technology, but it doesn't matter anyway, since you'll never use it other than in a game. In reality, most piston engines simply require setting the power for take off, then cruise, and finally descent. It is not hard at all to do, nor does it add dramatically to the work load (and I have two engines to consider in my plane). So losing things like mixture and prop control really wouldn't take anything away from the pilot, anyway. So why not do it? I never said we should or should not do it- another example of your twisted responses. Rather than defend or justify Anthony's now increasing list of comebacks and partial responses, or criticising the other posters, why not answer his question? Why haven't you answered the question yourself? Because the premise of your question was incorrect, and you are a non sequitor. |
Viperdoc writes:
An airplane will keep flying without a PFD, all of which require backup. An airplane without any instruments will fly perfectly well. It's the pilot who becomes the problem when instruments fail. In your limited opinion it is iffy technology, but it doesn't matter anyway, since you'll never use it other than in a game. True, that's one of the advantages of simulation. I'm not betting my life on inadequately tested software. Because the premise of your question was incorrect, and you are a non sequitor. Then why do you suggest that others answer the question? This seems inconsistent. |
In rec.aviation.piloting Mxsmanic wrote:
Viperdoc writes: An airplane will keep flying without a PFD, all of which require backup. An airplane without any instruments will fly perfectly well. It's the pilot who becomes the problem when instruments fail. A ridiculous, childish line of reasoning. -- Jim Pennino Remove .spam.sux to reply. |
Full Stalls Power Off | w3n-a | Soaring | 5 | December 4th 08 10:29 PM |
Full Stalls Power On | w3n-a | Piloting | 0 | December 4th 08 02:30 PM |
Can hydraulic lifters cause inadequate full power? | [email protected] | Owning | 13 | October 23rd 08 07:40 PM |
Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 07:52 PM |
4--O-470 pistons,used | jerry Wass | Aviation Marketplace | 0 | August 17th 04 05:07 PM |
