![]() wrote in message ... On Jan 8, 3:56 pm, Monk wrote: A Subaru? --------------------------------------------------------------------------------------------------- First off, we can forget about lost-foam or anything more exotic than green-sand, simply because there aren't enough of us. So we stick to standard, readily available valves, valve guides, valve seats and studs. The fins make the castings pretty tricky but if it was easy you would have seen it years ago. So we make a L-head and an R-head; mirror images. We do the best we can with the fins but recognize our limitations and leave the most difficult of them as CUT fins: Rather than try to cast perfect fins in a couple of high-risk areas, we settle for a quarter-inch bar of aluminum that's configured for easy SAWING, which we do as part of the flash clean-up. -R.S.Hoover ------------------------------------------------------------------------------------ I've alway thought it would be more practical to CNC saw all the cooling fins. Seems a bit extreme at first glance, but if you go to the time or expense to fabricate patterns to cast the heads, we must be talk about doing more than just a couple of sets. So the programming cost might well be worth the cooling efficency of extremely detailed cooling fins. |
On Jan 8, 10:30*pm, "Maxwell" #$$9#@%%%.^^^ wrote:
wrote in message ... On Jan 8, 3:56 pm, Monk wrote: A Subaru? --------------------------------------------------------------------------------------------------- First off, we can forget about lost-foam or anything more exotic than green-sand, simply because there aren't enough of us. *So we stick to standard, readily available valves, valve guides, valve seats and studs. *The fins make the castings pretty tricky but if it was easy you would have seen it years ago. So we make a L-head and an R-head; mirror images. *We do the best we can with the fins but recognize our limitations and leave the most difficult of them as CUT fins: Rather than try to cast perfect fins in a couple of high-risk areas, we settle for a quarter-inch bar of aluminum that's configured for easy SAWING, which we do as part of the flash clean-up. -R.S.Hoover ------------------------------------------------------------------------------------ I've alway thought it would be more practical to CNC saw all the cooling fins. Seems a bit extreme at first glance, but if you go to the time or expense to fabricate patterns to cast the heads, we must be talk about doing more than just a couple of sets. So the programming cost might well be worth the cooling efficency of extremely detailed cooling fins. I disagree, sand casting would be easier than milling from solid block. Just sculpt your head out of wax cover with sand and pour your casting. A little grinding here and there and there you have it. OK, not that simplistic, but you get the gist. |
![]() "Monk" wrote in message ... ------------------------------------------------------------------------------------ I've alway thought it would be more practical to CNC saw all the cooling fins. Seems a bit extreme at first glance, but if you go to the time or expense to fabricate patterns to cast the heads, we must be talk about doing more than just a couple of sets. So the programming cost might well be worth the cooling efficency of extremely detailed cooling fins. I disagree, sand casting would be easier than milling from solid block. Just sculpt your head out of wax cover with sand and pour your casting. A little grinding here and there and there you have it. OK, not that simplistic, but you get the gist. ------------------------------------------------------------------------------------------------------ I didn't suggest milling from billet. Just milling the cooling fins. The overall head with valley for the rockers, combustion chambers, ports, etc., should be green sand cast. It's also not possible to green sand cast over a wax investment. Even if it were simple enough to sculpt your heads out of wax, which it's not, you would have to investment cast them. Sand casting the heads and machining detail not practical with the green sand or air set process is the only practical method for producing a limited number of parts. Tooling cost for wax or foam investment casting would be too prohibitive. |
On Jan 8, 11:21*pm, "Maxwell" #$$9#@%%%.^^^ wrote:
"Monk" wrote in message It's also not possible to green sand cast over a wax investment. Even if it were simple enough to sculpt your heads out of wax, which it's not, you would have to investment cast them. While sand directly over wax isn't practical there are hybrid methods of lost wax and sand that the hobby casters can do with good results. As for being simple to sculpt the heads in wax ...........depends on your definition of simple. Tooling cost for wax or foam investment casting would be too prohibitive. If your thinking conventional production practices you might be right, but there are home brew methods that while slower work just fine. We aren't talking GM production numbers or that level of automation. ==================== Leon McAtee |
On Jan 8, 7:30*pm, "Maxwell" #$$9#@%%%.^^^ wrote:
I've alway thought it would be more practical to CNC saw all the cooling fins. Seems a bit extreme at first glance, but if you go to the time or expense to fabricate patterns to cast the heads, we must be talk about doing more than just a couple of sets. So the programming cost might well be worth the cooling efficency of extremely detailed cooling fins. ------------------------------------------------------------------------------------------------------------------------ Dear Maxwell, et al (more for the et al's at this point) What makes this NOT a ' blue-sky & bull**** ' kinda project is the fact we can pick up a telephone and have the key components sitting on our front porch in a matter of HOURS. Such as: Pistons & cylinders, crankshafts, camshafts, valves, valve seats, valve guides, carburetors, electronic ignition components, electrical system components... and so on right down the list. In fact, the existence of the Roto-Way type heads... most folks think of them as 'Scat-type'... provides 'Proof of Concept' -- meaning this IS NOT a new idea. What's 'new' is coming up with an isolated head- design that is amenable to air-cooling. Historically, when the real engine manufacturers ran into the thermal limitations of cast aluminum (**) they way they tackled the task serves as our instruction manual. They tried liquid cooling and machined fins but finally achieved the desired power-to-weight ratio by going to FORGINGS for their aluminum heads. (Forged aluminum is denser; it can couple more heat to the atmosphere than a casting can. [and if one you grammarians jumps on that...] ). Indeed, comparing the American & British efforts makes a damn good adventure novel -- one in which the British should have won (ie, because of their slide-valve engines). But buried in that 'novel' is methods tried & discarded not because they didn't work but simply because the goal was for more horsepower than those methods could provide. And to be fair here we really need to include the Japanese 14-cyl radial... which was using the so-called 'Singh Grooves' in the early 1940's, allowing them to run on 70 octane tractor gas.) In fact, we can even use the Lycoming O-145 as a good model of how NOT to do things. (Yeah, it produced 65hp... but only when you spun it up above 3000 rpm. Stuck on the nose of a Piper 'Cub' it was a TERRIBLE powerplant, simply because it produced all of its thrust in a narrow, high-velocity slug of accelerated air into which the fuselage of the Cub was buried. And as we know (and Lycoming seemed to forget), drag increases as the SQUARE of velocity. But AFTER the war, when a bright young fellow named Mooney came along with a sleek little single-place design, the O-145 finally came into its own... because there was simply no comparison to the induced drag of a Cub and a Mite. So what's our engine gonna be? It's going to be what it ALREADY IS, a set of 94mm jugs atop an 84mm Chinese crankshaft. But the difference is in the HEADS. And it's not even the WHOLE head we're talking about, just the outer portion that is associated with the exhaust stacks. This is the HOTTEST part of the VW engine. VW's engineers did some truly remarkable things to ensure the CORNERS of the engine got the MAJORITY of the cooling air. Unfortunately, when you try to do that using RAM-AIR instead of a blower, you run into all sorts of problems, most of which can be resolved by simply increasing the AREA of the cooling fins. And how do we do that? (Someone asks) ...or, Why hasn't someone done that? (another asks)... and in both cases the answer is pretty much the same: We do it by altering the shape of the exhaust outlet, and YES, someone has ALREADY DONE THAT... if you're familiar with the Porsche engine. The point here is that it's not a big change, in engineering terms. Nor even an especially difficult change. The main problem is that all previous efforts were aimed at CAR engines, which presented some space limitations that they simply could not resolve if they wanted the engine to fit in the car. Bottom Line: They came up with a new car- body that provided enough room for the 'fatter' engine -- 'fatter' because it had more fins. And put that fatter engine into airplanes, too. Which means we're not quite the ground-breakers we think we are :-) So what's the basis of our 'success'? Easy! We simply re-design the exhaust to dump out the BOTTOM of the head, as GM did with the Corvair... and which VW could NOT do with the VW engine. When the exhaust stack is moved outta the way it gives us access to the upper- outer corner of the head for each of the jugs, and that is where we install our additional fins. Not only do we add additional fins, we increase the size of the fins that are already there, so that our maximum PEAK output comes up to something on the order of 80hp, whilst our maximum SUSTAINABLE output is about 60hp (Standard Day assumed). Does this give us a 'thousand hour' engine? Hell no! Lookit the bearing area. At that level of output you'll be lucky to get a TBO of 500 hours. Of course, replacing every bearing in the engine will only run you about sixty bucks. Sure sounds easy, eh? In fact, if it's so damn easy you gotta wonder why I haven't already done it. Surprise! I already did... sorta. We called it the 'Fat Fin' head and tried to accomplish what I've described here by TIGing on additional fin area to stock heads. Which didn't work for a lot of reasons, but there were some examples that DID work... until the fins warped or the valves overheated or any one of a dozen other things. Plus the biggie: Fat Fin heads would not fit in a VEHICLE. And without that market, they were little more than a joke... some crazy ol' guy wanting to put a VW engine in an airplane, for crysakes! ------------------------------------------------------------------------------------------- How do you get in touch with OTHER 'crazy ol' guys?' Back then, you got Pope Paul to put a notice in the magazine. Remember all them notices? Yeah. I don't either. But now we got the Internet. Tell you what... Somewhere in my drawings I've got a stock VW head, sorta -373'ish (that's a VW part number... don't sweat it). I'll dig it out, convert it into a .jpg and post it on my blog. Then you can blow it up to near-full-scale and print it out. One it's printed, you can start fooling with the location of this & that... moving the exhaust stack... which is when you'll discover that a push-rod and an exhaust stack will NOT peacefully co-exist :-) But there's a couple of ways in which they WILL... expect they put one hell of an angle onto the push-rod... and you gotta move the rocker-arm around... stuff like that. THAT'S what we're talking about here. Once we can move the exhaust stack WITHOUT trashing the push-rod, we can increase the cooling-fin area by about 25%... mebbe more. Best of all (mebbe) is that we'll come up with a casting that the average home machinist can turn into a cylinder head. And that will only take another 10,000 words or so... plus a few hundred pitchers... if anyone is interested. -R.S.Hoover And just for Flavor of the Month -- sump plate |
On Jan 9, 9:28*am, " wrote:
And just for Flavor of the Month -- *sump plate ------------------------------------------------------------------------------------- Okay, okay... I sorta overlooked some asterisks and left you hanging with regard to the Sump Plate... so cut me a slack, okay? I gotta take some pills & stuff. (...but the Sump Plate is souper simple: You move the sump's DRAIN to one of the 'down-hill' corners of the sump, which allows you to install a PERMANENT sump plate... outta aluminum if you want minimum weight or outta steel if you want to use it as a base for brackets or whatever. Got some pitchers to show you... if I can findem') -Bob |
As promised, three ILLUSTRATIONS of drawings depicting the later-model
VW dual port head. Posted to my blog: bobhooversblog.blogspot.com Now I gotta go do my exercises. (My wife calls them 'Comic Relief.' ( I got a TOUGH crew.) -Bob |
schreef:
Indeed, comparing the American & British efforts makes a damn good adventure novel -- one in which the British should have won (ie, because of their slide-valve engines). [[off-topic, only of interest to historians:]] Bob, you are writing history here as a US'an crediting a US patent to a non-US'an! Indeed Mr. Charles Yale Knight, first holder of sleeve-valved engine patents, was born in Indiana, USA, in 1868, at least that's what I learn from http://en.wikipedia.org/wiki/Knight_Engine Then again, his idea was based upon early concoctions by German Mr. Otto, and then again his ideas were most succesfully implemented in Europe, in some British aero-engines (Bristol Centaurus and its predecessors) but also in the notorious luxury Minerva cars from Belgium - that factory was close to my home, indeed the allies only nearly missed killing my mother when trying to bomb the factory in May 1943. KA |
jan olieslagers wrote:
schreef: Indeed, comparing the American & British efforts makes a damn good adventure novel -- one in which the British should have won (ie, because of their slide-valve engines). [[off-topic, only of interest to historians:]] Bob, you are writing history here as a US'an crediting a US patent to a non-US'an! Indeed Mr. Charles Yale Knight, first holder of sleeve-valved engine patents, was born in Indiana, USA, in 1868, at least that's what I learn from http://en.wikipedia.org/wiki/Knight_Engine Then again, his idea was based upon early concoctions by German Mr. Otto, and then again his ideas were most succesfully implemented in Europe, in some British aero-engines (Bristol Centaurus and its predecessors) but also in the notorious luxury Minerva cars from Belgium - that factory was close to my home, indeed the allies only nearly missed killing my mother when trying to bomb the factory in May 1943. KA Yeah an American invented it, but it took Harry Ricardo and crew to make it really sing. Charles |
Charles Vincent wrote:
jan olieslagers wrote: schreef: Indeed, comparing the American & British efforts makes a damn good adventure novel -- one in which the British should have won (ie, because of their slide-valve engines). [[off-topic, only of interest to historians:]] Bob, you are writing history here as a US'an crediting a US patent to a non-US'an! Indeed Mr. Charles Yale Knight, first holder of sleeve-valved engine patents, was born in Indiana, USA, in 1868, at least that's what I learn from http://en.wikipedia.org/wiki/Knight_Engine Then again, his idea was based upon early concoctions by German Mr. Otto, and then again his ideas were most succesfully implemented in Europe, in some British aero-engines (Bristol Centaurus and its predecessors) but also in the notorious luxury Minerva cars from Belgium - that factory was close to my home, indeed the allies only nearly missed killing my mother when trying to bomb the factory in May 1943. KA Yeah an American invented it, but it took Harry Ricardo and crew to make it really sing. Charles From what I remember from the vintage car meets is that the sleeve-valve Willies-Knight, is that even in good running condition would smoke like a two stroke. It's one of those screwy inventions best left to the history books. Tony |
Yeah! I'm back online..No thanks to Charley. | CFLav8r | Piloting | 10 | August 24th 04 04:14 AM |
Yeah, I got that one... | Wade Meyers | Military Aviation | 0 | July 1st 03 04:45 AM |
