what every boy needs - yeah seriously
Old January 9th 09, 05:33 AM posted to rec.aviation.homebuilt
Default what every boy needs - yeah seriously
First off, we can forget about lost-foam or anything more exotic than
green-sand, simply because there aren't enough of us.
Lost foam isn't all that "high tech" and is actually well within the
ability of anyone that can build their own foundry and ram up some
sand. Classic lost wax is still a viable option and if one uses oil
based sand rather than bentonite green sand you can get much better
detail and steeper angles - but you do need a muller for oil sand.
Here again, borrow a page from the Corvair (or from GM) and we end up
with a 'rocker arm' that actually works. *The tricky bit is that it
does NOT need to be aligned on a shaft... we can literally put a valve
anywhere there is room. *And that means at any angle as well.
My conclusion as well - but if the angles aren't chosen very carefully
we end up with greater than stock side loads on the lifters - thus my
conclusion that we need a new cam at some point or run the risk of
accelerated lifter bore wear. Trying to put a second plug in the mix
and I'm not smart enough to come up with angles that I'm comfortable
with.
Personally I see no need for 2 plugs per cylinder. When was the last
time anyone heard of a spark plug failing with out warning? As for
flame front prorogation, the only real justification for dual plugs
other than unreliable magnetos, we just don't need them on a VW based
engine unless you start thinking high rpm's and a PSRU. But that's
getting too far away from the cheap and simple.
So we make a L-head and an R-head; mirror images. *We do the best we
can with the fins but recognize our limitations and leave the most
difficult of them as CUT fins
If we do the split heads (still need 2 cores, front and rear) the fins
can be rough cast and then finished up on a lathe. The mention of
sawing gives me the idea of using a saw mounted on the lathe for
quicker cutting than a standard tool and maybe even thinner fins. Band
saw off the fins next to the other head and your done. No CNC
needed. My next set of 1/2 VW heads will be done this
way................if I ever get around to a next set.
Leon McAtee
Old January 10th 09, 05:27 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
* First off, we can forget about lost-foam or anything more exotic than
* green-sand, simply because there aren't enough of us.
*Lost foam isn't all that "high tech" and is actually well within the
*ability of anyone that can build their own foundry and ram up some
*sand. Classic lost wax is still a viable option and if one uses oil
*based sand rather than bentonite green sand you can get much better
*detail and steeper angles - but you do need a muller for oil sand.
*Leon McAtee
How can you mold or sculpt invest foam articles with a simple hobby process,
and then get something as detailed as air cooled fins on a foam or wax
investment to withstand even the most careful ramming process for green
sand, oil sand or air set casting?
Also, if you use oil sand and wax investments, how can you possibly remove
enough wax from the mold to allow the introduction of molten aluminum and
yeild a useable casting, when you have detail as fine as a cooling fin?
Old January 10th 09, 07:27 PM posted to rec.aviation.homebuilt
Dear Maxwell,
While there are some pretty sturdy plastic-like waxes that can
withstand ramming-up in a core box, most of the methods using lost wax
begin by DIPPING the wax model in a slurry of high-temperature CLAY,
after all of the sprues, vents gates and supports have been attached
manually. After the clay dries it is BAKED, first at a fairly low
temperature ( ie 200F ), during which it is rotated several times to
get rid of the casting wax, and finally at a higher temperatures, such
as 500F for about two hours. The resulting product is then stiff
enough to withstand ramming.
There are variations to this theme. Some call for several dipping &
baking episodes using different recipes of clay. Dentists are the
best source of information on this procedure. The main down-side is
the HIGH COST of the refractory clay dips.
-Bob
Old January 10th 09, 08:24 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
process,
Dear Maxwell,
-Bob
I'm well aware of the variations in the investment casting process, but you
hand already limited the discussion to a sand casting, and for economic
reasons I would have to agree. But there is no way to use a wax investment
in a sand casting. Subsequent melting of the wax will contaminate the sand
mold, regardless of green sand, oil sand or air set.
Considering the use of foam, first we have to mold or sculpt a foam cylinder
head in full detail for each head we have to produce. Then adequately pack
sand between the fins of a foam pattern, when the fins are as detailed as
this project would require. Doesn't sound possible, much less practical to
me.
Old January 10th 09, 08:17 PM posted to rec.aviation.homebuilt
Your're thinking WAY too much inside the box. Making the molds for
the wax/foam cores is simple and there are many references to the
process(s) on the internet.
Ramming up sand directly on a foam or wax mold - isn't - practical.
Maybe if you resorted to vibration to pack core sand and then gas the
whole thing with CO2 ? But there is a way around that limitation as
well. Again, a search on the net should turn up some clues. I'd find
a link or 2 for you to start but I have to head out for the weekend
shopping with the Wife .............. maybe this evening.
yield a usable casting, when you have detail as fine as a cooling fin?
I may have been unclear in my earlier post. I did not intend to imply
using oil based sands with investment casting. Sounds kind of messy!
I meant that oil based sand allows one to make better detail and
thinner parts than you can get with bentonite based sands. Should
have been a separate paragraph...............
Investment casting of the quality needed is very doable by the hobby
caster.
Leon McAtee
Old January 10th 09, 08:44 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
process,
Care to provid a link of something as complex as VW head, "hobby" molded in
foam?
Doesn't matter what other process there are, you still have to have the
"hobby" molded foam or wax investment.
caster.
If you can reference any hobby process that will made it "simple" to cast
custom air cooled VW heads at home. I can assure you, I'm not the only
person on this group that would like to see a link.
Old January 11th 09, 04:47 AM posted to rec.aviation.homebuilt
I'd never have thought this technology was that obscure :-) 'course
it depends on your definition of "simple". You have to make or buy a
whole bunch of new tools and learn a few new skills if you have never
done it before. Kind of like making an airplane from a pile of raw
materials (the token aviation reference)
To me it's pretty straight forward use of patterns and molds, but then
again I had the good fortune of my grandfather showing me how to make
molds and fire porcelain things just shy of 50 years ago. We could
have made VW head molds back then using nothing more sophisticated
than some clay, plaster and green soap. The materials available
today make the process MUCH easier.
Fire up Google and see what others are doing.
My first exposure to hobby foam casting came from such an adventure
and was found of all places on a site run by a den mother describing
how to make foam trinkets for the kids to paint. If some 8 year old
kids can do it.......................
http://www.foundry101.com/racert2.htm
Not the site I had in mind but this is using green sand - with enough
detail and complexity for a VW head.
I've also been keeping my eye on a couple of interesting projects
being pursued by "Why Not!" types trying to build inexpensive 3D
printers. Think what we could cast up with one of those out in the
garage.
Leon McAtee
Old January 13th 09, 02:14 AM posted to rec.aviation.homebuilt
Couldn't find the site I discovered a few years ago - even had some
pictures - but I did find these this afternoon after a quick google.
http://www.plansandprojects.com/My%2...am_casting.htm
https://duckdeco.dkgnet.com/Molds.htm
http://www.tempo-foam.com/engineerin...ands_index.htm
http://www.wowessays.com/dbase/af2/skx196.shtml
http://www.mate.tue.nl/mate/showabstract.php/3871
http://www.answers.com/topic/expande...yrene-foam-epf
Combine this info with the fact that we can buy silicone casting
compound that lets us directly cast low melt metals like zinc and
pewter and I'll leave it up to the reader to connect the dots.
My only problem now is finding a source of the EPS beads again. One
of the local hobby-n-craft stores had them, but they went the way of
the missing web site.
Leon McAtee
Old January 13th 09, 03:58 AM posted to rec.aviation.homebuilt
Maxwell[_2_]
Leon McAtee
I'm well aware of the lost foam and lost wax processes Leon, as well as
their limitations. Do you have any examples of something being cast as
complex as an air cooled cylinder head? Coffee cups, duck decoys, and alike
are useful items, but hardly good examples for the task at hand.
Old January 13th 09, 04:13 AM posted to rec.aviation.homebuilt
You ever heard of something called an internet search engine? Try
Google, Yahoo, Altavista, Ask, or Dogpile. (add a "dot"com to the end
to make 'em work)
Examples of lost foam casting of the complexity required are quite
common.
L
Yeah! I'm back online..No thanks to Charley. CFLav8r Piloting 10 August 24th 04 04:14 AM
Yeah, I got that one... Wade Meyers Military Aviation 0 July 1st 03 04:45 AM
