RG-58 thinet cable
Old January 13th 09, 04:47 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
rmhou at yahoo.com
Default RG-58 thinet cable
http://www.cablestogo.com/product.as...=710&sku=03188
Would these cable work on aviation NAV/COM/antenna?
Thanks in advance.
Robin Hou
Old January 13th 09, 06:08 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Dear Robin,
Yeah, it would probably work for you, signal-wise. But I don't know
what you need with regard to weather and UV exposure -- some cables
are better than others and the only person qualified to say, is you.
But I can tell you that the outfit you've cited is kinda on the
expensive side. If you'll check the address below I think you'll find
their prices are a bit more reasonable.
http://www.allelectronics.com/make-a...G58/U/-/1.html
Also, once you make your connection with a BNC connector, it's kind of
hard to add safety wire. So instead of wire (which can sometimes
puncture the braid and lead to problems) the usual procedure is to use
one of the sticky-tapes, which is also carried by All Electronics.
The trick is to over-lap your wrappings, starting well beyond the
metal fitting... give it an inch or so... then squeeze the tape down
good & tight. You'll end up with a water-proof junction that also
resists coming loose.
-R.S.Hoover
-KA6HZF
Old January 13th 09, 08:34 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
On Mon, 12 Jan 2009 22:08:28 -0800 (PST), "
Dear Robin,
Good quality RG-58 can be found for about 21 cents per foot
(discount), BUT be careful about what kind you get particularly if its
going to flex or be subject to vibration. Straight RG58 has a solid,
tiny, center conductor while the AU and some others have stranded.
Good BNC connectors are at least several dollars each. That makes me
wonder about the quality of the above.
Another alternative is one of the RG8X versions which is the same
physical size as RG-6, but 52 ohms, is very flexible and runs about 32
cents per foot. It also has less loss than RG58. My choice is the
RG8XIIA which has a foil plus braid shield at
http://www.therfc.com/coax.htm
BTW, regular RG8 cables are nearly a half inch in diameter while the X
versions are much smaller.
Most of the cable suppliers will have the specs as to whether the
cable is UV resistant or not.
I use "flooded" heat shrink tubing. It has a layer of hot melt glue
on the inside and when slid up over the connector as far as possible
without interfering with the operation of the connector makes a good
solid connection that is far stronger than tape. OTOH the stuff is
only available in 1 meter lengths. It's easily cut, but runs about $10
a length. Although it can be removed with care, I consider all
connections permanent and if I have to remove one I throw it away.
http://www.rogerhalstead.com/ham_files/connectors.htm shows the
installation on larger cable and connectors. The smaller size tubing
0400 starts out at 0.40" an shrinks to 0.12" minimum. This is a
rather heavy, industrial grade tube so some might want something
lighter.
-R.S.Hoover
-KA6HZF
Roger (K8RI) ARRL Life Member
N833R (World's oldest Debonair)
Need A Cable Newps Owning 4 May 2nd 06 03:05 AM
Connection cable for an IFR GPS Doug Owning 8 November 29th 04 01:56 AM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
best Winch cable? yo Soaring 2 April 2nd 04 03:47 PM
