Embedded GPS INS (using RLG) are now standard in almost all military
aircraft - often two are used. Neat devices; just turn it on, and in 4 minutes at most you have attitude, velocities, and position. And GPS chips are showing up everywhere. And MEMS gyros and accelerometers are ubiquitous in modern cars. Could be that the hardware to make our theoretical GPS vario will soon be less expensive than classical pneumatic varios - whether mechanical or electronic - if the complete installation cost is compared. What does a really good TE system cost these days? Probe, tubing, installation, etc. So my glider cockpit of the future has an AOA system, a sunlight visible moving map/glide computer with real time weather (disabled for contests, of course), GPS Vario, instant-on attitude info for when you get sucked into a cloud or trapped above a deck in a wave, ADS-B in/out to show traffic around me, SPOT to let the family know where I am. And I want to be able to use voice commands to change a task inflight! 66 |
On Jan 14, 3:01*pm, "kirk.stant" wrote:
Embedded GPS INS (using RLG) are now standard in almost all military aircraft - often two are used. *Neat devices; just turn it on, and in 4 minutes at most you have attitude, velocities, and position. And GPS chips are showing up everywhere. And MEMS gyros and accelerometers are ubiquitous in modern cars. Could be that the hardware to make our theoretical GPS vario will soon be less expensive than classical pneumatic varios - whether mechanical or electronic - if the complete installation cost is compared. *What does a really good TE system cost these days? *Probe, tubing, installation, etc. So my glider cockpit of the future has an AOA system, a sunlight visible moving map/glide computer with real time weather (disabled for contests, of course), GPS Vario, *instant-on attitude info for when you get sucked into a cloud or trapped above a deck in a wave, ADS-B in/out to show traffic around me, SPOT to let the family know where I am. And I want to be able to use voice commands to change a task inflight! 66 On Jan 14, 3:01 pm, "kirk.stant" wrote: Embedded GPS INS (using RLG) are now standard in almost all military aircraft - often two are used. Neat devices; just turn it on, and in 4 minutes at most you have attitude, velocities, and position. And GPS chips are showing up everywhere. And MEMS gyros and accelerometers are ubiquitous in modern cars. Could be that the hardware to make our theoretical GPS vario will soon be less expensive than classical pneumatic varios - whether mechanical or electronic - if the complete installation cost is compared. What does a really good TE system cost these days? Probe, tubing, installation, etc. So my glider cockpit of the future has an AOA system, a sunlight visible moving map/glide computer with real time weather (disabled for contests, of course), GPS Vario, instant-on attitude info for when you get sucked into a cloud or trapped above a deck in a wave, ADS-B in/out to show traffic around me, SPOT to let the family know where I am. And I want to be able to use voice commands to change a task inflight! 66 I've broken my triple probe once and cursed at (and fixed) O-ring leaks in other ships, etc. but I'm still not sure I agree this is the worst problem we need to solve. But maybe we could be moving to simpler TE probe installations than many gliders come with. BTW a shootout of TE probes and mounting options would be interesting. So following Doug's points it seems that GPS doppler vertical velocity would give very impressive resolution (ugh I should have know this - embarrassingly I've worked on stuff related to high stability/ultra low phase noise microwave oscillators). But I still think worrying about doing away with the TE probe is not the right thing. Especially since for wind purposes you still need a static + pitot so already need (low cost) sensors for those in the unit and many pilots probably would not want to give up a pure mechanical vario backup (or would they?). I also suspect most people ordering new (expensive) gliders are not going to worry about saving a little by ordering it without a TE probe fitting and plumbing and would want the flexibility of having that installed. If you have the air data (and can get a digital TE if needed) then I'd hope that simple accelerometers could significantly improve TE compensation. If GPS can also improve that then great, but it's a complex high-end type of thing, not something that is going to target saving costs of TE systems. On the "less expensive" theme... you run into an common dilemma with claiming simplicity/cost savings with new technology. To realize that savings they have to take risks and suffer incompatibility with how things work now (e.g. not install a TE probe system in a new glider? Not have a TE probe etc. to also feed to a mechanical vario...). And the cost of developing a new advanced system is likely to be significant, so it is likely going to be something you need to target at the higher end/performance market, with really visceral benefits like providing for radically better wind calculations, much better gust isolation, etc.. So while we are dreaming about possible varios/flight computers here is my blue-sky feature wish list for a vario/flight computer/logger -- an evolved, up to date technology version of something like the Cambridge 302... and I'm completely biased and just want a vario/ logger/basic computer to interface to an external PDA, PNA or ClearNav etc. not a device to navigate etc. on. - Direct reading/pressure based (i.e. not flow rate based, no capacity flask, etc. needed,as done in some several current designs) - Digital TE compensation to remove the need for a TE probe, or to tune the TE probe response as done in some current systems) - Low power consumption. - Good reliability (we have lots of glider instruments with sloppy electric or mechanical design that directly affects reliability. Starting with the corrosion/handling damage prone daughter card/rear panel connector mess that some vendors use.). - ICG approved logger, for everything, built-in ENL support for motorgliders. - A development team who can actually provide support and enhancements for the product. - Selection of audio tones/styles (including simulate some popular audio vario tones. Anybody like the Rico?). - The supplied external speaker if one is needed is not a piece of crap (just about all of them seem to be). - Support better wind calculation than typical today: Including 3D Fluxgate magnetometer enhanced wind calculations. Remote mount (e.g. down the back of the fueslage?) the fluxgate if needed. The main intent is to hand all this stuff off to a PDA but on board calculations of wind as a backup is nice. This may add significant cost. - Decreased horizontal gust sensitivity with accelerometer based filtering/enhancement. I'd hope fairly simple MEMS accelerometers should be enough for this with no need for anything more complex. If GPS can enhance this significantly and be affordable and work reliably (steep banks, next to stepp terrain) etc. then great. - Make sure the advanced stuff does not get in the way, the thing is stupid easy to use and just works, push complex things off to PDA software or other devices. Logging just starts and stops automatically, with absolutely no effort/problems. - Enhanced IGC file logging, allow things like TAS data, fluxgste data, (and many more) to be recorded to the IGC log file (like apparently LX does). - Support dual log files with different parameters, sample rates etc.. Massive IGC log files that can contain extra stuff and a smaller also valid IGC file for uploading to OLC etc. - Use latest generation GPS+WAAS receiver technology for improved signal quality/fix times etc. - Support gobs of flash memory for flight traces. Even club ships should never need to overwrite a flight trace during a season, etc. at reasonable log rates. - Allow very high rate logging rate for beautifully smooth flight traces for pretty post-flight analysis. - Voice announce (needs to be multilingual) for warnings such as gear up, slow speed/stall etc. Too many stupid beeps in the cockpit already. Female voice would be great, just don't make her sound like my ex :-) - Have a variant of the device intended in headless operation (remote mounted with no dial/etc on panel for use where a PDA or other display will show a representation of the vario needle and averager etc. - Try to make the log data survive a crash. We've had a few unexplained fatal accidents where the logger does not survive and I wonder if something simple could be done in an attempt to make the data more likely to survive. e/g. Consider dual logging to onboard memory and a backup SD card plugged into the vario in a protected slot. I'd especially like to see lots of connectivity, e.g. possibly consider things like the following... - Utilize standard IGC RJ-45 connector wiring (All connector choices have issues, but there *is* supposed to be a standard). - Built in Bluetooth serial port profile support, in addition to legacy RS-232 serial ports, to drive external PDA and PNA devices. Could support dual Bluetooth connections for two-seat gliders. - USB Host support for file transfer, make the logger look like a disk drive and downloading IGC files just drag and drop from a laptop. Real USB support not a built-in USB to serial adapter pretend stuff some vendors ship today. - Could also consider USB OTG support - i.e. support USB client for connecting a Laptop or USB host for connecting to a PDA for high- speed file/waypoint/firmware updates etc. - Support for Bluetooth file exchange (flight traces and waypoints etc.). This works with many laptops and PDAs and is likely a very easy for people to use if they have a Bluetooth capable Laptop or PDA and speeds are probably OK until you get to huge log files. Thing's I'm not sure would work ... - More advanced AHRS/INS technology. Why do we need this? If you want a T&B or attitude indicator I think these are different devices and we are better off leveraging the larger market for experimental and light sports instrumentation. - A built in AOA meter? But maybe I'd consider a warning/alarm? Has anybody shown AOA displays to be useful in gliders? For stall warning? For thermalling/flight optimization? It might be useful with voice annunciations/warnings? (too many things beep already) - A vario/ computer could integrate an AOA sensor into slow speed/stall warning and that could be great. The safeflight AOA instument is just a meter right?, with no audible alarm? - they seriously want to add another thing the pilot has to look inside the cockpit? - Some people are playing with enhanced TE probes that try to align with the airflow, the mechanical complexity worries me. Not sure how significant the problem they are trying to solve is. That would be something interesting to see more info on. --- It hurts to think about the development effort/cost of something like this but I'll be dissapointed if we don't see some of these more advanced features in devices in the next few years. Darryl |
I like most of what Darryl said. I've winnowed it down to the things I
really want to have that my 302 doesn't have. Darryl Ramm wrote: - A development team who can actually provide support and enhancements for the product. - Support better wind calculation than typical today: Including 3D Fluxgate magnetometer enhanced wind calculations. - Decreased horizontal gust sensitivity with accelerometer based filtering/enhancement. Maybe use the accelerometers that are already there, for starters. - Enhanced IGC file logging, allow things like TAS data, fluxgste data, (and many more) to be recorded to the IGC log file (like apparently LX does). Especially if it would accept data from outside sources; e.g., an engine data logger. - Support dual log files with different parameters, sample rates etc. or at least send them out to the PDA that could make that huge log file with all manner of stuff in it the IGC doesn't need. - Voice announce (needs to be multilingual) for warnings such as gear up, slow speed/stall etc. Too many stupid beeps in the cockpit already. - Make the log data survive a crash. - Utilize standard IGC RJ-45 connector wiring (All connector choices have issues, but there *is* supposed to be a standard). - Built in Bluetooth serial port profile support, in addition to legacy RS-232 serial ports, to drive external PDA and PNA devices and support for Bluetooth file exchange (flight traces and waypoints etc.). And file transfer by just sliding an SD card or USB flash drive into a socket. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Jan 14, 4:01*pm, "kirk.stant" wrote:
ADS-B in/out to show traffic around me, SPOT to let the family know where I am. Why would you need SPOT? If ADS-B is providing real time position data to ATC what you really need is real time on-line access to that ATC data. Andy |
On Jan 15, 6:58*am, Andy wrote:
On Jan 14, 4:01*pm, "kirk.stant" wrote: ADS-B *in/out to show traffic around me, SPOT to let the family know where I am. Why would you need SPOT? *If ADS-B is providing real time position data to ATC what you really need is real time on-line access to that ATC data. Andy Coverage - will ADS-B find me when I'm down in some valley who know where. Signaling - How do I tell via ADS-B the pilot wants a retrieve is OK or in distress? It is not clear that people really want to be tracked by the feds and there is still that whole unresolved anonymous VFR issue (or has that been settled?) Darryl |
On Jan 15, 9:23*am, Darryl Ramm wrote:
On Jan 15, 6:58*am, Andy wrote: On Jan 14, 4:01*pm, "kirk.stant" wrote: ADS-B *in/out to show traffic around me, SPOT to let the family know where I am. Why would you need SPOT? *If ADS-B is providing real time position data to ATC what you really need is real time on-line access to that ATC data. Andy Coverage - will ADS-B find me when I'm down in some valley who know where. Signaling - How do I tell via ADS-B the pilot wants a retrieve is OK or in distress? It is not clear that people really want to be tracked by the feds and there is still that whole unresolved anonymous VFR issue (or has that been settled?) Darryl Andy, I see SPOT as an improved ELT, and ADS-B as an improved TCAS/TPAS. Different uses, but they do overlap. Kirk |
WAAS info | Paul kgyy | Owning | 6 | February 18th 07 03:37 PM |
WAAS for GNS 430/530? | Dane Spearing | Instrument Flight Rules | 58 | June 14th 05 02:22 AM |
IGC APproval for GPS with WAAS | Ivan Kahn | Soaring | 11 | November 26th 03 11:00 PM |
GPS Altitude with WAAS | Phil Verghese | Piloting | 38 | October 5th 03 12:39 AM |
WAAS | Big John | Piloting | 8 | July 22nd 03 01:06 PM |
