"Peter Twydell" wrote in message
... -------------------------------------------------------------------------------- -- Peter Ying tong iddle-i po! G'day Peter, Are you sure of this ones identity? As far as I knew, the Storch was powered by an Argus inverted V8 engine, not a radial. -- Jeff Cochrane - VK4BOF Innisfail Queensland --- avast! Antivirus: Outbound message clean. Virus Database (VPS): 090119-0, 19/01/2009 Tested on: 20/01/2009 8:59:06 AM avast! - copyright (c) 1988-2009 ALWIL Software. http://www.avast.com |
In message , Jeff Cochrane -
VK4BOF writes "Peter Twydell" wrote in message ... ------------------------------------------------------------------------ -------- -- Peter Ying tong iddle-i po! G'day Peter, Are you sure of this ones identity? As far as I knew, the Storch was powered by an Argus inverted V8 engine, not a radial. Mea culpa. It is a French-built Morane Saulnier MS.505 Criquet, with (I think) a Jacobs radial. There were other versions with Renault and Salmson engines too, and even a Lycoming O-540. -- Peter Ying tong iddle-i po! |
![]() "Peter Twydell" wrote in message ... In message , Jeff Cochrane - VK4BOF writes "Peter Twydell" wrote in message ... ------------------------------------------------------------------------ -------- -- Peter Ying tong iddle-i po! G'day Peter, Are you sure of this ones identity? As far as I knew, the Storch was powered by an Argus inverted V8 engine, not a radial. Mea culpa. It is a French-built Morane Saulnier MS.505 Criquet, with (I think) a Jacobs radial. There were other versions with Renault and Salmson engines too, and even a Lycoming O-540. -- Peter Ying tong iddle-i po! Thanks for the clarification Peter. Still an amazing aircraft though. STOL rules! -- Jeff Cochrane - VK4BOF Innisfail Queensland --- avast! Antivirus: Outbound message clean. Virus Database (VPS): 090119-0, 19/01/2009 Tested on: 20/01/2009 9:48:06 AM avast! - copyright (c) 1988-2009 ALWIL Software. http://www.avast.com |
"Jeff Cochrane - VK4BOF" schrieb im Newsbeitrag
... "Peter Twydell" wrote in message ... In message , Jeff Cochrane - VK4BOF writes "Peter Twydell" wrote in message ... ------------------------------------------------------------------------ -------- -- Peter Ying tong iddle-i po! G'day Peter, Are you sure of this ones identity? As far as I knew, the Storch was powered by an Argus inverted V8 engine, not a radial. Mea culpa. It is a French-built Morane Saulnier MS.505 Criquet, with (I think) a Jacobs radial. There were other versions with Renault and Salmson engines too, and even a Lycoming O-540. -- Peter Ying tong iddle-i po! Thanks for the clarification Peter. Still an amazing aircraft though. STOL rules! -- Jeff Cochrane - VK4BOF Innisfail Queensland --- avast! Antivirus: Outbound message clean. Virus Database (VPS): 090119-0, 19/01/2009 Tested on: 20/01/2009 9:48:06 AM avast! - copyright (c) 1988-2009 ALWIL Software. http://www.avast.com Only for info: The original engine was an Argus 10C. -- Gruß Guybrush |
On Tue, 20 Jan 2009 09:48:05 +1000, "Jeff Cochrane - VK4BOF"
wrote: "Peter Twydell" wrote in message ... In message , Jeff Cochrane - VK4BOF writes "Peter Twydell" wrote in message ... ------------------------------------------------------------------------ -------- -- Peter Ying tong iddle-i po! G'day Peter, Are you sure of this ones identity? As far as I knew, the Storch was powered by an Argus inverted V8 engine, not a radial. Mea culpa. It is a French-built Morane Saulnier MS.505 Criquet, with (I think) a Jacobs radial. There were other versions with Renault and Salmson engines too, and even a Lycoming O-540. -- Peter Ying tong iddle-i po! Thanks for the clarification Peter. Still an amazing aircraft though. STOL rules! The Flying Heritage Museum at Paine Field, Everett WA, has a real Storch in flying condition. It is truly a treat to watch! Bob ^,,^ |
VK4BOF writes "Peter Twydell" wrote in message ... In message , Jeff Cochrane - VK4BOF writes "Peter Twydell" wrote in message ... ------------------------------------------------------------------------ -------- -- Peter Ying tong iddle-i po! G'day Peter, Are you sure of this ones identity? As far as I knew, the Storch was powered by an Argus inverted V8 engine, not a radial. Mea culpa. It is a French-built Morane Saulnier MS.505 Criquet, with (I think) a Jacobs radial. There were other versions with Renault and Salmson engines too, and even a Lycoming O-540. -- Peter Ying tong iddle-i po! Thanks for the clarification Peter. Still an amazing aircraft though. STOL rules! Just to show I really do know the difference, another picture of the Criquet and one of a Storch. -- Peter Ying tong iddle-i po! |
Fieseler Storch archive material FS | Super_Cuber | Restoration | 0 | January 28th 05 05:13 PM |
