Trailer tires
Old January 21st 09, 12:49 PM posted to rec.aviation.soaring
Andy[_1_]
Default Trailer tires
On Jan 20, 4:30*pm, Dave Doe wrote:
If I were you I'd use LT tires (light truck), and run 'em at their rated
60psi (60-65 is about normal for LT tires (should be written on them,
often is)).
The LTX tires on my van has a max pressure of 35 psi so be careful
what you select.
I ran radials at 35 psi on my Minden trailer and it was far better on
rough roads and uneven freeway pavement than my new Cobra which has
smaller wheels and higher pressure tires. I sometimes think getting
the heavy duty suspension was a mistake. It seems too stiff for the
trailer weight.
Andy
Old January 21st 09, 04:19 PM posted to rec.aviation.soaring
Eric Greenwell
often is)).
what you select.
LTX is a Michelin designation, and does not mean it's an "LT" (Light
Truck) tire; e.g. Michelin makes passenger car tires in the LTX series.
So, it's a good warning: make sure you are not confusing the name of the
tire with it's type. The type will be in letters at the beginning of the
tire designation: P = passenger, LT = light truck, ST = special trailer.
For example, Michelin Pilot LTX P275/65R-18 114H RBL is a passenger car
tire.
* Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Old January 21st 09, 05:38 PM posted to rec.aviation.soaring
kd6veb
Hi Gang
There is another important consideration that has not been
thoroughly dealt with in this thread and that is trailer sway with
depends critically on the tires used and their pressures. What is
trailer sway? Well you are tootling down the highway at 50mph and
everything is great and then as you go through 65mph your trailer
begins to swing from side to side much to the consternation of anyone
following you. The only way to reduce this low frequency oscillation
is to slow down fast before the situation can get away from you. So
what are the factors affecting sway? Well the weight of the trailer is
one, the weight of the vehicle hauling, where the trailer wheels are
placed (front, middle or rear) but probably the most critical factor
is the lateral flex of the sidewalls of the tires, wand of course, the
pressure of the tires. When I received my Cobra trailer from Germany
the tire pressures were low about 25psi and what I described above is
a true story. So I pumped the tires up to 40psi and no sway to 70mph
when towing with a heavy vehicle.
In researching trailer sway more fully I found the general consensus
was to use tires with very stiff side walls such as 10 ply non radial
tires (truck tires) and to keep tire pressures up close to the
manufacturers maximum pressures especially if you are going to tow
with a small vehicle. I hope this is of some help.
Dave
Old January 22nd 09, 12:52 PM posted to rec.aviation.soaring
Andy[_1_]
On Jan 21, 10:38*am, kd6veb wrote:
Hi Gang
* There is another important consideration that has not been
placed (front, middle or rear) but probably the most critical *factor
* In researching trailer sway more fully I found the general consensus
Dave
Some people believe that the lateral stiffness of the towing vehicle
rear suspension and tires (tyres) is more important for sway control
than the stiffness in the trailer.
When observing a sway oscillation of a trailer and tow vehicle do you
see translation or rotation at the trailer axle? If both, which is
dominant?
Andy
Old January 27th 09, 05:03 PM posted to rec.aviation.soaring
Hi Gang
Dave
dominant?
Andy- Hide quoted text -
- Show quoted text -
I'm a big believer in tow vehicle stiffness as THE solution. I've got
a fair amount of experience hauling long (sometimes heavy) trailers.
You can do all you want to the trailer tires, but you'll get the best
effect by stiffening the tow vehicle. Just adding tires with higher
load rating (stiffer sidewalls) yields a huge improvement in sway
control. The downside is harsher ride for passenger cars.
Cobra Trailer Tires (US) RN Soaring 25 July 25th 08 06:11 AM
glider trailer tires Ken Ward Soaring 18 October 3rd 06 04:15 AM
Tires... Blueskies Home Built 0 May 10th 05 12:26 AM
Glider trailer tires Greg Arnold Soaring 7 December 7th 04 06:42 AM
Replacing Cobra trailer 13 inch tires with larger? Andy Blackburn Soaring 6 August 19th 04 03:15 AM
