Another AirBus-320 question
Old January 21st 09, 11:25 PM posted to rec.aviation.homebuilt
Peter Dohm
Default Another AirBus-320 question
"pintlar" wrote in message
I have seen reported that the AirBus-320 has a glide ratio of 1:15.
That was what our pilots told us the wings on Cessna 180-182 (L-19)'s
glide ratio was.
It does not seem consistent that a swept, thin airfoil, wing would have
the same glide ratio as the Cessna.
It is correct the AB-320 has a 1:15 glide ratio at zero power?
Those pilots also said a B-52 and a grand piano have identical glide
ratios.
To paraphrase an old movie line: "If the B52 doesn't have a glide ration of
at least 15:1, I'll eat my hat!"
Peter
Old January 22nd 09, 01:37 AM posted to rec.aviation.homebuilt
pintlar
of at least 15:1, I'll eat my hat!"
Peter
I was lead to believe the B-52's wing took a negative angle of attack when
the engines lost power. For the crew, that is nice to know that this is not
true.
Old February 20th 09, 05:47 AM posted to rec.aviation.homebuilt
Highflyer
not true.
I think you will find, with ANY airplane, that the angle of attack is
solely dependant upon the airspeed and the weight. It would not be
expected to change in any way by any power setting, from zero to
max.
Notice that this is definately NOT true for a powered rotary wing
aircraft! :-)
Highflyer
Highflight Aviation Services
Pinckneyville Airport PJY
Old February 20th 09, 12:42 PM posted to rec.aviation.homebuilt
not true.
max.
aircraft! :-)
Highflyer
It is not at all uncommon for a plane to "change trim" with
application of power - add power and many planes will "nose up"
slightly, and back the power down and they "nose down".
This is preferable to the opposite condition, which can happen on the
likes of a Lake or SeaBee. Upthrust od downthrust designed into the
mount combined with the location of the engine is usually calculated
to reduce the effect by tending to cancel each other out, but the
combination is not always totally effective.
Old February 20th 09, 02:57 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
not true.
max.
aircraft! :-)
Highflyer
I think you might say *range* of available angle of Attack?
Or AOA for straight and level flight?
Because at any weight and airspeed, I've always been able to
pull the nose up or down - changing the AOA.
Old February 20th 09, 11:24 PM posted to rec.aviation.homebuilt
Philippe[_2_]
cavelamb a fait l'effort d'écri
And you change the speed or the thrust settings (or both)...
For one weight and one speed, you have one AOA... You may have many
fligt path angle, according to the thrust....
« Si tous les poètes voulaient se donner la main, ils toucheraient enfin
des doigts d'auteur! »
Philippe Vessaire Ò¿Ó¬
Old February 21st 09, 04:26 PM posted to rec.aviation.homebuilt
Brian Whatcott
not true.
max.
aircraft! :-)
Highflyer
For large passenger aircraft, designers attempt to ameliorate loads
by balancing one effect against another.
An example: if you put fuel tanks in the fuselage, the wing bending
moment is greatest with full tanks. If you put fuel tanks in the wings,
the in flight bending moment is LEAST with full tanks.
In the same way, to ameliorate the wing twisting moment due to engine
thrust which increases with thrust, if the engines are set well forward
of the wing center of rotation which twists the wing down towards the
tips, the twisting moment DECREASES with increasing thrust (this is a
balancing act, of course...)
This design effort has the effect of increasing AofA with thrust, which
is a stabilizing factor.
Another design choice affecting AofA is Wing sweep.
Forward sweep has efficiency benefits, but was often considered a lethal
choice. A bump which increased wing bending moment also increases AofA
in swept forward designs, but AofA decreases in Swept back designs.
The later is a load-shedding effect. The former effect is a load
multiplying effect, just when you don't want it.
Brian W
airbus - Latest Plane From Airbus.jpg [email protected] Aviation Photos 14 June 26th 07 09:41 AM
Which is easier: Boeing to Airbus, or Airbus to Boeing? Mxsmanic Piloting 9 February 21st 07 01:58 AM
A question on Airbus landings [email protected] Piloting 17 July 18th 06 09:05 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
Airbus Ace Simulators 0 March 2nd 05 05:13 PM
