Comm Ant. Top or Bottom?
Old January 22nd 09, 05:37 PM posted to rec.aviation.homebuilt
Stuart Fields
Default Comm Ant. Top or Bottom?
"Gig 601Xl Builder" wrote in message
m...
In electrical terms it doesn't really matter, assuming the locations
offer a ground-plane that is more or less identical. But the fact
your airplane did not come with an antenna array already installed
begs the question as to type, age, method of construction and so
forth.
For maintenance however, antennae mounted to the top of the structure
usually offer some benefits. But as always, this is a general rule;
you will run into exceptions... without which this Group could not
survive! :-)
Just be careful not to measure Field Strength readings for a system
using the lower side of the hull, since the proximity of the earth
will skew your readings. Your 'Free Space' radiation pattern should
be identical, top or bottom. But here again, that 'Free Space' only
appears in text books. Ain't nothing 'free' nowadays :-)
-R.S.Hoover
The antenna in question is a Comant CI122 bent whip. Considering all the
advice I will mount it on the bottom but make sure there is enough service
loop in the cable to move it if it doesn't work out.
Excellent comments by Hoover. My measurements on my helicopter definitely
were not "Free Space" but were done with the helo on the ground. However,
the antenna mfr. claims were limited and had a statement of minimum VSWR of
3.
FAA ranks near bottom in Government employee morale EatMe[_2_] Piloting 0 November 18th 07 02:50 PM
Here is the most bottom price, best quality [email protected] General Aviation 0 October 29th 07 11:46 AM
FAA ranks near bottom in Government employee morale AirSafetyPatriot Piloting 6 October 20th 07 07:37 AM
xb-35-bottom.jpg Troy24 Aviation Photos 0 July 12th 07 12:07 AM
Lightnings Today, concluded - yippee-bottom.jpg (1/1) Mitchell Holman Aviation Photos 0 January 15th 07 02:12 PM
