Rearranging the Deck Chairs on the Titanic (was: US 2008 CompetitionFacts)
Old January 24th 09, 03:56 AM posted to rec.aviation.soaring
Default Rearranging the Deck Chairs on the Titanic (was: US 2008Competition Facts)
On Jan 23, 3:11*pm, wrote:
You have apparently not read the rules changes submitted , and
approved ths morning. The addendum does permit *COTS loggers, with
some limitations, for backup in National as well as a variety of lower
cost options for use in Regionals.
The more rigorous requirement you allude to would only apply in a case
of trying to make the US Team.
The impression you leave is that the RC is not responsive to your
suggestions on this topic. In fact, a great deal of time has been
spent on this while trying to find a reasonable balance between cost
to individuals and fairness to all.
You got your way, though maybe not 100% and you're still bitching.
Our guiding principles put safety first, fairness close behind, and
how any change affects participation right at the top of our list.
If you think we need a new charter- feel free to propose it with
concrete examples of how you would propose to accomplish such a
charter.
Sent as an individual member of the RC.
UH- Hide quoted text -
- Show quoted text -
UH,
I'm responding quickly because of the impression I gave you guys that
I'm bitching. I'm not. I did read the proposed rules a few weeks ago
when they were published and quickly re-read the section on flight
recorders a few minutes ago just to see if anything had changed (it
had not). I agreed with most of the changes, for whatever that's
worth.
But I admit I was disappointed in the section on COTS flight recorders
and I'm going to push back. It completes the stealth change in 2008
that essentially eliminated their routine use as a backup device at
the national level. I do recognize that P3 and I have been tasked with
coming up with a workable solution for regionals use, and we
appreciate the opportunity. It doesn't change the fact that the 2008
rules were a step away from 2007 and 2009 is still another step.
Prior to 2008, if a flight recorder met the functional requirements in
the Rules, it could be used as a backup. Period. We can argue about
what was intended but that's what the rules said and that's what I and
some others did using a cheap off-the-shelf Garmin unit. Last year the
RC changed the rules: the functional specs were kept but you created
three lists/classes of flight recorders and it was problematic whether
COTS were accepted as backups (I was graciously granted a waiver to
fly the October Region 4 contest with mine pending the RC's meeting).
This year the process is complete: there are two categories of flight
recorders, and COTS are tossed into the ingeniously titled
"substandard" category [I love that name: did you guys debate using
"schlock" or "junk" or "second class" as the descriptor or was this
your unanimous choice? g]. And the way I read the chart, COTS are
only for regional, not national use, and only by waiver (i.e., there's
no X in the Nationals column for COTS in Appendix B).
Another step backward, in my view, was the rule that says only one use
of a "substandard" backup device is allowed without a penalty. After
that, a modest 100 point penalty is imposed each day. Sarcasm
intended. Obviously no one, serious or not, will take a chance on that
one. So if your primary logger fails, you better hope to borrow
another primary logger immediately (like by the morning of the next
day). Oh, and if it's a CAI Model 20 with a dead battery, forget it.
Because although that unit met the functional requirements for a
backup device last year, it was specifically crossed off the list
because of the broken security seal. This year it's still allowed as a
backup, but you can only use a backup once before the penalty kicks
in. So the unit I borrowed in Cordele last May wouldn't have done me
any good because the security seal was dead on it at the time.
Sorry for the details. You see where I'm going? On the surface, "I got
what I wanted." But not really. Practically speaking, if I'm serious
(meaning I will only spend the $1500 to $2000 to fly a nationals--and
that's sleeping in the van every night--if I want to be scored every
day), I need a second RC-approved logger or guaranteed access to one
on short notice.
OK, I'm focused on the COTS issue. I have a long history of
"constructive" criticism of mandatory flight recorder use at
contests. But I did see a theme he a tendency to try to
eliminate "loopholes" (like the COTS use as a backup, which I and
another pilot first mentioned to another RC member a few years ago)
when there's no evidence that I'm aware of that such loopholes
necessarily need filling.
The start cylinder arc is another issue. I'm not going to worry about
it. But it does strike me as odd that we now have a rule the
application thereof won't be clear until well after we start. Say what
you want about the impact on points being small, but it invites
cynicism and rolling of eyes. Police officer pulling over a motorist:
"I know there was no posted speed limit, sir, but our computer
determined that based on the traffic density, weather, road condition,
and time of day that you were traveling in excess of 15 mph over the
imputed speed limit of 57.2 mph. That's a $100 fine and 2 points on
your license. Please drive carefully, sir."
I worry that the interaction of the ever-changing Rules and WinScore
(which combination actually represents the scoring system) is doomed
to small failures for the simple reason that the Rules themselves and
now WinScore have been patched and fixed so many times that it is
difficult to test them adequately. Using the first contest as the beta
test site isn't a real solution. Yes, I know we been tasked with
developing test data. But as the U.S. car companies discovered years
ago, you can't inspect quality in at the back end of the process. You
need to change the process. That means relatively simple rules and as
few changes as possible. The scoring issue I raised privately was
apparently in the system all year. It affected the daily winners and
order of final placings (though not the overall class winners) at
Region 4 in October.
I profoundly appreciate the job you guys do. The results are pretty
good. But I can tell you that no one flying that I have spoken with
understands the current Rules. Most pilots don't worry about it. They
look at the score sheet and take what's given to them. They might ask
a question if they get a penalty but that's it. The only reason we
tumbled onto the problem at Region 4 is that one exceptionally honest
pilot--Mike Higgins, who ought to get a sportsmanship award--allowed
during his winner's speech that he had busted the floor of the finish
cylinder and warned the scorer that he ought to check his calculations
again.
I've covered a lot of ground. I agree you have safety at the top of
your list. I believe you guys believe that you consider participation
with each proposed Rules change. But do you consider it the same way
as if you were required to justify each economic impact on a case-by-
case basis? For example, raising the deposit from $100 to $150 (the
"at risk" money) and pushing the full-refund date from 14 days to 30
days prior to the contest are significant changes this year. I'm sure
many contest organizers have problems with no-shows and appreciate
being able to plan for tow planes better. But this reminds me of the
tendency for some legislators to raise taxes higher and higher
assuming revenues will increase proportionately. In this case, some
contest organizers have taken a different tack: the astoundingly
successful Region 4N M-ASA regional, which didn't even exist five
years ago and now sucks pilots from perennial favorite New Castle,
doesn't enforce the late entry penalty. Want to fly? Come on down!
Different approaches. I worry that we haven't given the RC enough
latitude, or perhaps the right charge, to explicitly consider
participation on the same level as ensuring competition that fairly
determines the national champion and US team.
I don't have the magic answer. But I also don't think that raising the
questions I did is insulting or disloyal to the great group of
dedicated guys who serve on the RC.
Chip Bearden
ASW 24 "JB"
USA
Old January 24th 09, 04:08 AM posted to rec.aviation.soaring
I responded at length to UH's posting because I was concerned I had
communicated the wrong message. My response to some of the latest
postings is pretty short, however. I've been flying competition since
1968. I consider myself to be a serious competitor even though the
results don't always show it. My glider is definitely NOT
expendable. Nor do I think contest flying is dangerous. There are
risks, certainly. But if I thought they were significant, I wouldn't
fly. Publishing these kinds of statements serves only to increase the
divide between contest pilots and those who might think of trying it
but are put off by the perception that it's dangerous or insular or
just too difficult. I think the Rules Committee does a superb job of
considering the safety aspects of every decision they make.
Chip Bearden
ASW 24 "JB"
USA
Old January 24th 09, 03:30 PM posted to rec.aviation.soaring
Papa3
On Jan 23, 4:28*pm, ZL wrote:
On Jan 23, 1:46 pm, toad wrote:
I think that the decline in contest flying has NOTHING to do with the
racing rules ! *And no tinkering or restraint from tinkering will
change that decline.
It is simply mirroring the decline of soaring in general.
Todd Smith
3S
You may be right, although my impression is that neither soaring in
general nor the SSA membership specifically has suffered a 14%+
decline in the past four years.
snip
Here's some slightly different stats over previous years. The US
Competition Pilot Ranking list. Including some way back, pre-GPS, early
sports class years I found in my files. It gives the total number of
pilots that scored in an SSA sanctioned over the previous 3 years.
Smooths out some of the outlying good and bad years.
1990 - *620
1992 - *630
1995 - *550
2001 - *501
2002 - *551
2003 - *619*
2004 - *636
2005 - *636
2006 - *590
2007 - *592
2008 - *594
* The online list shows 900, hand removing obvious duplicates gives 619
Looks to me like the 20 year trend is remarkably flat. Bigger percentage
of SSA members today, but maybe not a different percentage of total
active glider pilots.
-Dave
ZL
In addition to the above, we have to also admit that non-sanctioned
local contests which didn't even exist on a large scale 15 years ago
are a legitimate form of racing which is growing. As ZA points out
in another post, the Chicago area racing scene is alive and well.
Same with the Governor's Cup in the PA/NY/NJ and the GTA races. I
did a quick back-of-the-envelope look at these three racing series
alone and came up with well over 50 pilots who do compete - just not
in SSA Sanctioned events. So, if I use even the conservative
number of 50 and add that to the numbers from the last 10 years or so
(when most of these series got going), you would conclude that, if
anything, there's been a slight increase in racing participation since
the early 1990s. Given the overall decline in the number of SSA
members, one could see reason for taking an optimistic view.
None of this suggests we can afford to be complacent, but I think "the
reports of racing's death are greatly exaggerated. "
P3
Old January 24th 09, 04:08 PM posted to rec.aviation.soaring
Brian[_1_]
snip
Of course one can fly hors de concourse and have some fun, but is that
really competing, or just getting in the way? *
snip
I think this is where a lot of pilot miss it on contest flying. They
think that contest flying = competing. Of course there a a few that do
really compete but I bet at most regional contests 90% of the pilots
are there for the concentrated week of flying (it is easier to take a
week off of work and fly), availability of tows and crew, (There are
always enough people to retrieve you if you land out), the social
aspect, (spending lot of time around other glider pilots), and the
once every 5 years that conservative flying and luck align to let you
win a day.
With so many MAT and TAT tasks being called most of the time it really
is a lot like just going out and flying on a regular Saturday
afternoon and going where you want to. Maybe we should start calling
the a regional fly-in instead of a contest.
Brian
HP16T
Old January 24th 09, 04:25 PM posted to rec.aviation.soaring
Default Rearranging the Deck Chairs on the Titanic (was: US 2008 Competition Facts)
First let me say "I have never flown in a contest, but my friends have."
A few years ago one of these friend took his well maintained Schreder
sailplane to the Sport Class National contest. He is a skilled pilot and
placed in the middle of the pack. At the time his EW Model D and Garmin
were acceptable. For him to compete in the future he will be required to
invest between 10 and 20 percent the value of his glider and trailer.
What information is provided by the "approved" flight recorders that cannot
be derived from a EW Model D?
It appears that this type of rule's only purpose is to keep people with big
buck gliders from being embarrassed by a kid flying an affordable 40 year
old bird.
HP-14 "6F"
http://www.soaridaho.com/Schreder
On Jan 23, 3:11 pm, wrote:
....Snip...
.... Snip ...
Chip Bearden
ASW 24 "JB"
USA
Old January 24th 09, 06:15 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
But the EW D is still an approved IGC recorder up to Diamonds, and National
Comps in most parts of the World (provided it is attached to an appropraite
Garmin so that the record shows it was set to WGS84).
Does the USA have different rules to IGC?
have."
cannot
big
old bird.
HP-14 "6F"
Old January 24th 09, 06:43 PM posted to rec.aviation.soaring
have."
sailplane to the Sport Class National contest. *He is a skilled pilot and
placed in the middle of the pack. *At the time his EW Model D and Garmin
were acceptable. *For him to compete in the future he will be required to
cannot
big
old bird.
HP-14 "6F"
http://www.soaridaho.com/Schreder- Hide quoted text -
He can us it today- we mirror the IGC list.
UH
Old January 24th 09, 06:47 PM posted to rec.aviation.soaring
"Peter Purdie" wrote in message
National
appropraite
Peter,
In Appendix B of the 2009 USA rules proposal the EW Model D is allowed at
the Regional competitions; however, is excluded for National level
competitions.
For all,
I woke up on the "wrong side of the bed" this morning and found this
restriction to handicapped Sport Class meets especially irritating.
HP-14 "6F'
Old January 24th 09, 06:58 PM posted to rec.aviation.soaring
Hank,
Forgive me, I miss read Apendix B!!!
(http://www.ssa.org/files/member/2009DraftRulesv5.pdf) I hope it continues
to remain a Sport Class option in the future.
Sorry about that!!!
Respectfully,
HP-14 "6F"
P.S. I knew I woke up on the wrong side of the bed this morning!!!
National
appropraite
have."
cannot
big
old bird.
HP-14 "6F"
UH
Old January 24th 09, 07:13 PM posted to rec.aviation.soaring
Bruce
Default Rearranging the Deck Chairs on the Titanic (was: US 2008 CompetitionFacts)
Chip Bearden
ASW 24 "JB"
USA
Indeed - Contests are not dangerous. Pilots are dangerous.
If you fly within your limits as fast and as well as you are safe to do,
flying in a contest is actually lower risk than less organised XC. There
is excellent weather, professional tasking, and close following of your
whereabouts.
I am seldom anywhere near the front, but FAI club class is great fun -
and if your contest scorer is good you know where you stand by the time
the last to land has a second drink in his or her hand. Of course the
website score is occasionally wrong for days...
The "kindergarten" class is a great place to learn to fly better,
without getting in peoples way. I will probably never win even a day in
club class, but my flying improves , and I learn from every contest.
Unfortunately , as recent Grand Prix events have shown, it is dangerous
flying in extreme conditions, or at extreme limits. But the fact remains
that the pilot (generally) chooses the risk level.
Jim Weir's OSH Chairs Jay Honeck Owning 4 October 7th 06 04:44 AM
Jim Weir's OSH Chairs Jay Honeck Piloting 6 August 18th 06 04:34 AM
Jim Weir's OSH Chairs Jay Honeck Owning 6 August 18th 06 04:34 AM
Jim Weir's OSH Chairs Jay Honeck Home Built 6 August 18th 06 04:34 AM
Roger Long Titanic Discovery john smith Piloting 11 December 8th 05 07:56 PM
