On-board Video Equipment?
Old January 28th 09, 09:31 AM posted to rec.aviation.soaring
noel.wade
Default On-board Video Equipment?
Hi All,
I'm hoping to take some on-board video of my first Regional
competition in April - but all I have right now is a hand-held
camcorder. OBVIOUSLY that is not a safe device to use when doing any
serious flying; especially not in a contest environment!
So I wanted to ask folks if they knew of a good setup to use. I'm
thinking about a bullet/lipstick camera that I can put either in the
cockpit (on some kind of remote mount), or up on the TE probe. I want
something I can simply turn on at the beginning of each flight and let
it capture a couple of hours of video (hands-free operation so its not
a distraction during my competition).
I've found some interesting "helmet-cam" type systems (the VIO POV1
system is especially impressive), but I'm not sure if these systems
have a wide-enough lens or can focus on distant objects well-enough to
capture the actual scenery when soaring.
Any tips or ideas on equipment?
Thanks, take care,
--Noel
Old January 28th 09, 01:04 PM posted to rec.aviation.soaring
On Jan 28, 3:31*am, "noel.wade" wrote:
Hi All,
camcorder. *OBVIOUSLY that is not a safe device to use when doing any
So I wanted to ask folks if they knew of a good setup to use. *I'm
cockpit (on some kind of remote mount), or up on the TE probe. *I want
Thanks, take care,
--Noel
May I gently suggest that flying a first competition and in-air
photography are each tasks that take 120% of your attention and
probably not wise to combine.
John Cochrane BB
Old January 28th 09, 02:40 PM posted to rec.aviation.soaring
Rob[_5_]
I managed to get an ACT3K for Christmas that I believe will be ideal
for this kind of thing -- but I won't be able to report back any first-
hand experience until all the stupid snow is gone. . ..
http://www2.oregonscientific.com/sho...?cid=6&scid=14
There are a few sample videos on the web, but mostly made with
motorbikes: http://ca.youtube.com/watch?v=yD2MufbV_To
Cheers,
Rob
Old January 28th 09, 02:55 PM posted to rec.aviation.soaring
Noel,
The esteemed John Cochrane BB is right on. Adding camera duties on top
of your flying duties at your first contest invites equipment
overload. Two or three contests down the road you can consider the
wisdom of a video camera in the cockpit. The contest work load is not
to be under anticipated.
John Seaborn A8
Old January 28th 09, 03:20 PM posted to rec.aviation.soaring
Tuno
Rob,
That ACT3K looks interesting but I can't find any mention at the web
page or its user manual wrt how much video it will hold. With a
storage limitation of 4G it doesn't seem it will be very much. What's
been your experience?
Is the quality good? I've seen lots of cameras that specify 640x480
resolution but they do it will CCDs that are smaller, sometimes a lot
smaller.
~ted/2NO
Old January 28th 09, 04:12 PM posted to rec.aviation.soaring
Frank Whiteley
hand experience until all the stupid snow is gone. . *..
motorbikes:http://ca.youtube.com/watch?v=yD2MufbV_To
Cheers,
Rob
In the SSA Video Gallery, the video by Dave Newill (2nd row left) as
taken with an ACT2K. Expect the same output from the ACT3K.
POV.1 has had a couple of nice upgrades to support up to 8GB SDHC
cards and an external power feed. It has several video settings
also. It now appears possible to record up to 5h45m in the highest
setting without touching it, which would be good if used in
competition. The latest camera head has 110degs field of view. It
takes up more space than a camcorder or ACT3K.
That said, an hour to 80mins of miniDV tape yields 15GB of hiqh
quality video. These other devices are considerably lower quality for
post flight processing, but they are a lot less hassle.
Frank Whiteley
Old January 28th 09, 06:16 PM posted to rec.aviation.soaring
Paul Remde
Hi Noel,
While I agree with others that you don't want to be "playing" with the video
camera while in flight, I do think that it would be OK to rigidly install
something before flight and forget it while in flight.
I had a company approach me recently about selling their digital video
systems. They are designed for use in race cars and aircraft. They are
more expensive though - starting at about $1698 for a single camera system.
It uses a very small Sony EXView 580 camera head and a small digital
recorder box. It is not HD quality, but much better than the low cost video
cameras mentioned elsewhere in this thread. The videos on their web site
are quite impressive.
I told them I would think about selling their products after seeing if their
is interest first. I plan to mention the system in my next newsletter. It
would be fun to sell products like this, but I fear that the technology is
changing so rapidly that it doesn't make sense to stock anything.
The systems are from datatoys.com. Below are some links to the products of
interest.
http://www.datatoys.com/products/Spe..._11/index.html
http://www.datatoys.com/products/Pro...duct_info.html
Let me know if you are interested in one of their systems and I'd be glad to
help you out.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"noel.wade" wrote in message
Hi All,
Thanks, take care,
--Noel
Old January 28th 09, 06:31 PM posted to rec.aviation.soaring
Papa3
Do some of you you even read a question before answering to it? Noel
explicitely asked for something he "can simply turn on at the beginning
of each flight and let it capture a couple of hours of video".
Both of the folks who replied clearly read the post and clearly
anticipated the problems that a newbie wouldn't. Imagine the
scenario... Sitting on the grid 10 minutes before launch. Time to
turn on the camera. Let's see if the little green light comes on.
Hmmm... no little green light. I wonder why that is? Let's check
the connections to the battery. Damn... I wonder if I forgot to
recharge. I'll just stroll back to the trailer to get the backup.
Hmm... I know it's here somewhere. Hey, why are all those guys down
on the line jumping up and down?
I'm sure Noel is smarter than that. Unfortunately, that's "resting
IQ." Contests seem to make us all dumber by 25%, and suddenly we're
not nearly as smart as we thought we were.
There are so many things that can and will go wrong at the first
contest. Do you really think that playing Warren Miller of the Sky
is a smart use of what little brain capacity may be left?
Sometimes the pundits really do know what they're talking about.
Respectfully submitted,
P3
Old January 28th 09, 06:36 PM posted to rec.aviation.soaring
Andy[_1_]
With a hand held camera the pilot has to point the camera to frame the
picture. With a fixed camera the pilot has to point the glider to
frame the picture. While it may be possible to turn it on and forget
it, I think it is possible, or even probable, that there would be a
temptation to fly differently with an active camera on board.
Andy
On board video from Sun and Fun Air Show Capt. Geoffrey Thorpe Piloting 1 May 1st 07 01:10 AM
EAA Board of Directors RST Engineering Piloting 12 April 19th 05 03:37 PM
new board in VL Keivn Anderson Soaring 3 September 18th 04 01:40 AM
Our new board Brett Home Built 0 August 26th 04 08:53 AM
