On Jan 28, 11:07*pm, JS wrote:
Jim et al: * All LS-4 Tech Notes are on...http://www.dg-flugzeugbau.de/Data/TM-LS/LS4/ (scroll to the bottom of the main "Technical Notes of our Aircraft" page, don't use the LS4/4a link on the left side) Jim Thanks Jim! That's what I was looking for. |
So which one is it?
On Jan 29, 2:19*pm, wrote:
So which one is it? I scanned them all, and none mentions replacing the gas spring with an aluminim bar. Technical Bulletin #6012 for the LS6 is about replacing the gas strut with part # 4R2-111, which I believe is the aforementioned aluminum bar. I won't name names, but at least two people that I hold in high esteem have stated that they have done this to other LS's. |
Here's the deal with LS-3/4/6/7's. When the shock absorbing gear is
under duress (as in bouncing on a rough landing), as the rear member absorbs the up-down motion, the geometry of the gear is changing. Not much, but enough to make the retraction rod (and therefore the retract handle) start MOVING! This is an undesirable situation, because the gear can collapse ( I hate it when that happens). Rolleden Snyder, in their wisdom, delt with this by placing a gas strut in the retration rod going to the retract handle, so now the gas strut absorbes the slight motions and that allows the retract handle to stay snugly in its assigned down position. Problem solved and everything was fine until the gas struts started loosing their poop and we were right back to the gear collapsing, only now it could collapse on a very gentle landing. Ah ha, said RS, lets replace the gas strut with a solid bar because the fix is worse than the disease and we'll just hope that little handle stays where its supposed to be. One can check the condition of ones gas strut by pushing forward on the rear "H" member of ones landing gear as in, try to make it collapse. It should only move about a half inch and spring right back.................if not, one might be in for a rude surprise on the next takeoff or landing. Oh yeah, recommend this check only be performed with the fuselage jacked up on the trailer saddle. One other little tid-bit, make sure the fuselage is jacked up high enough to allow the gear to completely extend without touching the ground or ..................see above about gear collapsing on takeoff. Cheers, JJ |
Good point about why the gas strut is there in the first place, JJ.
....Thought it was just for entertainment value. Jim |
Is there a suitable replacement gas strut that can be bought in the US
(McMaster??) rather than ordering from Germany? |
On Jan 30, 11:13*pm, wrote:
Is there a suitable replacement gas strut that can be bought in the US (McMaster??) rather than ordering from Germany? Last one we got was from : http://www.solairecanada.com/index2.htm Around $80, I think. |
American air industry collapse? | Huh?What?[_2_] | Piloting | 26 | July 8th 08 09:34 AM |
747 gear collapse crushes worker | JA_MORAN[_2_] | Piloting | 6 | November 24th 07 04:03 PM |
Neo-Con Collapse in Washington and Baghdad | WalterM140 | Military Aviation | 1 | June 11th 04 07:37 PM |
"Aluminum Overcast" damaged by gear collapse | James Robinson | Piloting | 57 | May 14th 04 11:14 PM |
EAA's B-17 "Aluminum Overcast" Gear collapse at Van Nuys airport | BlakeleyTB | Home Built | 4 | May 8th 04 06:15 AM |
