#11
On Jan 29, 10:22*am, Richard wrote:
On Jan 29, 9:45*am, Jim White wrote: At 16:13 29 January 2009, Richard wrote: The backlight and the battery scheme can be set in the CE 5.0 control panel. Start-Settings-Control-Panel-display-backlight * uncheck all Start-Settings-Control-Panel-Power- *set both schemes to all never These settings will be save in the registry automatially. Just a note Craggy Aero has had the 310/314 *power cable available for the Ipaq 310/314 for about 2 months. http://www.craggyaero.com/pdam.htm Richard www.craggyaero.com Thanks Richard but all these settings are lost on reset. Do you know how to make them stick? So far I reckon simplest is a script. Jim- Hide quoted text - - Show quoted text - JIm, My settings are not lost when I do a soft reset with the pen. *I am running SeeYou Mobile from the SD Card. *Maybe something in their setup from the card saves the settings. Richardwww.craggyaero.com I agree with Richard about not losing settings when booted from a card. Solid as a rock. Also I really like the airspace files from JustSoar loaded in, works very well. |
On Jan 29, 12:18*pm, brianDG303 wrote:
On Jan 29, 10:22*am, Richard wrote: On Jan 29, 9:45*am, Jim White wrote: At 16:13 29 January 2009, Richard wrote: The backlight and the battery scheme can be set in the CE 5.0 control panel. Start-Settings-Control-Panel-display-backlight * uncheck all Start-Settings-Control-Panel-Power- *set both schemes to all never These settings will be save in the registry automatially. Just a note Craggy Aero has had the 310/314 *power cable available for the Ipaq 310/314 for about 2 months. http://www.craggyaero.com/pdam.htm Richard www.craggyaero.com Thanks Richard but all these settings are lost on reset. Do you know how to make them stick? So far I reckon simplest is a script. Jim- Hide quoted text - - Show quoted text - JIm, My settings are not lost when I do a soft reset with the pen. *I am running SeeYou Mobile from the SD Card. *Maybe something in their setup from the card saves the settings. Richardwww.craggyaero.com I agree with Richard about not losing settings when booted from a card. Solid as a rock. Also I really like the airspace files from JustSoar loaded in, works very well.- Hide quoted text - - Show quoted text - Brian, What is your opinion on the visibiltiy of the 310 with direct sunlight from the rear. Craggy Aero does have a C310 power cable that charges the Ipaq 310 from the CAI 302 or PWR-5b. Tested on both. Richard www.craggyaero.com |
On Jan 30, 6:56*am, Richard wrote:
On Jan 29, 12:18*pm, brianDG303 wrote: On Jan 29, 10:22*am, Richard wrote: On Jan 29, 9:45*am, Jim White wrote: At 16:13 29 January 2009, Richard wrote: The backlight and the battery scheme can be set in the CE 5.0 control panel. Start-Settings-Control-Panel-display-backlight * uncheck all Start-Settings-Control-Panel-Power- *set both schemes to all never These settings will be save in the registry automatially. Just a note Craggy Aero has had the 310/314 *power cable available for the Ipaq 310/314 for about 2 months. http://www.craggyaero.com/pdam.htm Richard www.craggyaero.com Thanks Richard but all these settings are lost on reset. Do you know how to make them stick? So far I reckon simplest is a script. Jim- Hide quoted text - - Show quoted text - JIm, My settings are not lost when I do a soft reset with the pen. *I am running SeeYou Mobile from the SD Card. *Maybe something in their setup from the card saves the settings. Richardwww.craggyaero.com I agree with Richard about not losing settings when booted from a card. Solid as a rock. Also I really like the airspace files from JustSoar loaded in, works very well.- Hide quoted text - - Show quoted text - Brian, What is your opinion on the *visibiltiy of the 310 with direct sunlight from the rear. Craggy Aero does have a C310 power cable that charges the Ipaq 310 from the CAI 302 or PWR-5b. *Tested on both. Richardwww.craggyaero.com Richard, I really like the unit, but - I am comparing it to the IPAQ 3970, not the Cnav or the ultimate I prefer no terrain (white screen) as opposed to moving map the sunlight glare angle I think you are talking about is hard to get the way I have mine mounted. At worst the sun comes in at about 30 degrees above vertical which puts the glare angle in my lap. and, as I suspect you fly with an ultimate but own a HP310, try this- I fly with Terrain OFF but then run in SIM mode with Terrain ON while on commercial airline trips or other down time. Great way to study your past flights, and with the screen resolution of the HP it's like watching a movie. I like the way you are supporting the HP310. I'll contact you soon about getting a cable. |
HP310 and XCSoar | Jim White[_3_] | Soaring | 2 | January 14th 09 06:15 PM |
Applications soar at AFA | Otis Willie | Military Aviation | 0 | December 3rd 03 10:12 PM |
Euro-fighter? | Bryan | Military Aviation | 2 | October 29th 03 04:01 PM |
why do you soar? | Mark James Boyd | Soaring | 27 | October 21st 03 07:48 PM |
adrenaline, was why do you soar? | Robert Ehrlich | Soaring | 6 | October 13th 03 09:08 PM |
