T Tailed Libelle?
Old February 4th 09, 07:45 PM posted to rec.aviation.soaring
Tea Nott
Default T Tailed Libelle?
Glasflugel 205 Club Libelle - balsa wood core wings
http://www.sailplanedirectory.com/glasflugel.htm
At 16:03 04 February 2009, Tim Mara wrote:
that would be the Club Libelle.....really not close to a
Libelle...different
in almost every respect....different tail, fuselage, cocppit, rear hinged
canopy, Hornet wing with trailing edge dive brake....like I said, not
close
to a Libelle ..but still a nice glider...we have 2 locally I imported
several years ago..
tim
Please visit the Wings & Wheels website at www.wingsandwheels.com
"GARY BOGGS" wrote in message
I see on Wings and Wheels there is a T tailed Libelle for sale. I
don't think I've ever seen one of these before. I don't see any
reference of that configuration on the sailplane index. Can anyone
give me any info on them, like how many were made this way, and any
other relevant info?
Thanks
Boggs
www.nwskysports.com
Old February 4th 09, 08:35 PM posted to rec.aviation.soaring
Tim Mara[_2_]
absolutely not......205 had all foam cores
tim
Libelle...different
close
several years ago..
tim
Thanks
Boggs
www.nwskysports.com
Old February 4th 09, 09:30 PM posted to rec.aviation.soaring
Tea Nott
true, but only for s/n 140 onwards
http://www.streifly.de/TN205-11e.pdf
tim
Libelle...different
hinged
close
several years ago..
tim
Thanks
Boggs
www.nwskysports.com
Old February 5th 09, 12:26 AM posted to rec.aviation.soaring
Martin Gregorie[_4_]
The last balsa in the Std.Libelle, in the fin and elevator, vanished with
S/N 182 at the end of 1970. Martin Simons says the H.205 was introduced
in 1973 and the first AD is dated 1974, so its chances of containing any
balsa is about zero.
According to Simons the H.205's only vice was a sudden loss of height if
you closed the TE flaps since they added lift and lowered the stalling
speed: not a good thing to do toward the end of finals. I've seen a lot
of Std.Libelles (there are three on our field including my all-balsa
example, S/N 82) but I've never seen an H.205 in the flesh.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 5th 09, 05:04 AM posted to rec.aviation.soaring
Bruce Hoult
On Feb 5, 1:26*pm, Martin Gregorie
We had one at Wellington club from I don't know when until 1996 or
so. At the time I started to learn to fly you went from a Blanik to
the Club Libelle as your first single-seater. It was a big jump!! By
the time I got to that point the club had acquired a K6, which was an
excellent in-between step. I did about 60 or 70 hours in the Club
Libelle, including taking it to Omarama for recreational flying on my
off days when I was helping with the scoring at the 1995 Worlds.
The airbrakes did have a significant flap effect and lowered the stall
speed by about 5 knots. I don't know how anyone could have a problem
because of that though -- you're not going to get into trouble unless
you're flying at under the clean stall speed, which would be
insanity. Just fly your approach at clean stall speed plus 10 (plus
half the wind) and the variation of stall speed with brakes never
becomes an issue. Then go to full brakes as you come over the fence
or in the flare (if you weren't already) and you get excellent
deceleration in the air, an impressively low touchdown speed and short
rollout. It was just fantastic for doing approaches over trees, and I
found that a vertical dive with brakes open gave about 85 knots, which
was below the rough air speed.
By far the bigger problem at our field was people landing with partial
brake and getting flap effect but not much brake and floating all the
way down the runway.
Someone said it had Hornet wings. I don't believe so. The plan and
profile were as far as I could tell the same as the Std Libelle, with
only the airbrakes (and mounting position) different.
In theory the performance was less than a Std Libelle. I believe the
Club Libelle was deliberately dumbed down to get the best L/D down to
35 for the then Club Class rules (see Club Astir also). It had a much
roomier cockpit and fixed undercarriage. However it was pretty hard
to tell the difference. We had a Std Libelle as well and I flew one
or the other many times in company with the other and any difference
was tiny. I remember doing a final glide of about 30 km in the Club
Libelle, side by side with the Std Libelle, and we were maybe 50 ft
apart in height at the end.
Old February 5th 09, 10:15 AM posted to rec.aviation.soaring
Peter Thomas[_2_]
The Hornet is a type certificate variant of the Club Libelle, uses the
tailboom, tailplane, rudder and cockpit. The Hornet wing is a reinforced
version to take waterballast, both appear to be very similar to the
original Standard Libelle wing
The Mosquito fuz was pretty much the same and followed on to the 304 which
HPH still make
the Club Libelle is the original aircraft with the Hanel automatic control
connections
Realy nice glider to fly if you can keep the wingtips of the ground when
you launch, otherwise rather more practical than the Standard Libelle,
sensible cockpit and much more stable. seem to be popular in german
clubclass the wing is resonably rain and bug resistant, and it would seem
a resonable handicap advantage
Pete
Hornet Sn 39
Club Libelle Sn 22
At 05:04 05 February 2009, Bruce Hoult wrote:
On Feb 5, 1:26=A0pm, Martin Gregorie
if
lot
Old February 4th 09, 10:55 PM posted to rec.aviation.soaring
Andy[_1_]
The new Fork Tailed Doctor Killer Denny Piloting 182 March 24th 08 12:54 AM
Oshkosh 2004-T-Tailed Pusher Aircraft Jesse Zufall Home Built 3 February 13th 05 03:12 PM
For F-5 fans - Iran reveals new F-5 based twin-tailed Azarakhsh fighter TJ Military Aviation 1 July 11th 04 09:40 PM
