On Feb 5, 9:20*pm, Brian Whatcott wrote:
bildan wrote: .... I've looked at the ducted fan issue and it looks like they can be optimized to produce 8 -10 Lbs of thrust per HP in the 80 knot speed range. *The only airplane I know of that would benefit from that is a glider tug. 9 lb of thrust at 60 kt takes 1.6 HP Perhaps you had 30 kts in mind for 9 lb thrust per HP at 80% efficiency? Brian W Yeah, that sounds about right. I was looking at the acceleration of a glider being towed. A glider tug is one of the few airplanes where the 0 - 60 acceleration time matters since you have to get the glider up to an airspeed where the ailerons are effective enough to balance on a single wheel. 30 knots is in the middle of that range. A glider tug looks like a nearly perfect application for a ducted fan. |
bildan wrote:
On Feb 5, 9:20 pm, Brian Whatcott wrote: bildan wrote: .... I've looked at the ducted fan issue and it looks like they can be optimized to produce 8 -10 Lbs of thrust per HP in the 80 knot speed range. The only airplane I know of that would benefit from that is a glider tug. 9 lb of thrust at 60 kt takes 1.6 HP Perhaps you had 30 kts in mind for 9 lb thrust per HP at 80% efficiency? Brian W Yeah, that sounds about right. I was looking at the acceleration of a glider being towed. A glider tug is one of the few airplanes where the 0 - 60 acceleration time matters since you have to get the glider up to an airspeed where the ailerons are effective enough to balance on a single wheel. 30 knots is in the middle of that range. A glider tug looks like a nearly perfect application for a ducted fan. You set off that hunger for the likes of the Fournier RF4 which could travel a hundred miles over water on a certified (modified) VW without going into Auto-rough, after a take off using that one retractable mainwheel and wing outriggers. Memorable moments when an approach controller once queried the type (RF-4) as a military jet :-) Brian W |
On Fri, 6 Feb 2009 07:28:04 -0800 (PST), bildan
wrote: A glider tug is one of the few airplanes where the 0 - 60 acceleration time matters since you have to get the glider up to an airspeed where the ailerons are effective enough to balance on a single wheel. 30 knots is in the middle of that range. A glider tug looks like a nearly perfect application for a ducted fan. I think not. Ducted fans are horribly inefficient at low airspeeds. For that matter, they're not that great at higher speeds, either. -Dana -- "Next year in Galt's Gulch!" |
On Feb 15, 4:35*pm, Dana M. Hague wrote:
On Fri, 6 Feb 2009 07:28:04 -0800 (PST), bildan wrote: A glider tug is one of the few airplanes where the 0 - 60 acceleration time matters since you have to get the glider up to an airspeed where the ailerons are effective enough to balance on a single wheel. *30 knots is in the middle of that range. A glider tug looks like a nearly perfect application for a ducted fan. I think not. *Ducted fans are horribly inefficient at low airspeeds. For that matter, they're not that great at higher speeds, either. -Dana -- "Next year in Galt's Gulch!" Ignorance! The high bypass turbofans used on airliners is a ducted fan that is very efficient at high subsonic speeds. At speeds below 80 knots, a ducted fan is more than 4 times more efficient than an open prop. It's just in the middle speed range that the drag of the duct offsets the gain in efficiency. |
bildan wrote:
On Feb 15, 4:35 pm, Dana M. Hague wrote: On Fri, 6 Feb 2009 07:28:04 -0800 (PST), bildan wrote: A glider tug is one of the few airplanes where the 0 - 60 acceleration time matters since you have to get the glider up to an airspeed where the ailerons are effective enough to balance on a single wheel. 30 knots is in the middle of that range. A glider tug looks like a nearly perfect application for a ducted fan. I think not. Ducted fans are horribly inefficient at low airspeeds. For that matter, they're not that great at higher speeds, either. -Dana -- "Next year in Galt's Gulch!" Ignorance! The high bypass turbofans used on airliners is a ducted fan that is very efficient at high subsonic speeds. At speeds below 80 knots, a ducted fan is more than 4 times more efficient than an open prop. It's just in the middle speed range that the drag of the duct offsets the gain in efficiency. It's efficient - compared to a jet... |
On Sun, 15 Feb 2009 17:18:10 -0800 (PST), bildan
wrote: Ignorance! The high bypass turbofans used on airliners is a ducted fan that is very efficient at high subsonic speeds. At speeds below 80 knots, a ducted fan is more than 4 times more efficient than an open prop. It's just in the middle speed range that the drag of the duct offsets the gain in efficiency. A high bypass turbofan is a very different beast than a piston powered fan. Max thrust at low speeds is gotten by accelerating a lot of air a little bit (i.e. big prop, flat pitch). That's not the definition of a ducted fan. Also fan to duct clearances have to be REALLY small for best efficiency... difficult to achieve with the inherent vibrations of a piston engine without a very heavy structure. -Dana -- There are 3 kinds of people: those who can count & those who can't. |
info | sierra | Soaring | 3 | January 2nd 07 03:24 AM |
Info please | ASM | Soaring | 7 | October 21st 06 02:41 PM |
RHJ-8 Info? | Scott | Soaring | 6 | March 24th 05 09:21 PM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
