"Secret" Overvoltage Protection?
Old February 15th 09, 11:47 PM posted to rec.aviation.homebuilt
Dana M. Hague[_2_]
Default "Secret" Overvoltage Protection?
On Sat, 14 Feb 2009 21:26:23 -0800, Ron Wanttaja
The only thing I can think of is that both units have some sort of
overvoltage protection that clears itself after a time. Neither has the
classical "On" button with mechanical contacts...
Still, the units shouldn't have seen that direct generator output...they
were turned off. So what activated the overvoltage protection?
Anybody got any ideas?
I wonder if it's the same problem that I've seen on a number of
occasions with computers, which typically is the computer getting
zapped by a static discharge (the "rubbing your feet on a carpet on a
dry day" thing). The symptom is that the computer won't turn on at
all, and the fix is to unplug and/or remove the battery, then press
and hold down the power button for ten seconds or so to drain off any
static. Plug it in and/or replace the battery, and voila! The
computer works again. A transient voltage spike too fast for your
gauge to register may have done the same thing to your electronics.
-Dana
There is always a law against doing anything interesting.
"Stealth" Secret Service aircraft No Name Piloting 10 August 21st 08 12:12 AM
NASA to Release "SECRET" Survey Larry Dighera Piloting 9 November 13th 07 12:54 PM
THE BIGGEST SECRET 9/11, 7/7 and ("Operation Iraqi Freedom"? ) Mighty Thor General Aviation 0 October 27th 07 11:35 AM
THE BIGGEST SECRET 9/11, 7/7 and ("Operation Iraqi Freedom"? ) Mighty Thor Instrument Flight Rules 0 October 27th 07 11:34 AM
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [3/5] - "03 Blackhawk - a different angle on Sunday.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 07:31 PM
