Aviation Sheetmetal Work
Old February 16th 09, 11:49 PM posted to rec.aviation.homebuilt
Default Aviation Sheetmetal Work
On Feb 16, 3:00*pm, Brian Whatcott wrote:
It says it leaves a
sticky surface. That's better than nothing.....
Most of the comments are coming from people who have never used
kerosene & a flit-gun to protect their machine tools. I suggest you
try it before wandering off in all directions. Kerosene is called
'paraffin oil' for a pretty good reason: As the kerosene evaporates
it leaves behind a layer of WAX. It is the layer of wax that protects
the surfaces of your machine tools. Cleaning it up is no problem.
Simply re-spray and wipe it off.
Some times the 'old ways' are best. I think you'll find this is one
of those times.
-R.S.Hoover
Marking sheetmetal Michael Horowitz Home Built 41 September 23rd 06 05:25 PM
Conservative friends of aviation at work Paul Tomblin Instrument Flight Rules 2 April 30th 05 04:30 PM
Did your ELT work? Eric Greenwell Soaring 11 June 24th 04 02:45 PM
where's the THRILL is flying, rec.aviation.balloon,   rec.aviation.hang-gliding, rec.aviation.powerchutes, rec.aviation.soaring BW Rotorcraft 0 October 15th 03 11:42 AM
