On Feb 19, 3:23*am, Dan G wrote:
As has been said I would think some kind of novel, lightweight, glider- borne pressure cabin would be at least as likely to fail as the MIT- developed and tested suit... I suppose that's so. The art, science, and technology of pressure vessel design and fabrication is quite mature, literally centuries old. Of course, the pressure vessel containment failure at Rutan's Scaled Composites a couple years ago that killed two or three people shows that there is still something to be learned as we extend composite construction into ksi pressures. But down around the 8.5 psi pressure level like Perlan will use and like SpaceShip One and Global Flyer have already applied, there's a pretty well-established technology for making composite pressure hulls and securing the viewing ports and hatches that it takes to make them useable. As an aside, it's interesting to see that the Perlan guys are looking for 8.5 psi pressures. As another poster points out, you can get away with a lot less pressure if your pilots breathe 100% O2 in accordance with the law of partial pressures. Since air is about 1/5 oxygen, at 100% oxygen you can achieve the same partial pressure of O2 across the semipermeable membranes of the alveoli with 15/5 = ~3psi as you would get at sea level under normal circumstances. Of course, the lessons of Apollo 1 inform us that 100% oxygen can be a real fire hazard, especially at sea level pressures and when mixed with various machinery and its lubricants and also a bunch of electronics. One solution to that issue is the one they used with the X-15 program: They filled the pressure suits with 100% O2 to a few psi, and then pressurized the cabin with nitrogen to the same pressure, resulting in a limp pressure suit and a non-flammable cabin atmosphere. That's the solution I think I might have chosen for a similar mission profile to that of Perlan. Based on their 8.5psi cabin pressure, I'm guessing that what they have planned is to pressurize the cabin with regular air (20% O2, 80% N2, or maybe a bit richer) to 8.5psi, which replicates the environment you'd see down around 10,000 or 12,000 feet. They'll put the crew in David Clark 1030-series suits pressured up to the same 8.5psi as the cabin, and feed supplemental oxygen into the helmet enclosure to get blood oxygen saturation up to what you'd see at sea level. The suits will be limp and relatively easy to wear except in the case of cabin pressure failure. BTW though as I understand it the MIT suit works by applying mechanical pressure rather than inflation, so there's not a lot to fail in the first place. True enough. But when I estimated mission profiles for a Perlan-type program, it looked like you'd want to allow for a flight time of up to 12 hours. I'm not sure how the MIT suit works, but if its based on mechanical pressure I can imagine that it might be quite fatiguing after a few hours. Adding into the equation the work required to fly a rather heavy 20-meter glider with unpowered controls probably makes it a lot worse pretty fast. Thanks, Bob K. www.hpaircraft.com |
On Feb 20, 5:55*am, Bob Kuykendall wrote:
I suppose that's so. The art, science, and technology of pressure vessel design and fabrication is quite mature, literally centuries old. Of course, the pressure vessel containment failure at Rutan's Scaled Composites a couple years ago that killed two or three people shows that there is still something to be learned as we extend composite construction into ksi pressures. Building a tank that holds pressure is one thing, building one that is shrapnel resistant is something else. |
Region 12 updates | g l i d e r s t u d | Soaring | 3 | April 24th 08 10:13 PM |
More Updates | Maple1 | Aviation Photos | 0 | November 4th 07 10:29 PM |
Perlan Goes to 50,000+ | Shawn Knickerbocker | Soaring | 2 | September 1st 06 09:05 PM |
Perlan height record in Argentina | Charles Yeates | Soaring | 3 | September 1st 06 12:59 PM |
Perlan project - high wave flights | Bill Daniels | Soaring | 2 | October 20th 05 01:15 AM |
