Aviation Sheetmetal Work
Old February 20th 09, 01:26 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default Aviation Sheetmetal Work
On Sun, 15 Feb 2009 13:35:56 -0800 (PST), "
I would not dream of putting a
machine lathe in an unheated workshop where the ways might attract a
layer of rust.
So buy a Flit gun and 5 gallons of kerosene. After using the lathe,
pump up the Flit gun and give the lathe a light coating of kerosene,
then cover it with a piece of canvas that is NOT allowed to touch any
unpainted surface.
-Bob
PS -- Can't find a Flit gun? Then use one of those refillable aerosol
cans... or use an air-brush.
my lathe sits in an unheated workshop. when the workshop was an
asbestos cement shed I had moisture problems.
now I have a colourbond tin workshop, still unheated, and all I use is
shell tellus 46 on the slideways and a thick plastic sheet draped over
it. the plastic being impervious to moisture unlike the canvas.
the poms who have your snow merely put a cover over the lathe and sit
the smallest light globe they can find down in the ways. probably
about 15 watts. the heat from that keeps the lathe and the air around
it just above ambient temperature and prevents condensation.
if you are really desperate spray a lathe under plastic with CRC or
WD40 and it should be ok.
stealth pilot
Marking sheetmetal Michael Horowitz Home Built 41 September 23rd 06 05:25 PM
Conservative friends of aviation at work Paul Tomblin Instrument Flight Rules 2 April 30th 05 04:30 PM
Did your ELT work? Eric Greenwell Soaring 11 June 24th 04 02:45 PM
where's the THRILL is flying, rec.aviation.balloon,   rec.aviation.hang-gliding, rec.aviation.powerchutes, rec.aviation.soaring BW Rotorcraft 0 October 15th 03 11:42 AM
