Also, does
anyone with experience with this particular job have tips or tricks? There are about 80 srews around the frame. That's alot of drilling. I know we need special bits. Mike Be vary careful transferring your holes (sucks to do something perfectly wrong...) Buy the special acrylic bits. They have a special point that doesn't allow itself to screw into the plastic faster than the tip is shaving away the base of the hole, keeping it from punching through before the hole is there (important, otherwise it WILL crack) Drill at a lower speed and let the bit do the work. Let the bit do the work. (seriously, don't push it along) Take your time. Good Luck! (it gets more tense with each hole...) -Paul |
Blanik L23 AD | tomcatvf51 | Soaring | 0 | February 12th 09 12:52 PM |
Jim Weir, Oshkosh windscreen signs? | Dave Butler | Piloting | 7 | July 3rd 05 04:27 PM |
If you see this in your windscreen... | Jay Masino | Piloting | 6 | June 1st 05 02:36 PM |
Blanik L-23 | Duane Eisenbeiss | Soaring | 8 | April 27th 04 05:53 AM |
windscreen pollish/scratch remover | centurion_of_evil | Rotorcraft | 4 | October 3rd 03 06:49 AM |
