Blanik L13 Windscreen Replacement
Old February 25th 09, 01:47 PM posted to rec.aviation.soaring
Mike125
Default Blanik L13 Windscreen Replacement
I don't know why I didn't ckeck W&W first. Duh. Do you think it is
better to drill smaller holes and increase the size or just go for it
on the first try? Thanks for the input. BTW, this ship is on the
market (but not yet advertised on W&W). Painted w/Imron 5 years ago,
with trailer located in NJ - asking $20K.
Mike
Old February 25th 09, 02:54 PM posted to rec.aviation.soaring
bildan
on the first try? *Thanks for the input. BTW, this ship is on the
Mike
I have a set of Plexiglas drill bits I use frequently - they do a
great job on almost any plastic. I'd go for the final hole size -
just be sure it's in the right spot.
Canopy makers have figured out that that selling untrimmed, undrilled
plastic puts the cracking problem in the hands of the customer who
will be back for yet another part if they crack it.
That said, Bob K was right in that new Plexiglas is far more forgiving
than old brittle stuff. Just work carefully and avoid problems.
The L-13 canopy isn't complicated so it should be possible for a
vendor to "free blow" a replacement which should result in far better
optics than the original.
Old February 25th 09, 03:34 PM posted to rec.aviation.soaring
Mike
I just finished drilling and countersinking 60+ holes for my Open
Cirrus last week. I would pick up the old hole locations from the
frame by just drilling enough to make a slight mark, then dismount the
canopy and drill full size. the 60 deg angle of the plexiglas drill
bit seems to preclude drill wander.
In addition to all that was said so far, you should back up the holes
with a piece of wood or equal and carefully control the speed and feed
at the point the drill bit breaks through. Touch c'sink both sides of
hole. I used the bits sold at A/C spruce. If you can produce perfect
holes and countersinks on the old plexi, should have no problem with
the new stuff. Biggest problem is getting tired and not paying
attention after the first couple dozen holes. A typical flaw is a
small radial crack or chip at the back side of the hole, this can be
removed by countersink, and I would omit the screw in that location.
Lastly, the CFR title 14 part 21 has requirements for parts on type
certificated aircraft. Might want to research this before going
aftermarket.
aerodyne
Old February 25th 09, 03:47 PM posted to rec.aviation.soaring
sisu1a
on the first try? *
I like to use exact size holes I want the first time. I thought it was
safer (reduced exposure...), as well as faster, but, Tim has a great
do's and don'ts for this very thing (again, on W&W, Thanks Tim!...)
http://www.wingsandwheels.com/Installation.htm and he recommends step
drilling... Lots of really good tips there (including carefully and
lightly chamfering the edges of the holes w/a countersink bit)
-Paul
Blanik L23 AD tomcatvf51 Soaring 0 February 12th 09 12:52 PM
Jim Weir, Oshkosh windscreen signs? Dave Butler Piloting 7 July 3rd 05 04:27 PM
If you see this in your windscreen... Jay Masino Piloting 6 June 1st 05 02:36 PM
Blanik L-23 Duane Eisenbeiss Soaring 8 April 27th 04 05:53 AM
windscreen pollish/scratch remover centurion_of_evil Rotorcraft 4 October 3rd 03 06:49 AM
