You might as well give it up with this person, too. *It is more likely that you will have a real 747 qualified pilot on board, than you would likely find a simmer with the kind of "practiced" on the 747. *This one will never concede, either. -- Jim in NC Jim Believe me I'm nowhere near as bad as MX!!! Are you saying that all that I have learnt and 'practiced' bears no correlation to the systems and controls of a real 747-400 because it does. I have watched a lot of real tutorial dvds (not talking about little flyby clips on Youtube, but official licensed products on the 747 and 767 flightdecks). The position and behavior of EVERY switch whether it on the overhead panel, radio panel, Mode Control Panel, the glass cockpit, the FMC do EXACTLY as the real thing does. I know if I press 'this' the aircraft will do 'that'. A full procedural checklist MUST be followed (as per the real thing) for engine start including APU, ground power, setting pumps to Aux and Auto, turning off packs etc I know for FACT that if I was to sit down in a 747-400 flightdeck (forgetting all this emergency landing issue) I could name a huge majority of the switches, tell you where they are located and the effect they have on the flight thus giving me some form of advantage to that of a person who has never been on a flight deck OR used a simulator/game. I have openly stated it's a training aid and can successfully compliment flight training for procedures and navigation flight planning etc. I know it's not the be-all-and-end all tool that will give you a PPL after a weeks use which is were MX falls short off. I know there is a LOT more to learn about the dynamics of flight, weather systems, regulations etc etc. I know alot of real life pilots who use it and some are actually prominant members on this forum (but keep quite), there are those with PPL's, instructors, a retired A320 captain and a retired Gulf War veteran who flew rotaries in the Gulf. When I took my first flying lesson I felt I could have solo'd, laugh as you may, but the controls, throttle, pitching, descending, straight and level flight, torque effects of the prop had ALL been experienced by me in the sim so I already knew how to compensate for them. I was turning to certain bearings, climbing/descending to set altitudes, trimming the aircraft, maintaining set speeds - ALL on my first lesson and ALL picked up entirely from the sim. As I've already said we all need real lessons too but the sim CAN help as it has already done for me. Ibby |
![]() "Ibby" wrote in message ... *********************************** You might as well give it up with this person, too. It is more likely that you will have a real 747 qualified pilot on board, than you would likely find a simmer with the kind of "practiced" on the 747. This one will never concede, either. -- Jim in NC Jim Believe me I'm nowhere near as bad as MX!!! Are you saying that all that I have learnt and 'practiced' bears no correlation to the systems and controls of a real 747-400 because it does. I have watched a lot of real tutorial dvds (not talking about little flyby clips on Youtube, but official licensed products on the 747 and 767 flightdecks). The position and behavior of EVERY switch whether it on the overhead panel, radio panel, Mode Control Panel, the glass cockpit, the FMC do EXACTLY as the real thing does. I know if I press 'this' the aircraft will do 'that'. A full procedural checklist MUST be followed (as per the real thing) for engine start including APU, ground power, setting pumps to Aux and Auto, turning off packs etc I know for FACT that if I was to sit down in a 747-400 flightdeck (forgetting all this emergency landing issue) I could name a huge majority of the switches, tell you where they are located and the effect they have on the flight thus giving me some form of advantage to that of a person who has never been on a flight deck OR used a simulator/game. I have openly stated it's a training aid and can successfully compliment flight training for procedures and navigation flight planning etc. I know it's not the be-all-and-end all tool that will give you a PPL after a weeks use which is were MX falls short off. I know there is a LOT more to learn about the dynamics of flight, weather systems, regulations etc etc. I know alot of real life pilots who use it and some are actually prominant members on this forum (but keep quite), there are those with PPL's, instructors, a retired A320 captain and a retired Gulf War veteran who flew rotaries in the Gulf. When I took my first flying lesson I felt I could have solo'd, laugh as you may, but the controls, throttle, pitching, descending, straight and level flight, torque effects of the prop had ALL been experienced by me in the sim so I already knew how to compensate for them. I was turning to certain bearings, climbing/descending to set altitudes, trimming the aircraft, maintaining set speeds - ALL on my first lesson and ALL picked up entirely from the sim. As I've already said we all need real lessons too but the sim CAN help as it has already done for me. Ibby -------------------------------------------------------------------------- Really, and how was your landing? |
![]() -------------------------------------------------------------------------- Really, and how was your landing? I wasn't allowed to land on my first lesson and I would doubt anyone is but I'm sure your hoping to compare my first lesson to how I, or a complete novice with zero aircraft experience, would land a commercial airliner. Landing a small Cessna 152 (with NO AUTOPILOT) requires manual control of pitch and throttle to retain the required descent rate and localiser following. Landing an airliner can all be done via the Autoland system with the press of a few buttons. It doesn't have to be done manually, you do NOT have to control the yoke or touch the thrust levers until on the ground. MOST real life landings are done with this method with the pilot perhaps only disconnecting the autopilot and autothrottle systems a few hundred feet above ground level when the aircraft is already established and configured for the descent path i.e. descent rate, airspeed and lateral position. His hands will of course remain on the control column and thrust levels in case he needs to press the TOGA button on the thrust lever in case of a Go-Around etc. If a novice or even a PPL pilot had to hand fly an airliner and land it yes it would more than likely result in disaster but less likely with the highly technical automation systems available today in the Next Generation Boeings. Ibby |
![]() "Ibby" wrote in message ... -------------------------------------------------------------------------- Really, and how was your landing? I wasn't allowed to land on my first lesson and I would doubt anyone is but I'm sure your hoping to compare my first lesson to how I, or a complete novice with zero aircraft experience, would land a commercial airliner. Landing a small Cessna 152 (with NO AUTOPILOT) requires manual control of pitch and throttle to retain the required descent rate and localiser following. Landing an airliner can all be done via the Autoland system with the press of a few buttons. It doesn't have to be done manually, you do NOT have to control the yoke or touch the thrust levers until on the ground. MOST real life landings are done with this method with the pilot perhaps only disconnecting the autopilot and autothrottle systems a few hundred feet above ground level when the aircraft is already established and configured for the descent path i.e. descent rate, airspeed and lateral position. His hands will of course remain on the control column and thrust levels in case he needs to press the TOGA button on the thrust lever in case of a Go-Around etc. If a novice or even a PPL pilot had to hand fly an airliner and land it yes it would more than likely result in disaster but less likely with the highly technical automation systems available today in the Next Generation Boeings. Ibby Oh brother, Mx Jr. |
![]() Oh brother, Mx Jr.- Hide quoted text - - Show quoted text - God man grow up. What do you think the point of an autopilot, autolanding and autothrottle systems are for?? To make control of an airliner easier for the flightcrew whether it an Airbus, Boeing and MD and even a Cirus, Pipers etc. As a Cessna 152 has NONE of these systems they have to be flown by hand and landed by hand. An airliner does NOT HAVE to be hand flown - in REAL LIFE and RARELY is. Read some books, watch some videos and wise up you lot. I was DEFENDING the skill required in hand flying a light aircraft but it just seems to literally 'fly' over a lot of heads here in your blindness for what you are reading. There is nothing wrong with my previous post. I know what is required in a real aircraft to control airspeed, attitude, descents and climbs because I HAVE bloody flown a REAL aircraft but in the UK you are not permitted to land or take off on your first lesson which I was commenting on. Ibby |
![]() "Ibby" wrote in message ... You grow up dumb ass. Just exactly like MX, in your ignorance and inexperience you missed the whole point. |
![]() You grow up dumb ass. Just exactly like MX, in your ignorance and inexperience you missed the whole point. So how can someone who HAS physically controlled a real aircraft (me) be compared to MX who HASN'T controlled a real aircraft???????????? The Sim isn't perfect but it DOES teach (especially with commercial addons) elements of flight and navigation. It helped me understand what was required on my first flight in a Cessna 152. Infact the REAL aircraft was EASIER to roll, pitch and trim than the sim. If my comments are so stupid about landing an airliner then YOU describe to ME the process involved in doing so!! Why do airports have ILS's, why do they have DME etc, for navigation and automated flight. Why does the FMC have a full SID STAR database if the pilot was just going to hand fly them based on his charts? Do commercial airlines use the autopilot - yes they do from 500ft after takeoff to potential touchdown. An airline pilot would NEVER hand fly an entire route from takeoff, cruise to landing as per your assumptions. Doing so WOULD be very difficult and I'd freely give credit to a pilot that could do it but they use all systems available to ease their workload - FACT. Ask a REAL airline pilot, not a GA pilot. Infact ask them too, if you have an autopilot on your aircraft - DO you use it and why do you use it if not to make the flight easier? You hardly use it 'for the challenge' Ibby |
Hi,
In article , wrote: but in the UK you are not permitted to land or take off on your first lesson which I was commenting on. I know of no regulation in the UK that prevents it. If there were one, I would therefore know of several people in the UK that have breached it. Andy (UK PPL) |
*It doesn't have
to be done manually, you do NOT have to control the yoke or touch the thrust levers until on the ground. *MOST real life landings are done with this method ??? Most? Certainly not. -- Duncan Duncan So do YOU believe a pilot of a 737 or 747 hand flys an entire STAR approach, captures the ILS localiser and glideslope, whilst keeping critical control of his altitude and reducing airspeed and deployment of flaps ALL by hand. Commercial pilots use the autopilot's approach system at the very LEAST to get established on the localiser and control the descent on the glideslope whilst they manually reduce the desired speed (still under the autopilots autohrottle control) on the Mode Control Panel Watch this video of the final stages of a 747-400 approach and landing into San Fransisco. This is a typical landing. The pilot disconnected the autopilot at a few hundred feet but this aircraft and runway 28L could have enabled him to perform a full autoland. http://www.youtube.com/watch?v=5ShBOtPiuNM As you can clearly witness the majority of the input required by the pilot to maintain flight, approach and landing is via the MCP on the glareshield Ibby Ibby |
Apology re mxsmanic | terry | Piloting | 96 | February 16th 08 05:17 PM |
Mxsmanic : Your results are in | Mayo Clinic | Piloting | 13 | May 24th 07 02:01 PM |
I saw Mxsmanic on TV | Clear Prop | Piloting | 8 | February 14th 07 01:18 AM |
Mxsmanic | gwengler | Piloting | 30 | January 11th 07 03:42 AM |
Getting rid of MXSMANIC | [email protected] | Piloting | 33 | December 8th 06 11:26 PM |
