#11
"Paul Remde" wrote:
I was planning on including a parachute so it won't land hard if all the balloons pop, I presume the parachute (or perhaps a simple cloth drogue?) would already be deployed - it'd hang limp (most of the time) till needed. But I don't want to do it if it is not safe, or not legal, etc. I don't want to "take my chances" that it will be safe - unless the risks are miniscule. As far as I can tell it can be done legally since a SPOT allegedly weighs only 209 gms (~7.4 oz) and the smallest surface is ~4.7 in^2, or ~1.6 oz/in^2 -- well under the 3 oz/in^2 specified by 101.1(a)(4)(i). (Numbers extracted from the specs on the SPOT web site.) I'd be mindful of 101.7 when determing when and where to launch. I'd launch in clear weather and use 101.33 as a guideline (even though it isn't applicable to such a small balloon.) So if the worst happens I'd have shown intent to not launch in a hazardous manner. I don't know what the probability is of it causing an accident, but I'd guestimate it is indeed miniscule. Infinitesimal probability of a collision, multiplied by a small amount of damage, multiplied by the probability that small amount of damage yields fatalities. Bottom line is I would not personally have any issue if such a balloon were launched while I was in any sort of aircraft in the same area. |
On Mar 2, 11:18*pm, Jim Logajan wrote:
I believe you've misread the regulations by not reading 101.1. That is where it states: True, I missed that. It would appear that only 101.7 is applicable given the mass of SPOT. That looks like an FAA wild card to be played anytime they want. Andy |
Thank you everyone for the interesting and informative posts.
While it may be legal and would be safe 99.999% of the time, I think I'll scrap the idea. I would never want it to cause any issues. Good Soaring, Paul Remde "Jim Logajan" wrote in message .. . Andy wrote: On Mar 2, 4:24 pm, Jim Logajan wrote: Why not? Last I checked, balloon launchers had an equal right to use the public airspace as anyone else. (In the U.S. part 101 contains the regulations pertinent to safe operations of balloons.) The operation described by the OP does not appear to be compliant with 101 subpart D. Perhaps he left out all the details that would make it compliant. Perhaps he'd post again telling us how he intends to comply. I believe you've misread the regulations by not reading 101.1. That is where it states: "This part prescribes rules governing the operation in the United States, of the following: ... (4) Except as provided for in 101.7, any unmanned free balloon that ... " So the "applicability" in 101.1 specifies the criteria that must be met for _any_ of the remainder of Part 101 to be applicable. Now in 101.31 in "Subpart D" it states "This subpart applies to the operation of unmanned free balloons." But that subpart _isn't_ applicable if the conditions in 101.1 aren't met. (Because it is a _subpart_.) If it were applicable, then according to 101.33(d), anyone releasing something as small as a helium party balloon in a town would be in violation of the FARs. When properly read, according to 101.1 any unmanned free balloon under 4 lbs of payload that presents suitably large surface areas is not subject to any Subparts of Part 101. I've been startled by party balloons when flying power planes in the Phoenix area. They wouldn't hurt if I hit one. I don't relish the idea of getting a spot through the prop or windshield. I hate to break it to you, but you are more likely to run into a bird than a balloon of any sort. Or even another manned aircraft. Maybe that's because unmanned balloon operations are regulated by 101 subpart D. The flight of birds is, to the best of my knowledge, unregulated. A SPOT weighs 209g. It has a density less than water (it's designed to float.) Might dent the prop or crack the windshield, but can't see it causing a serious hazard. (You can save the prop from significant damage but shutting off the engine and gliding. ;-)) And as I said, Subpart D of Part 101 isn't applicable to all unmanned balloon operations. Small balloons meeting the criteria of 101.1(4) are not covered by Part 101. The balloon the OP proposes could no doubt be easily made to comply. And since the OP is a pilot would no doubt perform the operation as safely as feasible. |
On Mar 3, 8:09*am, "Paul Remde" wrote:
Thank you everyone for the interesting and informative posts. While it may be legal and would be safe 99.999% of the time, I think I'll scrap the idea. *I would never want it to cause any issues. Good Soaring, Paul Remde "Jim Logajan" wrote in message .. . Andy wrote: On Mar 2, 4:24 pm, Jim Logajan wrote: Why not? Last I checked, balloon launchers had an equal right to use the public airspace as anyone else. (In the U.S. part 101 contains the regulations pertinent to safe operations of balloons.) The operation described by the OP does not appear to be compliant with 101 subpart D. *Perhaps he left out all the details that would make it compliant. *Perhaps he'd post again telling us how he intends to comply. I believe you've misread the regulations by not reading 101.1. That is where it states: "This part prescribes rules governing the operation in the United States, of the following: ... (4) Except as provided for in 101.7, any unmanned free balloon that ... " So the "applicability" in 101.1 specifies the criteria that must be met for _any_ of the remainder of Part 101 to be applicable. Now in 101.31 in "Subpart D" it states "This subpart applies to the operation of unmanned free balloons." But that subpart _isn't_ applicable if the conditions in 101.1 aren't met. (Because it is a _subpart_.) If it were applicable, then according to 101.33(d), anyone releasing something as small as a helium party balloon in a town would be in violation of the FARs. When properly read, according to 101.1 any unmanned free balloon under 4 lbs of payload that presents suitably large surface areas is not subject to any Subparts of Part 101. I've been startled by party balloons when flying power planes in the Phoenix area. They wouldn't hurt if I hit one. I don't relish the idea of getting a spot through the prop or windshield. I hate to break it to you, but you are more likely to run into a bird than a balloon of any sort. Or even another manned aircraft. Maybe that's because unmanned balloon operations are regulated by 101 subpart D. The flight of birds is, to the best of my knowledge, unregulated. A SPOT weighs 209g. It has a density less than water (it's designed to float.) Might dent the prop or crack the windshield, but can't see it causing a serious hazard. (You can save the prop from significant damage but shutting off the engine and gliding. ;-)) And as I said, Subpart D of Part 101 isn't applicable to all unmanned balloon operations. Small balloons meeting the criteria of 101.1(4) are not covered by Part 101. The balloon the OP proposes could no doubt be easily made to comply. And since the OP is a pilot would no doubt perform the operation as safely as feasible.- Hide quoted text - - Show quoted text - This is a bit off topic, but I found this neat project while googling for balloon info yesterday. http://www.members.shaw.ca/sonde/ These guys launched an RC glider to 65k' via a balloon. Cool Stuff! Pete |
vontresc wrote:
This is a bit off topic, but I found this neat project while googling for balloon info yesterday. http://www.members.shaw.ca/sonde/ These guys launched an RC glider to 65k' via a balloon. Cool Stuff! What a fascinating project! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Mar 3, 7:22*pm, Eric Greenwell wrote:
vontresc wrote: This is a bit off topic, but I found this neat project while googling for balloon info yesterday. http://www.members.shaw.ca/sonde/ These guys launched an RC glider to 65k' via a balloon. Cool Stuff! What a fascinating project! -- This might be an excellent and cheap way to have a local temp trace! ![]() Lars |
for balloon info yesterday. http://www.members.shaw.ca/sonde/ These guys launched an RC glider to 65k' via a balloon. Cool Stuff! Actually 20k' cooler, it was launched to 85k'! -Paul |
On Mar 2, 11:03*pm, Jim Logajan wrote:
"Paul Remde" wrote: I was planning on including a parachute so it won't land hard if all the balloons pop, I presume the parachute (or perhaps a simple cloth drogue?) would already be deployed - it'd hang limp (most of the time) till needed. But I don't want to do it if it is not safe, or not legal, etc. *I don't want to "take my chances" that it will be safe - unless the risks are miniscule. As far as I can tell it can be done legally since a SPOT allegedly weighs only 209 gms (~7.4 oz) and the smallest surface is ~4.7 in^2, or ~1.6 oz/in^2 -- well under the 3 oz/in^2 specified by 101.1(a)(4)(i). (Numbers extracted from the specs on the SPOT web site.) I'd be mindful of 101.7 when determing when and where to launch. I'd launch in clear weather and use 101.33 as a guideline (even though it isn't applicable to such a small balloon.) So if the worst happens I'd have shown intent to not launch in a hazardous manner. I don't know what the probability is of it causing an accident, but I'd guestimate it is indeed miniscule. Infinitesimal probability of a collision, multiplied by a small amount of damage, multiplied by the probability that small amount of damage yields fatalities. Bottom line is I would not personally have any issue if such a balloon were launched while I was in any sort of aircraft in the same area. With the right size balloon you might be able to fit the Spot inside the balloon envelope. I'm guessing that would reduce the chances of it striking anything directly as the upwash ahead of any moving object would tend to deflect it - plus you get a built-in airbag. Anyone who's seen a balloon on a freeway can understand that. As to the turbofan scenario - jet engines are designed to eat birds up to 5 lbs (as Capt Sully found out to his dismay, geese are bigger). I can't imagine a Spot is any tougher than a duck. You'd get some damage I'd bet, but I doubt it'd be catastrophic. With a little effort you could balance things so the balloon didn't get into the Class A. For instance a small pinhole would allow helium out at a rate to ensure that the balloon didn't get too high or go too far - how long a chase do you want anyway? If you release it away from and downwind of any significant terminal areas your odds of hitting anything are infinitesimal. Given all the time lags associated with Spot messages I doubt you'll be able to track the thing close enough to actually see it until it's already on the ground. Also, you'd have to worry about lakes and maybe forests as possible unhappy endings. Without a good wide area wireless connection you will have trouble tracking it in real time from the road, so you'll have to wait for it to land, get a fix and go find it. Overall it sounds a bit like you've run out of ways to entertain yourself over the winter. ;-) 9B |
On Mar 4, 4:14*pm, Eric Greenwell wrote:
wrote: Bottom line is I would not personally have any issue if such a balloon were launched while I was in any sort of aircraft in the same area. With the right size balloon you might be able to fit the Spot inside the balloon envelope. I'm guessing that would reduce the chances of it striking anything directly as the upwash ahead of any moving object would tend to deflect it - plus you get a built-in airbag. Anyone who's seen a balloon on a freeway can understand that. As to the turbofan scenario - jet engines are designed to eat birds up to 5 lbs (as Capt Sully found out to his dismay, geese are bigger). I can't imagine a Spot is any tougher than a duck. You'd get some damage I'd bet, but I doubt it'd be catastrophic. With a little effort you could balance things so the balloon didn't get into the Class A. For instance a small pinhole would allow helium out at a rate to ensure that the balloon didn't get too high or go too far - how long a chase do you want anyway? If you release it away from and downwind of any significant terminal areas your odds of hitting anything are infinitesimal. Given all the time lags associated with Spot messages I doubt you'll be able to track the thing close enough to actually see it until it's already on the ground. Also, you'd have to worry about lakes and maybe forests as possible unhappy endings. Without a good wide area wireless connection you will have trouble tracking it in real time from the road, so you'll have to wait for it to land, get a fix and go find it. Assuming you mean "wireless" as used for computer communication, that may not be a limitation: SPOT service can be set to send text messages with the coordinates to your cell phone, which usually has a lot more coverage. The truly determined could rent/borrow a satellite phone for the day of the flight. SPOT floats - tow a boat with your retrieve vehicle! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" You are going to want to hang the spot under the balloon some distance, maybe on a little platform so the thing can be oriented pointing roughly up for best GPS reception (not really an issue) and best GlobalStar coverage (more of an issue). Eric's idea of SMS message to an Iridium phone sounds sexy if you are really remote. However SPOTcast/tracking only works to the internet and won't transmit position data to SMS or email. So you will have to modify the SPOT to "press" the OK button. Very simple to hack for somebody with electronics skill, but encouraging this might annoy SPOT, Inc. You'd need to find out if SPOT supports SMS to Iridium numbers. Many places do, people even twitter to them etc. My perception is that many of the SPOT position delays that Andy mentioned are associate with the SPOT web pages, SMS and email messages may get thought faster. It would be great to know if anybody has hard data on this. The problem on landing is the SPOT is unlikely to land upright oriented with sight of the satellites so the best you may get is a 10 minute old position fix which may or may not be enough to find the unit. The idea of launching some balloons with small cameras etc on them as a project with kids is quite interesting. Darryl |
Spot deal, today only, buy service get a free Spot | Tim Taylor | Soaring | 3 | December 1st 08 10:30 PM |
Al(Race Card) Sharpton and Jesse (Race Warlord) Jackson | GetErDone | Piloting | 1 | December 8th 07 09:22 PM |
I need materials to make helium balloons. | John Doe | Home Built | 19 | December 7th 04 05:51 AM |
Best small balloon material for containing helium? | John Doe | Home Built | 7 | December 3rd 04 09:42 PM |
How much weight will 15 ft.³ of helium lift? | John Doe | Home Built | 1 | December 3rd 04 04:07 PM |
