On Mar 4, 11:21*am, Mxsmanic wrote:
Musicrab writes: What's the Boeing 737-800 flight manual say about what to do when left and right hand altimeters don't match? It surely points out that working altimeters are required for an automated approach. *The airline flew with broken altimeters, and after tempting fate several times, it finally caught up with them. You are talking about standard altitude altimeters or RAs? From reading the it appears that the concern is about the RA's not the altimeters. No plane is going to flare as a result of a reading from a pressure altimeter. -Robret |
Robert M. Gary writes:
You are talking about standard altitude altimeters or RAs? RAs. One of them had malfunctioned on several previous flights, according to the flight data recorders. The airline had not bothered to fix it, even though it is essential for autoland (perhaps the airline expected its pilots to be alert and hard-working enough to fly landings by hand, although that's not really an excuse). No plane is going to flare as a result of a reading from a pressure altimeter. But it probably will if the RA says that it's 7 feet below the runway. |
![]() "Mxsmanic" wrote in message ... Robert M. Gary writes: You are talking about standard altitude altimeters or RAs? RAs. One of them had malfunctioned on several previous flights, according to the flight data recorders. The airline had not bothered to fix it, even though it is essential for autoland (perhaps the airline expected its pilots to be alert and hard-working enough to fly landings by hand, although that's not really an excuse). No plane is going to flare as a result of a reading from a pressure altimeter. But it probably will if the RA says that it's 7 feet below the runway. What a dumb ass. |
Mxsmanic wrote:
Robert M. Gary writes: You are talking about standard altitude altimeters or RAs? RAs. One of them had malfunctioned on several previous flights, according to the flight data recorders. The airline had not bothered to fix it, even though it is essential for autoland (perhaps the airline expected its pilots to be alert and hard-working enough to fly landings by hand, although that's not really an excuse). Babble. Where is your data on airline SOP with regard to doing an autoland all the way to the ground? Where is your data on the percentage of landings that do an autoland all the way to the ground? -- Jim Pennino Remove .spam.sux to reply. |
Mxsmanic wrote:
writes: Where is your data on airline SOP with regard to doing an autoland all the way to the ground? Every autoland is all the way to the ground. Where in the world did you come up with that rediculous statement? What percentage of landings are done with autoland and what is your source of information? -- Jim Pennino Remove .spam.sux to reply. |
Mxsmanic wrote:
writes: Where in the world did you come up with that rediculous statement? If the autopilot isn't taking the aircraft to touchdown, it's not an autoland. That's what autoland means: automatic landing. No control inputs required. Autopilot engaged all the way up to touchdown and beyond. Yeah, right. The word "autoland" refers to a system in aircraft. If you are going to post to real aviation groups, learn the language of real aviation. It is routine to turn on autoland during approach and turn it off just before touchdown. -- Jim Pennino Remove .spam.sux to reply. |
Manchester (EGCC) Turkish Airlines TC-JRA | Andrew B | Aviation Photos | 0 | May 29th 08 08:01 PM |
ATC radio for cabin on airlines besides United? | [email protected] | Piloting | 1 | May 1st 06 10:48 PM |
Los Angeles radio tower crash kills 2 | Paul Hirose | Piloting | 178 | August 6th 05 03:46 PM |
Thunderbird pilot found at fault in Mountain Home AFB crash | Ditch | Military Aviation | 5 | January 27th 04 01:32 AM |
Recommendation for Radio, transponder and Altimeter | Ron Natalie | Home Built | 0 | July 8th 03 03:40 PM |
