Throttle or Prop control first after takeoff
Old March 6th 09, 08:52 PM posted to rec.aviation.owning
Mark Hansen
Default Throttle or Prop control first after takeoff
On 03/06/09 12:48, Robert M. Gary wrote:
On Mar 6, 11:37�am, cyberflyrg
We are having a argument about what is better to do after takeoff. Some
mechanics say pull power back first after takeoff and then adjust prop
speed after, my mechanic says prop speed back first and then manifold
pressure after that.
What the "right" thing to do that will not damage the prop governor and
motor??? You opinion is greatly appreciated..
PS: this is in reference to my 1965 210.
Refer to your POH when in doubt. However, the rule of thumb most of us
fly under is that when reducing power you work left to right
(throttle, then prop, then mixture). When increasing power you work
the other way (mixture, prop, then throttle). This sequence ensures
you don't lug the engine. If your airframe POH or engine manual says
otherwise, go for it.
-Robert, CFII
Yes but right after take off, don't people reduce the rpm just a bit
(to 2500 in the Archer I flew) to reduce noise?
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old March 6th 09, 08:55 PM posted to rec.aviation.owning
Robert M. Gary
I don't because I personally don't believe in touching power below
1000 feet. However, a lot of aircraft require a power reduction for
sustained climb or noise. For instance in the C-182T you pull power
and fuel flow back to the top of the green, etc. However, I still
don't touch anything below 1000 feet, even coming out of SMO in my
Mooney (where the noise nazi's live)
-Robert
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Head wind takeoff into rising hills, or crosswind takeoff to open space ?? P S Piloting 7 September 20th 07 07:29 PM
Question on Baron 58 prop control Mxsmanic Piloting 62 December 3rd 06 05:26 AM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
Hydraulic CS prop converting to Adjustable prop? Scott VanderVeen Home Built 0 December 5th 03 05:54 PM
