On Mar 8, 10:03*am, Brad wrote:
I know this has come up before in RAS. But thought I would bring up the subject again. For a club looking at long term projections, which at some point will include either sticking a "new" engine on a Pawnee or getting rid of it, does it make sense to start evaluating getting a 2 place motorglider to serve as a tug and also as a touring/training tool? Can a MG tug pull a loaded 2 place Blanik on a standard day at SL, from a 1800' grass strip? Or perhaps such a tug could be used to tow the members single place ships, and the heavier/ 2-place ships stow behind the clubs remaining pawnee? We are blessed with 3 towplanes in our club, there are upcoming factors that will/are causing us to look at several different scenarios and am wondering if tossing a MG into the mix might be one such solution. Brad You don't say what type of motorglider you are thinking of (seems even sustainers count as motorgliders if you believe Soaring Magazine) But having said that there is not one touring (i.e. non pylon style) motorglider I can think of that I'd want to tow behind in any sailplane, well certainly not a two place glider. A Kstana or something with a big engine might be able to tow a light glider but it is not going to touch a good Pawnee or simmilar and so what then you are left with a not great tug and a not very good XC trainer (or XC anything). But I don't understimate how the appeal of being flexible/ multi-purpose and doing something clever/different might just suck people in... As a self-launch motorglider owner in general I tend to think good XC trainers do *not* have motors. Think Duo Discus or DG-1000S class two seater. Motorgliders are compelx and expensive to operate and most have more vices than a modern two-seater, so you are not going to let newer pilots (the very ones you want to be encouraging to go XC) go fly them solo etc. And if you only do dual in that glider and send them solo in an a conventional glider you are sending the XC student/ mentoree a very bad signal. Motorgliders can be great for some things, inluding orientatiion flights, etc. but you can also do those in a two place power plane. Darryl |
We spent quite some time looking at this. We currently have 2xPawnee 235's
and a Super Cub 180. We also have a Falke 2000 motorglider. Normally we only need on tug, except on busy periods when we occationally need two. The motorglider is underutilised, so the idea of a motorglider that can tow seemed attractive. To keep operations simple, we assumed that one of our Pawnees would be servicable, so that the Motorglider could tow single seaters (which is usually the cause of our peak demand), and therefore the utilisation of the motorised fleet would increase and we would need one less aircraft. Initially we evaliated the 100hp fixed pitch Rotax Falke. It did tow, but seemed a bit marginal from our operation. Also it needed careful management of the engine temperature to avoid long term issues. Then we looked at the Grob 109 Turbo. This gives about 130hp for the initial takeoff and was substantially better than the Falke whilst still delivering economy which was more than two times better than the Pawnee. I would say that it was the best we looked at and also better than the super dimona, which we also studied briefly. In the UK a G109T has been towing from a grass strip for almost two years now, towing a variety of single and two seat gliders (including duo's etc) and has very few problems, I understand. The concept is certainly worth considering. In the meantime, we continue to watch developments, as well as plans to re-engine Pawnees with 230hp Diesel Engines. Craig Lowrie, UK At 17:28 08 March 2009, Darryl Ramm wrote: On Mar 8, 10:03=A0am, Brad wrote: I know this has come up before in RAS. But thought I would bring up the subject again. For a club looking at long term projections, which at some point will include either sticking a "new" engine on a Pawnee or getting rid of it, does it make sense to start evaluating getting a 2 place motorglider to serve as a tug and also as a touring/training tool? Can a MG tug pull a loaded 2 place Blanik on a standard day at SL, from a 1800' grass strip? Or perhaps such a tug could be used to tow the members single place ships, and the heavier/ 2-place ships stow behind the clubs remaining pawnee? We are blessed with 3 towplanes in our club, there are upcoming factors that will/are causing us to look at several different scenarios and am wondering if tossing a MG into the mix might be one such solution. Brad You don't say what type of motorglider you are thinking of (seems even sustainers count as motorgliders if you believe Soaring Magazine) But having said that there is not one touring (i.e. non pylon style) motorglider I can think of that I'd want to tow behind in any sailplane, well certainly not a two place glider. A Kstana or something with a big engine might be able to tow a light glider but it is not going to touch a good Pawnee or simmilar and so what then you are left with a not great tug and a not very good XC trainer (or XC anything). But I don't understimate how the appeal of being flexible/ multi-purpose and doing something clever/different might just suck people in... As a self-launch motorglider owner in general I tend to think good XC trainers do *not* have motors. Think Duo Discus or DG-1000S class two seater. Motorgliders are compelx and expensive to operate and most have more vices than a modern two-seater, so you are not going to let newer pilots (the very ones you want to be encouraging to go XC) go fly them solo etc. And if you only do dual in that glider and send them solo in an a conventional glider you are sending the XC student/ mentoree a very bad signal. Motorgliders can be great for some things, inluding orientatiion flights, etc. but you can also do those in a two place power plane. Darryl |
Hi Craig.
I landed out at Sackville Farm in the 15s last year and was ear bashed for about an hour by Tim on how good the Grob109T was for towing. Unfortunately he was not able to give me a tow out as the undercarriage had been damaged and it was in repair. I think you need a very good surface to operate off and that the Grob (and probably similar SLMGs) are too lightly built for anything more than occasional tugging. At BGC our tugs do c. 2000 cycles p.a. each. I doubt that a MG would stay that pace. Jim At 18:00 08 March 2009, Craig Lowrie wrote: |
On 9 Mar 2009 08:30:04 GMT, Jim White wrote:
I think you need a very good surface to operate off and that the Grob (and probably similar SLMGs) are too lightly built for anything more than occasional tugging. Their strength is completely sufficient for towing all dyearlong - lots of clubs in Germany are using motorgliders as their primary tug plane. The only problem is that they usually need a long grass or a paved runway to be safe. At BGC our tugs do c. 2000 cycles p.a. each. I doubt that a MG would stay that pace. No problem at all for a motorglider. ![]() |
In message , Jim White
writes Hi Craig. I landed out at Sackville Farm in the 15s last year and was ear bashed for about an hour by Tim on how good the Grob109T was for towing. Unfortunately he was not able to give me a tow out as the undercarriage had been damaged and it was in repair. I think you need a very good surface to operate off and that the Grob (and probably similar SLMGs) are too lightly built for anything more than occasional tugging. I also landed there last year and got a ride with Tim in his Grob. He also did a tow for another arrival from Shennington who wasn't feeling too euphoric to fly back. Apparently the same one visited my own club the previous year to demonstrate how good it was a towing, and they gave it our heaviest two-seater with one of our heaviest crew combos, and it got them off the ground. I believe our aerotow strip is just shy of 800m, and it rises slightly at the end they took off towards. So far as I know the Grob performed admirably. At BGC our tugs do c. 2000 cycles p.a. each. I doubt that a MG would stay that pace. -- Surfer! Email to: ramwater at uk2 dot net |
Seeking towplanes for Region 9 | [email protected] | Soaring | 0 | May 17th 06 12:03 AM |
US:Restricted Towplanes | Judy Ruprecht | Soaring | 8 | November 5th 04 11:27 PM |
Standard Nationals Need Towplanes | C AnthMin | Soaring | 5 | July 14th 04 12:46 AM |
Take-upReels on Towplanes | Nyal Williams | Soaring | 9 | April 21st 04 12:39 AM |
Helicopters and Towplanes | Burt Compton | Soaring | 6 | September 11th 03 05:21 PM |
