"Damo" writes:
"John Schilling" wrote in message ... (George William Herbert) writes: John Schilling wrote: Likewise, if your idea is that it doesn't matter how easy an individual missile is to find and kill because you are going to saturate US/NATO style air defenses with numbers, you don't match it against the present standard of an F-15 with four each AMRAAMs and Sidewinders but against an F-22 packed to the limit with air-to-air Stingers; fourty-five stowed kills at 0.8 Pk per shot, if my math is correct. I was under the impression (mistaken?) that the F-22 can only carry 4 air-to-air missiles, if it carries more it loses what stealth it had and you might as well send in F-15s?? The F-22 carries, internally and stealthily, six AIM-120 AMRAAMs and two AIM-9 Sidewinders. It can carry four missiles (2 ea AIM-9 and AIM-120) *and* two JDAMs internally, as a self-escorting strike aircraft. That may be where you got the four missiles bit from. But AMRAAMS are gross overkill against the sort of cruise missile being postulated here. You only need the long range, midcourse guidance, high energy and terminal maneuverability if the target is going to evade and/or shoot back, or if it's moving fast enough that even a supercruising F-22 can't engage closely. Against minimal cruise missiles, an air-to-air Stinger is more than enough. Yes, the Stinger has an air-to-air variant, and yes, the seeker will lock onto the exhaust of a small piston engine. And you can pack eight of them in the weight and volume envelope of an AIM-120, or four for an AIM-9. Fifty-six total in an F-22, without compromising stealth or supercruise[1]. This is not to say you could do it tomorrow. You'd have to design 4- and 8-rail extendable launchers, and integrate the missiles and launchers with the F-22 weapons control system. But it could be done faster than the hypothetical opposition could field their cruise missile swarms, at which point American fighter pilots get to have more fun than they've had since the Marianas Turkey Shoot. [1] A competent adversary not irrationally wedded to the Great Cruise Missile Swarm tactic would keep just enough MiG-29s or the like in inventory that American pilots would reasonably insist on a couple of AMRAAMs at all times Just In Case. So maybe fourty Stingers and two AIM-120s would be a more realistic loadout for this scenario, ~34 stowed kills at 0.8 Pk. Probably a couple more with the gun :-) -- *John Schilling * "Anything worth doing, * *Member:AIAA,NRA,ACLU,SAS,LP * is worth doing for money" * *Chief Scientist & General Partner * -13th Rule of Acquisition * *White Elephant Research, LLC * "There is no substitute * * for success" * *661-951-9107 or 661-275-6795 * -58th Rule of Acquisition * |
Australia F111 to be scrapped!! | John Cook | Military Aviation | 35 | November 10th 03 11:46 PM |
