SPOT Tracking For 2009 Senior Contest at Seminole Lakes, Florida
Old March 12th 09, 12:32 PM posted to rec.aviation.soaring
ContestID67[_2_]
Default SPOT Tracking For 2009 Senior Contest at Seminole Lakes, Florida
Mark - Thanks but....I couldn't get it to work with IE 6 (yeah, I
know). I just get a page showing raw HTML code. It does work with
FireFox 3, Safari 3.2.2 and Chrome 1. FYI and hope you can fix the
issue with IE 6 as there is alot of installed base. My $0.02.
Thanks again.
PS - The direct link imbedded in the XML works fine;
http://maps.google.com/maps/ms?ie=UT...p; output=kml
- John
Old March 12th 09, 03:34 PM posted to rec.aviation.soaring
MarkHawke7
Hi John,
Strange. I just tried it with IE version 6.0.3790.1830 and it worked
just fine. You have to have javascript enabled or it definitely won't
work. Is javascript access perhaps turned off with yours? I'll try
it with a couple more IE6's around our lab if I can find any. In
general Javascript is MUCH faster (as in 2 times or more) in Firefox,
Chrome and and probably Safari as well. I would HIGHLY suggest one of
those. Also, thanks for letting me know that it does work Safari. I
don't have access to a Mac to test with.
As for that link, it will only give you the Task.
Later!
-Mark
know). *I just get a page showing raw HTML code. *It does work with
FireFox 3, Safari 3.2.2 and Chrome 1. *FYI and hope you can fix the
issue with IE 6 as there is alot of installed base. * My $0.02.
Thanks again.
PS - The direct link imbedded in the XML works fine;http://maps.google.com/maps/ms?ie=UT...n&oe=UTF8&msa=...
- John
SPOT tracking test at 2009 Seniors Frank[_1_] Soaring 0 February 22nd 09 03:24 AM
SPOT tracking for 2009 contests? Frank[_1_] Soaring 24 February 15th 09 05:21 AM
Spot tracking consistency Bill Daniels Soaring 3 June 24th 08 10:25 PM
SPOT - 6 months free tracking 5Z Soaring 1 May 29th 08 04:26 PM
Glider tracking - Spot etc... Bill Daniels Soaring 5 January 3rd 08 05:32 AM
