motorgliders as towplanes
Old March 12th 09, 09:35 PM posted to rec.aviation.soaring
Mike the Strike
Default motorgliders as towplanes
On Mar 12, 1:09*pm, Bruce wrote:
Bruce wrote:
On Mar 8, 1:03 pm, Brad wrote:
Can a MG tug pull a loaded 2 place Blanik on a standard day at SL,
from a 1800' grass strip? Or perhaps such a tug could be used to tow
the members single place ships, and the heavier/ 2-place ships stow
behind the clubs remaining pawnee?
Brad
http://www.youtube.com/watch?v=5UYPyNgf4Q4
Lambada motorglider towing
UFM 13 Rotax 912 100hp
Personally I would far rather be behind the 100hp Samba or Lambada with
my Std Cirrus - hot and high off grass the accelleration is slower, but
the propwash is limited and climb is better than the asthmatic 180hp
(must be really little ponies over there) super cub.
The wingloading on the Lambada is very similar and the tow combination
is nicely balanced. Behind a 235hp Rallye it is, by comparison
wonderful. Same time to altitude without all the - extreme speed just
off the deck waiting for the tug to leap skyward, then get to be like a
good martini and get all shaken up by the wake turbulence - then scream
around on the outside of all the thermals.
Give me a motorglider any time...
Bruce
In case anyone thought that the MG/UL has too little grunt.
Follow the link below.
The story behind it is - experienced pilot in getting current again on
Janus forgot the thing has a drogue chute.
On a check flight the Janus is towed up from an airfield (Orient) at
5100" MSL at around 20 centigrade.
As you can see the Samba accelerates slowly - then the drogue chute
deploys. (one bump too many )
Tuggie happens to be enormously experienced CFI - uses his head and
abuses the Rotax a little. Combination manages to make a circuit and the
Janus gets dropped over the threshold.
Samba engine did not over heat or suffer any apparent damage, although
it was kept in the time limited maximum power range for the entire circuit.
Seeking towplanes for Region 9 [email protected] Soaring 0 May 17th 06 12:03 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
