On Mar 17, 11:12*pm, wrote:
The article says that the older gasoline powered winches with automatic transmissions are tension controlled types, or at least allow themselves to be controlled that way. I'm not familiar with transmissions to know either way, just citing what the article says. They go on to recommend that the existing electric ones and the Diesels commonly used at least install a tension meter. Further, the older Hercules winches should be abandoned as they are not up to par, break down often and are not of the highest standard. These are mainly from eastern Europe. To take away, besides maintaining the equipment, is to realize that an avoidable danger is in accelerating too fast in the first few seconds, because this can (emphasis on "can") cause an unavoidable pitch up movement that can not be compensated for with the available elevator authority - resulting in either a high speed and nose high stall at low altitude due to an excessive angle of attack or a rope break (weak link). the former is almost always fatal. The latter not, but can be if the pilot does not react properly and can contribute to accidents. The pleasing part is that the new German statistics show winch launch actually safer than air tow. I've always felt that this should be the case if the equipment was well maintained and the pilots were trained to the same level as is common with air tow. However there seems to be a lot of technical confusion in the article. "Tension Controlled" means that rope tension is continuously monitored and controlled through an automatic feedback loop. There are very few winches that do this. Two American built super winches are both tension controlled with feedback systems. Automatic transmissions are designed to help a vehicle driver maintain highway speed on varying road grades - that's speed control and the exact opposite of tension control. There is no torque regulation in an automatic transmission and there is no way to modify one to provide it. To refer to them as "tension controlled is plain wrong. Automatic transmissions taken from road vehicles simply don't belong in glider winches. Electric winches could easily be tension controlled by just monitoring the current flowing to the motor as could hydrostatic winches by monitoring hydraulic pressure although a running line tensiometer would be a better solution. My understanding is that the ESW-2B is tension controlled. I know for a fact that both American super winches under development ARE tension controlled. Specific attacks on electric winches show a complete lack of understanding of electric power. The innate characteristics of electric motors make them ideal for torque control. "Older gasoline powered winches" most likely mean underpowered winches that are actually "tension limited" such that the glider pilot can control airspeed with pitch. To refer to these as tension controlled is unwarranted and will confuse the issue. These are not "tension controlled". The hysterics about initial acceleration needs hard data not theory or speculation to back it up. The experiments I have done with "pitch strings" used as an angle of attack indicator suggest that the AOA is nowhere near stall regardless of initial acceleration. In fact, greater acceleration actually reduces peak AOA. The preceding paragraph needs to be qualified by saying there are a small number of types with well deserved reputations for uncontrollable pitch-up under hard acceleration. There are relatively few of these and they are . |
Two points Bill,
1) Why do you think that automatic transmissions in vehicles (or winches) try to maintain a constant speed? If you come to a hill and keep the throttle setting the same, the vehicle will slow down! As a glider rotates into the full climb and demands more power, the winch cable will also slow down if you maintain the same throttle setting. Are you sure you are not getting confused with cruise control? 2) Obviously you have never watched a dangerously steep, overpowered, over-rotation on a winch launch. I have! Generally these involve lighter, high wing gliders such as K6s, K7s and K8s. Usually they go into a near vertical climb, often despite the pilot holding the stick on the forward stop, followed by a weak link failure. On one occasion a K8 got into such a steep climb that the belly hook just back released, due to the extreme angle between the fuselage and the cable. These events normally leave the glider pointing almost vertically at the sky at about 100ft with no further means of propulsion! Fortunately at our club, none of these glider flicked, and were being flown by youngish, switched on pilots who managed to get them down safety. I dread to think what would have happened if a numpty had been flying them. I know a lady who was almost knocked unconcious during at the start of a very overpowered winch launch, when she banged her head very hard on the canopy frame of her K6. Also there have been a couple of fatal flick spin accidents in the UK where it is believed that the pilots slipped back in their seats and pulled the stick hard back as a result. These were both in glass single seaters with rather reclining seatpans. There is no case for exceeding about 0.8g acceleration during the ground run. This gets you up to flying speed in about 3 to 4 seconds. Most pilots find this enough! Derek Copeland At 15:16 18 March 2009, bildan wrote: . The pleasing part is that the new German statistics show winch launch actually safer than air tow. I've always felt that this should be the case if the equipment was well maintained and the pilots were trained to the same level as is common with air tow. However there seems to be a lot of technical confusion in the article. "Tension Controlled" means that rope tension is continuously monitored and controlled through an automatic feedback loop. There are very few winches that do this. Two American built super winches are both tension controlled with feedback systems. Automatic transmissions are designed to help a vehicle driver maintain highway speed on varying road grades - that's speed control and the exact opposite of tension control. There is no torque regulation in an automatic transmission and there is no way to modify one to provide it. To refer to them as "tension controlled is plain wrong. Automatic transmissions taken from road vehicles simply don't belong in glider winches. Electric winches could easily be tension controlled by just monitoring the current flowing to the motor as could hydrostatic winches by monitoring hydraulic pressure although a running line tensiometer would be a better solution. My understanding is that the ESW-2B is tension controlled. I know for a fact that both American super winches under development ARE tension controlled. Specific attacks on electric winches show a complete lack of understanding of electric power. The innate characteristics of electric motors make them ideal for torque control. "Older gasoline powered winches" most likely mean underpowered winches that are actually "tension limited" such that the glider pilot can control airspeed with pitch. To refer to these as tension controlled is unwarranted and will confuse the issue. These are not "tension controlled". The hysterics about initial acceleration needs hard data not theory or speculation to back it up. The experiments I have done with "pitch strings" used as an angle of attack indicator suggest that the AOA is nowhere near stall regardless of initial acceleration. In fact, greater acceleration actually reduces peak AOA. The preceding paragraph needs to be qualified by saying there are a small number of types with well deserved reputations for uncontrollable pitch-up under hard acceleration. There are relatively few of these and they are . |
On the other end of the scale, only 8.7% of the accidents with winch
launches involves a wing drop to the ground. |
On Mar 18, 12:30*pm, Derek Copeland wrote:
2) Obviously you have never watched a dangerously steep, overpowered, over-rotation on a winch launch. I have! No, I haven't seen any of the weird things you describe. They all seem to happen in your immediate vicinity. I wonder why. |
At 23:53 18 March 2009, bildan wrote:
On Mar 18, 12:30=A0pm, Derek Copeland wrote: 2) Obviously you have never watched a dangerously steep, overpowered, over-rotation on a winch launch. I have! No, I haven't seen any of the weird things you describe. They all seem to happen in your immediate vicinity. I wonder why. Probably because I'm a gliding instructor at a large and very busy club that does a lot of winch launching. I also visit other clubs that winch launch. I should add that probably 99% of winch launches go to plan (including deliberate practice launch failures by instructors) without any difficulties. About 1% suffer cable or weak link breaks, or other technical failures of one sort or another. Given proper training these should be just an inconvenience, rather than an emergency situation. Once it was recognised that over powered winch launches were a problem for lighter gliders, we reduced the power settings used for these types and opened the winch engine throttles a bit more slowly. I haven't seen a 'rocket launch' for quite a few years now. Derek Copeland |
In message , Derek Copeland
writes At 23:53 18 March 2009, bildan wrote: On Mar 18, 12:30=A0pm, Derek Copeland wrote: 2) Obviously you have never watched a dangerously steep, overpowered, over-rotation on a winch launch. I have! No, I haven't seen any of the weird things you describe. They all seem to happen in your immediate vicinity. I wonder why. Probably because I'm a gliding instructor at a large and very busy club that does a lot of winch launching. I also visit other clubs that winch launch. I should add that probably 99% of winch launches go to plan (including deliberate practice launch failures by instructors) without any difficulties. About 1% suffer cable or weak link breaks, or other technical failures of one sort or another. Given proper training these should be just an inconvenience, rather than an emergency situation. I have over 300 winch launches - not many by some people's standards but still a fair number. I have had only 1 genuine launch failure (caused by the club member driving the winch, not by me or by equipment failure), so either I'm due a run of cable breaks and the like, or the percentage of failures is better for some pilots/ glider types than others... (or a bit of both of course) snip -- Surfer! Email to: ramwater at uk2 dot net |
bildan wrote:
On Mar 18, 12:30 pm, Derek Copeland wrote: 2) Obviously you have never watched a dangerously steep, overpowered, over-rotation on a winch launch. I have! No, I haven't seen any of the weird things you describe. They all seem to happen in your immediate vicinity. I wonder why. Hi Bill Derek is not alone here. As additional example - Std Cirrus can also be coaxed into too steep a climb with too much power too fast. In this case it is often a combination of - poor seatbelt location, which allows the pilot to slide back on launch. - full flying elevator - which is possible to stall if one holds the stick full forward. (Low speed + big angular deflection) - aft CG with a light pilot Maybe if you only ever see launches of modern glass, or heavy two seaters, with experienced winch drivers who know the different types, you will not see this. I have yet to meet the perfect winch driver. At a busy club, or where the winch driver is inexperienced with the glider type or just inexperienced it is easy on a powerful winch to apply too much initial power. And a little too fast on the throttle at the start is very dangerous for a range of gliders. Basically excessive acceleration can use most or all of the available control authority. One more thing, like a gust / thermal / cable break and you exceed the authority and have an accident. Best to avoid. Best way to avoid is to train winch driving technique correctly. Denial gets people hurt. Power limited winches are no fun either... Bruce |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Safety of winch launch vrs. aero tow? | Gary Boggs | Soaring | 172 | November 13th 03 06:59 PM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
