motorgliders as towplanes
Old March 19th 09, 01:15 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
Default Aerodynamics of Towing
A glider in steady free flight is always descending through the air in
which it is flying. If you can fly in air that is going up as fast or
faster than the sink rate of the glider, then you can gain potential
height energy. Isn't that what soaring flight is all about?
Derek Copeland
(Qualified gliding instructor with Gold C and 3 Diamonds BTW)
At 22:07 18 March 2009, The Real Doctor wrote:
On 17 Mar, 19:04, Darryl Ramm wrote:
Say what? Gravitational potential energy *increases* not decreases as
the glider climbs.
Sorry, typo.
And that "store" is the transfer mechanism that allows the glider to
glide.
No it's not. The gravity force is necessary, but it's perfectly
possible to soar for extended periods and distances without adding to
or drawing from the potential energy store. It happens any time we fly
level - along a wavebar, running a ridge, following a cloud street.
There is no other mechanism. With no gravity, even with an
atmosphere (which would be difficult to arrange), your glider could
not glide.
You miss, as so many people do, the point. Because the force of
gravity is necessary for a glider to work, people assume that gravity
somehow "powers" the flight. Which it does not.
Guy's this has wandered into junior-high school level physics.
No, it has wandered into junior high school level misconceptions about
physics!
Here's another one for you. Does a glider turn (normally) by (a)
rolling (b) pitching (c) yawing or (d) other?
Ian
Old March 19th 09, 07:45 AM posted to rec.aviation.soaring
Jim White[_2_]
Having read all 170 posts in this thread I am still happily ignorant of the
theory of flight!
Old March 19th 09, 08:24 AM posted to rec.aviation.soaring
The Real Doctor
theory of flight!
Aircraft stay up because they're afraid of the ground.
That said, you might find it interesting to get hold of the TV
programme and video which the Open University made on gliding
mathematics some years ago. The course in question, "MST207 Applied
Mathematics" is defunct, but a fair number of copies of the AV
material lurk around gliding clubs.
Ian
Old March 19th 09, 12:30 PM posted to rec.aviation.soaring
Bob Cook[_2_]
Ok I'll bite.....
Turning flight is accelerated flight, so the forces acting on the glider
are "unbalanced".
Since I am a firm believer that you can't change gravity (although some
of you out there try to in your analysis), gravity remains constant. If
we keep airpseed constant then drag should not change either. So we have
to change lift in order to get acceleration.
So I say we have to change the direction of lift, inward toward the center
of the circle. (centripetal force). This should be accomplished by
rolling.
Since we have added a "Horizontal component of lift", total lift must be
increased. This normally requires additional nose up force on stick or
trim. (angle of attack) You might call this pitch, but I don't think
the actual pitch attitude changes, just the stick forces and angle of
attack.
Yawing can be conidered to be necessary, or at least correction for
adverse yaw.
But to rephrase the question,
Q) What force causes a glider to turn.
A) Lift
Cookie
Here's another one for you. Does a glider turn (normally) by (a)rolling
Ian
Old March 19th 09, 02:15 PM posted to rec.aviation.soaring
Big Wings
At 12:30 19 March 2009, Bob Cook wrote:
Clearly not a geologist then. I wonder why they do gravity surveys if it
is a constant?
Ok I'll bite.....
Old March 19th 09, 05:00 PM posted to rec.aviation.soaring
Big Wings
Further to earlier post. Gravity is measured in Gals (in honour of
Galileo), 1 Gal = an acceleration of 1 cm/sec2. Average gravity at the
surface is 980.654321 Gals (or so). At the poles it is more at about 983
Gals and on equatorial mountain tops only 977 Gals - a difference of about
0.6%. There are significant local variations. Now if we start to take
height into account...
By the way, what happened to the discussion about slow tows?
it
is a constant?
Ok I'll bite.....
some
Old March 19th 09, 07:21 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
983 Gals and on equatorial mountain tops only 977 Gals - a difference of
about 0.6%. There are significant local variations. Now if we start to
take height into account...
I notice that's not an SI unit. Is the Gal some sort of engineering or
specialist geological unit? Its a pretty big unit for gravimetry, since
the maximal variation at the earths surface is only 6 Gals.
The SI unit is uM/s^2 (micrometers per sec squared), or 0.1 milliGals,
which looks more in tune with what satellites and aerial surveys are
measuring these days.
Got too slow and stalled in.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 20th 09, 12:45 AM posted to rec.aviation.soaring
Bob Cook[_2_]
Dear Big,
You are on to something here. Get one of those geo surveys, and fly your
glider only over areas of higher gravity. This extra gravity will give
your glider extra power, and you will be the best glider pilot!
Cookie
it
is a constant?
Ok I'll bite.....
some
Old March 20th 09, 02:30 PM posted to rec.aviation.soaring
Jim Beckman[_2_]
your
Well, that should work. The important thing is that you have to find and
use thermals only in *low* gravity areas, and then do your inter-thermal
cruising in the *high* gravity areas. Next best thing to dynamic
soaring.
Jim Beckman
Old March 19th 09, 05:46 PM posted to rec.aviation.soaring
Jim Logajan
some of you out there try to in your analysis)
They're just using thought experiments:
http://en.wikipedia.org/wiki/Thought_experiment
Seeking towplanes for Region 9 [email protected] Soaring 0 May 17th 06 12:03 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
