motorgliders as towplanes
Old March 19th 09, 12:45 PM posted to rec.aviation.soaring
Bob Cook[_2_]
Default aerodynamics of gliding
Ian,
Misconceptions sure die hard. Many "Cannot handle the truth".
Here' s another one.
Q) A glider is in circling flight. The glider circles because there is a
horizontal component of lift. This horizontal component of lift is
balanced by an equal and opposite force, centrifugal force.
True or False and why?
Cookie
Old March 19th 09, 06:25 PM posted to rec.aviation.soaring
The Real Doctor
On 19 Mar, 12:45, Bob Cook wrote:
Q) A glider is in circling flight. *The glider circles because there is a
horizontal component of lift. *This horizontal component of lift is
I hope you're not getting hung up on the old centripetal/centrifugal
debate. Centripetal force is just as real in a stationary axix system
as centrifugal is in a turning one!
By and large (ignoring a few second-order effects) what you wrote is
fine.
Ian
Old March 20th 09, 01:00 AM posted to rec.aviation.soaring
Bob Cook[_2_]
Ian,
I was trying to point out a misconception that the "horizontal component
of lift" in a turn is somehow balanced by some other force.
If it were, the glider would not turn.
A turn is an acceleraton, requiring unbalanced forces. Lift is greater
than the sum of gravity plus drag.
Cookie
Q) A glider is in circling flight. =A0The glider circles because there
is=
a
horizontal component of lift. =A0This horizontal component of lift is
fine.
Ian
Old March 20th 09, 09:32 AM posted to rec.aviation.soaring
The Real Doctor
On 20 Mar, 01:00, Bob Cook wrote:
Ian,
It all depends on your reference frame. To someone on the ground, an
unbalanced sideways force gives rise to the necessary acceleration.
But to an observer moving with the glider - the pilot, say - there is
no sideways acceleration /of the glider/ (the rest of the world may,
of course, be doing something). To the moving observer, an equal an
opposite centrifugal force provides the necessary balance.
We engineers like modelling with moving reference frames and
centrifugal forces because it turns dynamics problems into statics
problems, which are generally simpler. Physicists, and particularly
school physics teachers, traditionally get terribly upset by the idea
of centrifugal force.
Ian
Old March 21st 09, 05:21 AM posted to rec.aviation.soaring
Myles
Ian
Physicsists make equally snarky comments about engineers, Ian. My
engineering dynamics professor at UC, Berkeley was adamant in
opposing the perpetuation of the centrifugal force myth. It's phony
physics and can lead to seriously erroneous conclusions.
Myles
Old March 21st 09, 11:41 AM posted to rec.aviation.soaring
The Real Doctor
Physicsists make equally snarky comments about engineers, Ian. *
Indeed. Bu hey, the mathematicians despise us all.
My
engineering dynamics professor at UC, Berkeley was *adamant in
opposing the perpetuation of the centrifugal force myth. *It's phony
It's a perfectly useful tool if applied correctly. That normally means
within a moving axis system, and getting there is not always simple.
You always have to decide whether it's going to be easier overall to
use the difficult model with the simple setup (stationary axes) or the
simple model with the difficult setup (moving axes).
It's the same in fluids - normally we model a glider by holding it
still and letting the air move past, but that's not always the best
way, or the easiest way. Mind you, I'm a typical lazy engineer, so for
me best = easiest in about 99% of cases.
Ian
Old March 21st 09, 02:30 PM posted to rec.aviation.soaring
TonyV[_2_]
... My engineering dynamics professor at UC, Berkeley was adamant in
Yeah, yeah, centrifugal force is a reaction to a centripetal force, I
know the difference,.... I don't care. The layman understands the former
term and not the latter. To the typical student, I'll use the term
"centrifugal". If he's a physicist, I'll say "centripetal". :-)
Tony V.
Seeking towplanes for Region 9 [email protected] Soaring 0 May 17th 06 12:03 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
