Bob Cook wrote:
Not many took a stab at the "spoilers and flaps" questons! Probably because it was a no-win situation. Spoilers do not "reduce lift". Spoilers increase drag. As drag increases, glide slope steepens. Spoilers redistribute lift, but not reduce lift. You're claim conflicts with that in the FAA "Pilot's Handbook of Aeronautical Knowledge": "Found on many gliders and some aircraft, high drag devices called spoilers are deployed from the wings to spoil the smooth airflow, reducing lift and increasing drag." http://www.faa.gov/library/manuals/a...apter%2003.pdf Flaps do not "increase lift". Flaps increase drag. As drag increases, gilde slope steepens. Flaps change the coeffecient of lift, but not lift. Again, from the PHAK, same chapter: "Flaps are the most common high-lift devices used on aircraft. These surfaces, which are attached to the trailing edge of the wing, increase both lift and induced drag for any given AOA." (But I see you're being pedantic. Now you make a distinction between "lift" and "coefficient of lift".) Another question: Q) Two gliders, one is 40:1 racer and glider two is 20:1 trainer. Both weigh 800# Glider one has twice the lift of glider two. True or flase and why. Another no-win situation, since you don't indicate what they are doing. Are they sitting stationary on the ground? Then both have zero lift. Are they turning and if so, are the turn radii and descent rates different? |
On Thu, 19 Mar 2009 13:09:30 -0500, Jim Logajan wrote:
You're claim conflicts with that in the FAA "Pilot's Handbook of Aeronautical Knowledge": "Found on many gliders and some aircraft, high drag devices called spoilers are deployed from the wings to spoil the smooth airflow, reducing lift and increasing drag." Printing it in some official or semi-official publication doesn't make it right. There is a question in the UK Bronze badge written paper about the proportion of lift provided by the top and bottom surfaces of a wing that's just as wrong. The so-called "correct" answer is 70/30, but as a wing is a device for imparting momentum to an air mass its a meaningless question. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On 19 Mar, 19:48, Martin Gregorie
wrote: There is a question in the UK Bronze badge written paper about the proportion of lift provided by the top and bottom surfaces of a wing that's just as wrong. The so-called "correct" answer is 70/30, but as a wing is a device for imparting momentum to an air mass its a meaningless question. Oh no. Not that one. At the surface of the wing, it exerts a force on the air mass. A long distance away (typically 2 chord lengths) it's a momentum change. In between the effect of the wing is a pressure change /and/ a momentum change. Overall, the integrated pressure across the top surface is about 70% of the total lift force, and the intergrated pressure across the bottom surface is about 30% of the total lift. Significance? Irregularities on the top surface will reduce lift by more than the same irregularities on the bottom surface. Hence top- surface-only airbrakes: they are more effective there than underneath, because they destroy more lift, necessitating a bigger and draggier change of AoA to compensate. Ian |
On Fri, 20 Mar 2009 02:39:17 -0700, The Real Doctor wrote:
On 19 Mar, 19:48, Martin Gregorie wrote: There is a question in the UK Bronze badge written paper about the proportion of lift provided by the top and bottom surfaces of a wing that's just as wrong. The so-called "correct" answer is 70/30, but as a wing is a device for imparting momentum to an air mass its a meaningless question. Oh no. Not that one. At the surface of the wing, it exerts a force on the air mass. A long distance away (typically 2 chord lengths) it's a momentum change. In between the effect of the wing is a pressure change /and/ a momentum change. Overall, the integrated pressure across the top surface is about 70% of the total lift force, and the intergrated pressure across the bottom surface is about 30% of the total lift. Significance? Irregularities on the top surface will reduce lift by more than the same irregularities on the bottom surface. Hence top- surface-only airbrakes: they are more effective there than underneath, because they destroy more lift, necessitating a bigger and draggier change of AoA to compensate. True enough, but the point I was trying (badly) to make is that the lift is due to the whole wing section and shouldn't be apportioned to the two surfaces as a number taught to neophytes. Apart from anything else this breaks down when you consider the pressure distribution across the top surface. Why not also teach an arbitrary percentage of lift generated by the LE suction spike at high Cl? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
At 19:48 19 March 2009, Martin Gregorie wrote:
On Thu, 19 Mar 2009 13:09:30 -0500, Jim Logajan wrote: You're claim conflicts with that in the FAA "Pilot's Handbook of Aeronautical Knowledge": "Found on many gliders and some aircraft, high drag devices called spoilers are deployed from the wings to spoil the smooth airflow, reducing lift and increasing drag." Printing it in some official or semi-official publication doesn't make it right. But it *does* make it the right answer to the written test when that test is given by that same authority. For the test, concentrate not on what is necessarily true, but on what the FAA wants for an answer. After the written is out of the way, just learn to fly the aircraft. Jim Beckman |
On Fri, 20 Mar 2009 14:30:04 +0000, Jim Beckman wrote:
But it *does* make it the right answer to the written test when that test is given by that same authority. For the test, concentrate not on what is necessarily true, but on what the FAA wants for an answer. After the written is out of the way, just learn to fly the aircraft. Yes, and I learnt it as the answer to that Bronze question. It just annoys me that official publications should enshrine myths as some sort of truth. Its no better than introductory texts showing packets of air dividing at the LE of a ring and meeting up again at the TE, when a photo taken in a wind tunnel shows clearly that doesn't happen. Far better to publish the photo than a bogus diagram. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On 21 Mar, 16:48, Martin Gregorie
wrote Its no better than introductory texts showing packets of air dividing at the LE of a ring and meeting up again at the TE, when a photo taken in a wind tunnel shows clearly that doesn't happen. Far better to publish the photo than a bogus diagram. Oh, that one drives me mad. Not only does it not happen ... there is no conceivable reason why it should happen. And yet many many websites and books cite it as fact. Grrrrrrrrrrrrrrrrrr. Incidentally, if you don't have a copy of "An Album of Fluid Motion" by Milton Van Dyke, get it. You'll love it. Every gliding club should have one. Ian |
On Sat, 21 Mar 2009 12:28:59 -0700, The Real Doctor wrote:
Incidentally, if you don't have a copy of "An Album of Fluid Motion" by Milton Van Dyke, get it. You'll love it. Every gliding club should have one. Another recommendation: http://www.av8n.com/how/ gives a good description of how an aeroplane works. A lot of it is similar to "Stick and Rudder", so its written for pilots rather than aircraft designers. However, section 3 has excellent descriptions and diagrams showing how a wing works. It was recommended to me by a professional aerodynamicist who is a model designer and has flown gliders. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Sat, 21 Mar 2009 20:01:23 +0000, Martin Gregorie wrote:
On Sat, 21 Mar 2009 12:28:59 -0700, The Real Doctor wrote: Incidentally, if you don't have a copy of "An Album of Fluid Motion" by Milton Van Dyke, get it. You'll love it. Every gliding club should have one. Here's a link to animated visualizations of the flow past a wing: http://www.av8n.com/irro/ - click the flag of your favored language to see the visualizations. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
That is a VERY good reference!!!
Mike Schumann "Martin Gregorie" wrote in message ... On Sat, 21 Mar 2009 12:28:59 -0700, The Real Doctor wrote: Incidentally, if you don't have a copy of "An Album of Fluid Motion" by Milton Van Dyke, get it. You'll love it. Every gliding club should have one. Another recommendation: http://www.av8n.com/how/ gives a good description of how an aeroplane works. A lot of it is similar to "Stick and Rudder", so its written for pilots rather than aircraft designers. However, section 3 has excellent descriptions and diagrams showing how a wing works. It was recommended to me by a professional aerodynamicist who is a model designer and has flown gliders. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Seeking towplanes for Region 9 | [email protected] | Soaring | 0 | May 17th 06 12:03 AM |
US:Restricted Towplanes | Judy Ruprecht | Soaring | 8 | November 5th 04 11:27 PM |
Standard Nationals Need Towplanes | C AnthMin | Soaring | 5 | July 14th 04 12:46 AM |
Take-upReels on Towplanes | Nyal Williams | Soaring | 9 | April 21st 04 12:39 AM |
Helicopters and Towplanes | Burt Compton | Soaring | 6 | September 11th 03 05:21 PM |
