motorgliders as towplanes
Old March 19th 09, 07:48 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
Default aerodynamics of gliding
On Thu, 19 Mar 2009 13:09:30 -0500, Jim Logajan wrote:
You're claim conflicts with that in the FAA "Pilot's Handbook of
Aeronautical Knowledge":
"Found on many gliders and some aircraft, high drag devices called
spoilers are deployed from the wings to spoil the smooth airflow,
reducing lift and increasing drag."
Printing it in some official or semi-official publication doesn't make it
right.
There is a question in the UK Bronze badge written paper about the
proportion of lift provided by the top and bottom surfaces of a wing
that's just as wrong. The so-called "correct" answer is 70/30, but as a
wing is a device for imparting momentum to an air mass its a meaningless
question.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 20th 09, 09:39 AM posted to rec.aviation.soaring
The Real Doctor
On 19 Mar, 19:48, Martin Gregorie
question.
Oh no. Not that one.
At the surface of the wing, it exerts a force on the air mass. A long
distance away (typically 2 chord lengths) it's a momentum change. In
between the effect of the wing is a pressure change /and/ a momentum
change.
Overall, the integrated pressure across the top surface is about 70%
of the total lift force, and the intergrated pressure across the
bottom surface is about 30% of the total lift.
Significance? Irregularities on the top surface will reduce lift by
more than the same irregularities on the bottom surface. Hence top-
surface-only airbrakes: they are more effective there than underneath,
because they destroy more lift, necessitating a bigger and draggier
change of AoA to compensate.
Ian
Old March 20th 09, 10:52 AM posted to rec.aviation.soaring
meaningless question.
change.
Overall, the integrated pressure across the top surface is about 70% of
the total lift force, and the intergrated pressure across the bottom
Significance? Irregularities on the top surface will reduce lift by more
True enough, but the point I was trying (badly) to make is that the lift
is due to the whole wing section and shouldn't be apportioned to the two
surfaces as a number taught to neophytes. Apart from anything else this
breaks down when you consider the pressure distribution across the top
surface. Why not also teach an arbitrary percentage of lift generated by
the LE suction spike at high Cl?
org |
Old March 20th 09, 02:30 PM posted to rec.aviation.soaring
Jim Beckman[_2_]
it
right.
But it *does* make it the right answer to the written test when that test
is given by that same authority. For the test, concentrate not on what is
necessarily true, but on what the FAA wants for an answer. After the
written is out of the way, just learn to fly the aircraft.
Jim Beckman
Old March 21st 09, 04:48 PM posted to rec.aviation.soaring
test is given by that same authority. For the test, concentrate not on
what is necessarily true, but on what the FAA wants for an answer.
After the written is out of the way, just learn to fly the aircraft.
Yes, and I learnt it as the answer to that Bronze question. It just
annoys me that official publications should enshrine myths as some sort
of truth.
Its no better than introductory texts showing packets of air dividing at
the LE of a ring and meeting up again at the TE, when a photo taken in a
wind tunnel shows clearly that doesn't happen. Far better to publish the
photo than a bogus diagram.
org |
Old March 21st 09, 07:28 PM posted to rec.aviation.soaring
The Real Doctor
On 21 Mar, 16:48, Martin Gregorie
Oh, that one drives me mad. Not only does it not happen ... there is
no conceivable reason why it should happen. And yet many many websites
and books cite it as fact. Grrrrrrrrrrrrrrrrrr.
Incidentally, if you don't have a copy of "An Album of Fluid Motion"
by Milton Van Dyke, get it. You'll love it. Every gliding club should
have one.
Ian
Old March 21st 09, 08:01 PM posted to rec.aviation.soaring
On Sat, 21 Mar 2009 12:28:59 -0700, The Real Doctor wrote:
Incidentally, if you don't have a copy of "An Album of Fluid Motion" by
Milton Van Dyke, get it. You'll love it. Every gliding club should have
one.
Another recommendation:
http://www.av8n.com/how/ gives a good description of how an aeroplane
works. A lot of it is similar to "Stick and Rudder", so its written for
pilots rather than aircraft designers. However, section 3 has excellent
descriptions and diagrams showing how a wing works. It was recommended to
me by a professional aerodynamicist who is a model designer and has flown
gliders.
org |
Old March 21st 09, 08:18 PM posted to rec.aviation.soaring
one.
Here's a link to animated visualizations of the flow past a wing:
http://www.av8n.com/irro/ - click the flag of your favored language to
see the visualizations.
org |
Old March 21st 09, 11:01 PM posted to rec.aviation.soaring
The Real Doctor
On 21 Mar, 20:18, Martin Gregorie
one.
Here's a link to animated visualizations of the flow past a wing:http://www.av8n.com/irro/- click the flag of your favored language to
I've never really liked that Joukowski transform stuff. The arbitrary
definition of circulation worries me, and anyway no real wing behaves
anything like that. It's a fair way of visualising the flow, roughly,
but I prefer to jump straight into circulation theory and model my
wings as vortices.
Ian
Old March 22nd 09, 02:56 AM posted to rec.aviation.soaring
Mike Schumann
That is a VERY good reference!!!
Mike Schumann
"Martin Gregorie" wrote in message
one.
gliders.
org |
Seeking towplanes for Region 9 [email protected] Soaring 0 May 17th 06 12:03 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
