motorgliders as towplanes
Old March 20th 09, 09:39 AM posted to rec.aviation.soaring
The Real Doctor
Default aerodynamics of gliding
On 19 Mar, 19:48, Martin Gregorie
There is a question in the UK Bronze badge written paper about the
proportion of lift provided by the top and bottom surfaces of a wing
that's just as wrong. The so-called "correct" answer is 70/30, but as a
wing is a device for imparting momentum to an air mass its a meaningless
question.
Oh no. Not that one.
At the surface of the wing, it exerts a force on the air mass. A long
distance away (typically 2 chord lengths) it's a momentum change. In
between the effect of the wing is a pressure change /and/ a momentum
change.
Overall, the integrated pressure across the top surface is about 70%
of the total lift force, and the intergrated pressure across the
bottom surface is about 30% of the total lift.
Significance? Irregularities on the top surface will reduce lift by
more than the same irregularities on the bottom surface. Hence top-
surface-only airbrakes: they are more effective there than underneath,
because they destroy more lift, necessitating a bigger and draggier
change of AoA to compensate.
Ian
Old March 20th 09, 10:52 AM posted to rec.aviation.soaring
Martin Gregorie[_4_]
meaningless question.
change.
Overall, the integrated pressure across the top surface is about 70% of
the total lift force, and the intergrated pressure across the bottom
Significance? Irregularities on the top surface will reduce lift by more
True enough, but the point I was trying (badly) to make is that the lift
is due to the whole wing section and shouldn't be apportioned to the two
surfaces as a number taught to neophytes. Apart from anything else this
breaks down when you consider the pressure distribution across the top
surface. Why not also teach an arbitrary percentage of lift generated by
the LE suction spike at high Cl?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Seeking towplanes for Region 9 [email protected] Soaring 0 May 17th 06 12:03 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
