On Fri, 20 Mar 2009 02:39:17 -0700, The Real Doctor wrote:
On 19 Mar, 19:48, Martin Gregorie wrote: There is a question in the UK Bronze badge written paper about the proportion of lift provided by the top and bottom surfaces of a wing that's just as wrong. The so-called "correct" answer is 70/30, but as a wing is a device for imparting momentum to an air mass its a meaningless question. Oh no. Not that one. At the surface of the wing, it exerts a force on the air mass. A long distance away (typically 2 chord lengths) it's a momentum change. In between the effect of the wing is a pressure change /and/ a momentum change. Overall, the integrated pressure across the top surface is about 70% of the total lift force, and the intergrated pressure across the bottom surface is about 30% of the total lift. Significance? Irregularities on the top surface will reduce lift by more than the same irregularities on the bottom surface. Hence top- surface-only airbrakes: they are more effective there than underneath, because they destroy more lift, necessitating a bigger and draggier change of AoA to compensate. True enough, but the point I was trying (badly) to make is that the lift is due to the whole wing section and shouldn't be apportioned to the two surfaces as a number taught to neophytes. Apart from anything else this breaks down when you consider the pressure distribution across the top surface. Why not also teach an arbitrary percentage of lift generated by the LE suction spike at high Cl? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Seeking towplanes for Region 9 | [email protected] | Soaring | 0 | May 17th 06 12:03 AM |
US:Restricted Towplanes | Judy Ruprecht | Soaring | 8 | November 5th 04 11:27 PM |
Standard Nationals Need Towplanes | C AnthMin | Soaring | 5 | July 14th 04 12:46 AM |
Take-upReels on Towplanes | Nyal Williams | Soaring | 9 | April 21st 04 12:39 AM |
Helicopters and Towplanes | Burt Compton | Soaring | 6 | September 11th 03 05:21 PM |
