With my new Zaon MRX PCAS mounted on top of my glare shield, I've been
experiencing some radio interference and linked this to the MRX: the radio gives white-noise static -- like the squelch is not properly adusted. When I turn the MRX off it goes away. I've heard putting a "ferrite core" around the MRX's (and the radio's?) power cord might help. (Here's one: http://cgi.ebay.ca/Noise-Filter-Clip...QQcmdZViewItem ). Does anybody else have this problem? Have you solved it in some way? Thanks, Eric DG-300 |
JJ Sinclair reported an MRX/radio interference problem several years
ago on this forum. When I installed my MRX in my panel I took the precaution of installing a ferrite bead around the power cable, and I've had no interference problems. It's good electrical practice to use ferrite beads on DC supply leads. If you can, loop the power cable so it goes through the ferrite core more than once in order to get the best high frequency attenuation. -John On Mar 24, 1:58 am, wrote: With my new Zaon MRX PCAS mounted on top of my glare shield, I've been experiencing some radio interference and linked this to the MRX: the radio gives white-noise static -- like the squelch is not properly adusted. When I turn the MRX off it goes away. I've heard putting a "ferrite core" around the MRX's (and the radio's?) power cord might help. (Here's one:http://cgi.ebay.ca/Noise-Filter-Clip...QQitemZ3501565... ). Does anybody else have this problem? Have you solved it in some way? Thanks, Eric DG-300 |
On Mar 24, 2:58*am, wrote:
With my new Zaon MRX PCAS mounted on top of my glare shield, I've been I have the same problem. I also had the problem with the previous model. I did the ferrite bead and it didn't do the job. I finally sent it in and they replaced the power mosfet and that did the trick. I'm about to send this one in for a firmware upgrade and to deal with this issue. Hopefully the same way. Cheers, Tim 1FL experiencing some radio interference and linked this to the MRX: the radio gives white-noise static -- like the squelch is not properly adusted. When I turn the MRX off it goes away. I've heard putting a "ferrite core" around the MRX's (and the radio's?) power cord might help. *(Here's one:http://cgi.ebay.ca/Noise-Filter-Clip...QQitemZ3501565... ). Does anybody else have this problem? *Have you solved it in some way? Thanks, Eric DG-300 |
On Mar 24, 6:01*am, qflyer1 wrote:
On Mar 24, 2:58*am, wrote: With my new Zaon MRX PCAS mounted on top of my glare shield, I've been I have the same problem. I also had the problem with the previous model. I did the ferrite bead and it didn't do the job. I finally sent it in and they replaced the power mosfet and that did the trick. I'm about to send this one in for a firmware upgrade and to deal with this issue. Hopefully the same way. Cheers, Tim 1FL experiencing some radio interference and linked this to the MRX: the radio gives white-noise static -- like the squelch is not properly adusted. When I turn the MRX off it goes away. I've heard putting a "ferrite core" around the MRX's (and the radio's?) power cord might help. *(Here's one:http://cgi.ebay.ca/Noise-Filter-Clip...QQitemZ3501565... ). Does anybody else have this problem? *Have you solved it in some way? Thanks, Eric DG-300 Make sure you are installing a large enough ferrite bead (beads is slang, fat walled cylinders might be a better description) that allows the power cable to go through the middle and be wrapped around the outside several times. Use a thin gauge wire cable to help with this and the bead can still be small and allow you to feed the cable through several times. It may be worth trying to installing this close to the Zaon end of the power cable if it does not work elsewhere. Darryl |
On Mar 24, 10:30*am, Darryl Ramm wrote:
On Mar 24, 6:01*am, qflyer1 wrote: On Mar 24, 2:58*am, wrote: With my new Zaon MRX PCAS mounted on top of my glare shield, I've been I have the same problem. I also had the problem with the previous model. I did the ferrite bead and it didn't do the job. I finally sent it in and they replaced the power mosfet and that did the trick. I'm about to send this one in for a firmware upgrade and to deal with this issue. Hopefully the same way. Cheers, Tim 1FL experiencing some radio interference and linked this to the MRX: the radio gives white-noise static -- like the squelch is not properly adusted. When I turn the MRX off it goes away. I've heard putting a "ferrite core" around the MRX's (and the radio's?) power cord might help. *(Here's one:http://cgi.ebay.ca/Noise-Filter-Clip...QQitemZ3501565... On the previous model I did wrap several turns on the bead. Only sending it in fixed the problem. On this one, I'm not wasting my time. I'm awaiting my rma # as I write. Seems to me whatever power supply, or downstream component, design they used before is the same now. Tim ). Does anybody else have this problem? *Have you solved it in some way? Make sure you are installing a large enough ferrite bead (beads is slang, fat walled cylinders might be a better description) that allows the power cable to go through the middle and be wrapped around the outside several times. Use a thin gauge wire cable to help with this and the bead can still be small and allow you to feed the cable through several times. It may be worth trying to installing this close to the Zaon end of the power cable if it does not work elsewhere. Darryl |
Tim, that's very interesting. I have a friend who bought a MRX last
summer. While flying with him last fall I noticed that his MRX was misreading the altitude of the tow plane. He's planning on sending it in, but what with his problem and now yours I wonder if there was a QC problem at Zaon last year. Don't get me wrong, I love my unit and I know several that are performing exactly as they should - but they're all older units. -John On Mar 24, 8:01 am, qflyer1 wrote: I have the same problem. I also had the problem with the previous model. I did the ferrite bead and it didn't do the job. I finally sent it in and they replaced the power mosfet and that did the trick. I'm about to send this one in for a firmware upgrade and to deal with this issue. Hopefully the same way. |
On Mar 24, 12:57*pm, jcarlyle wrote:
Tim, that's very interesting. I have a friend who bought a MRX last summer. While flying with him last fall I noticed that his MRX was misreading the altitude of the tow plane. He's planning on sending it in, but what with his problem and now yours I wonder if there was a QC problem at Zaon last year. Don't get me wrong, I love my unit and I know several that are performing exactly as they should - but they're all older units. -John [snip] By how much? And just compared to the towplane? The altitude of the towplane sent to the Zaon is digital. So it is unlikely to "misread" it. It uses it's own internal altimeter to calculate the relative altitude. I would hope they agree to 100' or so. One issue is the Zaon pressure sensor is exposed to ambient cockpit pressure and not the static line pressure, so opening and closing vents/speeding up etc. might affect the relative altitude it displays. If the difference is more than a few hundred feet I'd next suspect the pressure sensor in the Zaon. It may be worthwhile before sending the Zaon back to compare what the Zaon says to another aircraft that has a transponder that shows the encoder's pressure altitude and play with opening and closing vents. Of course if it is just the tow plane then it's encoder may also be faulty, or maybe it really is an RF related problem that only happens when close to the other transponder (but unlikely). Darryl |
It was 300-400 feet off, sometimes above and sometimes below us - and
we were doing a normal tow, not boxing the wake. Vents were closed (it was 35 degrees F on the ground before takeoff). Hopefully he and I will be able to fly together within the next month. I've got a Becker ATC4401 that reports the encoded altitude, so we'll be able to compare that with his MRX in real time at different separation distances and heights. -John On Mar 24, 3:11 pm, Darryl Ramm wrote: By how much? And just compared to the towplane? The altitude of the towplane sent to the Zaon is digital. So it is unlikely to "misread" it. It uses it's own internal altimeter to calculate the relative altitude. I would hope they agree to 100' or so. One issue is the Zaon pressure sensor is exposed to ambient cockpit pressure and not the static line pressure, so opening and closing vents/speeding up etc. might affect the relative altitude it displays. If the difference is more than a few hundred feet I'd next suspect the pressure sensor in the Zaon. It may be worthwhile before sending the Zaon back to compare what the Zaon says to another aircraft that has a transponder that shows the encoder's pressure altitude and play with opening and closing vents. Of course if it is just the tow plane then it's encoder may also be faulty, or maybe it really is an RF related problem that only happens when close to the other transponder (but unlikely). Darryl |
jcarlyle wrote:
It was 300-400 feet off, sometimes above and sometimes below us - and we were doing a normal tow, not boxing the wake. Vents were closed (it was 35 degrees F on the ground before takeoff). Hopefully he and I will be able to fly together within the next month. I've got a Becker ATC4401 that reports the encoded altitude, so we'll be able to compare that with his MRX in real time at different separation distances and heights. Does his glider have a transponder in it? Do you know that the towplane encoder was working correctly? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Mar 24, 1:49*pm, jcarlyle wrote:
It was 300-400 feet off, sometimes above and sometimes below us - and we were doing a normal tow, not boxing the wake. Vents were closed (it was 35 degrees F on the ground before takeoff). Hopefully he and I will be able to fly together within the next month. I've got a Becker ATC4401 that reports the encoded altitude, so we'll be able to compare that with his MRX in real time at different separation distances and heights. The MRX internal baro altitude is both displayable and adjustable. It should not require any other equipment, except an accurate altimeter set to 29.92, to determine if the problem is the MRX baro sensor. Andy |
Flight computer - radio interference | cernauta | Soaring | 3 | August 1st 08 02:37 PM |
FM radio interference from planes | rb | Piloting | 34 | July 19th 06 05:53 PM |
GPS / radio interference | Cub Driver | Piloting | 2 | October 31st 04 10:57 PM |
radio / vario interference - HELP! | Chris Davison | Soaring | 13 | November 3rd 03 06:09 AM |
Radio Interference Information | Ross Richardson | Piloting | 0 | October 17th 03 02:06 PM |
