FS: Libelle 201b
Old March 24th 09, 01:00 PM posted to rec.aviation.soaring
Pete Smith[_3_]
Default FS: Libelle 201b
As far as I know the 201b designation involved several items: foam skins,
new tailplane, revised brakes, ballast bags as standard and increased Vne
and Mtow limits.
Anybody who is interested can see exactly when these changes occurred
because all the TNs are available on Hansjörg Streifeneder's site,
http://www.streifly.de/
Also, you mentioned it in passing but the 201b had dive brakes on
the top surface of the wing only.
That's correct. Lower surface brakes is the easiest way to tell a 201
from a 201b. Everything else apart from the tailplane change are internal
and I, for one, can't walk up to a lone Libelle and tell which tailplane
it has.
201 has a sharp radius to the leading edge tip (15mm radius?) the 201b
tailplane has a much larger radius (50mm?)
Old March 24th 09, 02:17 PM posted to rec.aviation.soaring
We have (6) privately owned Libelle's in our soaring club. There is a
huge difference between each horizontal stabilizer in sahpe and
thickness... They must have changed throughout the production series..
and Mtow limits.
it has.
Wanted Libelle 201b Canopy Fish Soaring 2 June 1st 06 07:10 PM
1-35 or 201B Waduino Soaring 11 April 2nd 06 07:32 PM
Libelle 201B Manual Joris Vanderputten Soaring 1 May 8th 05 12:49 PM
Libelle 201B in SoCal... Pat Russette Soaring 0 April 9th 05 05:42 AM
Dual Tires on Libelle 201b Ray Lovinggood Soaring 11 September 9th 04 04:34 PM
