The detection systems alone do not render stealth aircraft useless...
but link it to the German anti-stealth seeking missile and it is an effective counter. But who needs missiles? You dont even need exotic weapons like EM missiles,a multi static system designed to detect stealth platforms might be turned into a "kill" system instantly if you can keep frequencies and phases of several powerful emitters under control,a kind of poor mans HPM weapon. |
Yes, you are talking about a theoretical ADW "aerial denial weapon"
that would knock aircraft out of the sky without knocking out powered systems on the ground. Actually I was talking about something much different. Lets consider a multi static system using hundreds or thousands of commercial emitters and only a dozen or so powerful dedicated military emitters.If you can detect and track a stealth platform (or any platform) , these military emitters could be used as frequency and phase controlled combined devices to produce much higher levels of energy at the target area. Problem is phase locking but seemingly solved. Such a device will not be able to engage targets at exotic ranges,wont be able to recover GW or TW levels energy at target like EM Missilles and they are strictly line sight type devices, but they will severely degrade the any adversaries ability to attack. And most importantly they are very cheap in comparison to "real" HPM weapons. |
..after you increase their output by a few orders of magnitude.
Not going to happen. If you can keep the frequencies AND phases under control,then you have no problem. |
Flight test update - long | nauga | Home Built | 1 | June 5th 04 03:09 AM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
IFR Long X/C and the Specter of Expectations | David B. Cole | Instrument Flight Rules | 0 | February 24th 04 07:51 PM |
Israeli Stealth??? | Kenneth Williams | Military Aviation | 92 | October 22nd 03 04:28 PM |
Long Range Spitfires??? | ArtKramr | Military Aviation | 3 | September 9th 03 10:05 PM |
