On Mar 24, 2:01*pm, wrote:
On Mar 24, 2:02*am, Bob Hoover wrote: I'm leaning toward that myself. When the tubes came out of the acid, I rinsed them in clean tap water and then let them air-dry. I actually watched them rust in a period of 5 minutes. Harry Another thought - I've seen some EMT that has been painted/coated on the inside. The acid won't remove that. If that is the kind of EMT you are using for practice burn out the paint and then use a wire brush from the plumbing section to clean it out. ======================= Leon McAtee |
Question technique | Patrick R7 | Aviation Photos | 4 | September 30th 08 01:50 PM |
Interesting pattern technique | [email protected] | Soaring | 13 | July 19th 05 02:11 AM |
spinner trimming technique | Dick | Home Built | 0 | January 25th 05 11:57 PM |
instructor technique | Mike Stramba | Soaring | 8 | October 3rd 03 09:45 PM |
Flying Technique Question of the Day | Jim Vincent | Soaring | 24 | October 3rd 03 03:29 PM |
