Zaon MRX causing radio interference
Old March 25th 09, 02:43 AM posted to rec.aviation.soaring
Eric Greenwell
Default Zaon MRX causing radio interference
jcarlyle wrote:
On Mar 24, 6:06 pm, Darryl Ramm wrote:
On Mar 24, 3:33 pm, Eric Greenwell wrote:
jcarlyle wrote:
It was 300-400 feet off, sometimes above and sometimes below us - and
we were doing a normal tow, not boxing the wake. Vents were closed (it
was 35 degrees F on the ground before takeoff). Hopefully he and I
will be able to fly together within the next month. I've got a Becker
ATC4401 that reports the encoded altitude, so we'll be able to compare
that with his MRX in real time at different separation distances and
heights.
Does his glider have a transponder in it?
Do you know that the towplane encoder was working correctly?
Lets play 20 questions... :-)
Since the temperature was cold. Was this the first tow of the day? Any
chance the transponder had just been turned on within a few minutes
earlier and was still warming up?
Eric, the club G103 we were in does not have a transpondert. The
towplane encoder is working properly according to ATC.
OK, then the MRX should be using it's internal altimeter, as Darryl
thought. If the encoder altitude output is a just a little erratic,
you'd be able to notice while ATC might not. They would not be able to
tell the difference between an unsteady climb and a slightly erratic
encoder, I'm guessing.
Darryl, it wasn't the first tow of the day, so yes, the encoder was
warmed up. Let's ask the other 17 questions after I fly my transponder
equipped glider with him and his MRX in his non-transponder equipped
glider.
Or, you could fly with the MRX in your glider, which would make the MRX
use your encoder altitude instead of it's internal altimeter. That might
tell you if the problem is the internal altimeter.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Flight computer - radio interference cernauta Soaring 3 August 1st 08 02:37 PM
FM radio interference from planes rb Piloting 34 July 19th 06 05:53 PM
GPS / radio interference Cub Driver Piloting 2 October 31st 04 10:57 PM
radio / vario interference - HELP! Chris Davison Soaring 13 November 3rd 03 06:09 AM
Radio Interference Information Ross Richardson Piloting 0 October 17th 03 02:06 PM
