On Mar 25, 9:18*am, Gilbert Smith wrote:
Hello Rod, I use a home-spun device which clamps to the wingtip just outboard of the aileron. I have fitted two small wheels to this so that the wing can be moved into position while vertical. When rigging you then have to lift the tip with the device still fitted, go flat, and push it home. A fold-down prop then supports the tip while I engage the main and leading edge pins. It also has an extension of about a foot out from the trailing edge to help with the aft c of g at the tip. I rig and derig alone every day, and the device has been in use for 25 years. My attempt at a trolley and hydraulic jack was a failure because I lost the "feel" required to locate the spar pin. If you like I can email photos of both. Regards, "Gilbert" Rod Swallow wrote: Dear Gilbert I am a Grob 109b owner in Australia. Currently I am trying to assemble a trolley to make wing folding easier as I want to be able to rig it on my own. Do you have any suggestions? Thanking you Rod Swallow At 16:13 07 February 2009, Gilbert Smith wrote: In the UK we replace them on the G109B at 3000 hours irrespective, together with a few other mods which come up at that time. The new pins have a better taper, handy if you rig frequently as I do, and are replaceable without the major surgery reuired on the first occasion. - Colin. "Bob Jenneson" *wrote: Hi, * *I am seeking advise on the replacement of the wing pins fitted in the end of the spars on Grob 109 and 109B. This also applies to the Grob Twin Astir. A brief history. These pins are welded to a plate that is glassed into the wing spar end during manufacture. It was found out at a later time that some of these assemblies were prone to cracking around the welds and required replacement if found to be cracked. * * In Australia we are required to "ultrasonic " test these pins every 500 hours ( AD 370 ) If tested 'OK' we keep flying. We now have two aircraft that have 3000 hours each ( Life extension time ) and no cracks found. Do we need to change the pins? This is serious and expensive surgery and I am seeking advise as to how other countries have dealt with this problem. I understand that Australia in the only country that uses the ultrasonic test. Grob are happy to supply the new pin assemblies, but is it really necessary if the old ones have a 3000 hour safe history. Any help appreciated, Bob.- Hide quoted text - - Show quoted text - Dear Gilbert I would really appreciate the photos as it sounds like a much simpler system than the one I was considering. Thanking you Rod Swallow |
Grob 109 wing pins | BT | Soaring | 0 | February 7th 09 05:05 AM |
Grob wing retainer bearings | Tim | Soaring | 3 | September 3rd 06 02:55 PM |
ASW-15B spar pins | [email protected] | Soaring | 1 | May 9th 06 12:46 AM |
Hinge pins for Pegasus AD | tooromeo | Soaring | 0 | May 17th 05 02:56 PM |
taper pins | Ernest Christley | Home Built | 4 | September 12th 03 03:15 AM |
