#61
"This discussion always gets the "Safety Nazis" wringing their hands
and wailing every time. ( But never, ever, producing any hard data.) " Bill, for once, please, answer the simple question: What the initial tension, measured in G that you consider ideal on initial launch? Are you afraid to answer this question that I am now asking of you for the third time already? You can't complain about others not providing data (which is not true) if you refuse to even begin to do so yourself. So put up already. |
#62
Can I add that after a very sucessful 6 month trial with a loaned
secondhand Skylaunch winch, Lasham Gliding Society has ordered 2 new ones that will be arriving shortly. Lasham is the largest and probably most professional gliding club in the UK, so its Committee and Management would not have not have entered into this major financial investment lightly or without considering the alternatives. I am not a member of the Management or the Committee by the way. Can I further add that this winch will smoothly launch anything from lightweight little vintage single seaters up to big and heavy DG1000Ts, Duo Discus turbos, and ASH25 turbos. As John says below, the automatic gearbox changes up into top very early during the ground run and normally stays there for the rest of the launch. The gearchanges are imperceptable to the pilot and we have not found a problem with weak links breaking during the ground run, or at any other stage of the launch for that matter. Derek Copeland P.S. I still want to know how many winch launches Bill Daniels has actually taken? He demands exact data from others, but won't give out any himself! At 00:15 26 March 2009, John Galloway wrote: At 16:43 25 March 2009, bildan wrote: Everyone has experienced the imprecise surging when backing a car with an automatic transmission to align a tow ball with a trailer hitch. Imagine trying to control the acceleration a 1000 pound glider with a drive train intended for a 6000 pound road vehicle. Anyone who thinks any of this is not true, needs to produce some valid measurements to the contrary. I believe validated data. Bill, I have been involved in a lot of discussion a debate here in Scotland abut the merits or otherwise of Skylaunch winches and I have been launched by one and have launched about 8 gliders with one. As you well know because you have been told this on another forum the auto box is a complete non-issue. It changes into third during the ground run and stays in fixed ratio top gear throughout the launch - only exeptionally changing down under very heavy loading during the main part of the launch. The early upwards gear changes are undetectable to the glider pilot. I don't know what you consider to be validated data if not 40 odd winches over many years of use without problems with controllability related to the auto box. I can understand your wish to promote the merits of tension controlled winches but to do so by denigrating a clearly successful alternative design reveals more about your mindset than the winch in question. It is a shame that you have no practical experience of the Skylaunch which in our club trials worked equally successfully for K8s to Duo Disci I am pretty sure that the long term future of winching will rest with much more complex designs but there is none currently available that is proven by experience in terms of time of use and numbers built. The Hydrostart is certainly not yet convincing and is very expensive and, correct me if I am wrong, the US version is not launching yet. Considering the cost of winches, and the fact that once a club becomes winch orientated then proven reliabilty is critical, then I would reckon that it will be 5-10 years before it becomes wise to risk the purchase of what is now an experimental winch design. That is not to say that the the US tension controlled winch will not be successful from the start - just that it is better to let others act as the early adopters. John Galloway |
#63
To get the absolute maximum acceleration possible for a glider, just
divide a gliders flying weight into its specified weak link strength. (Tost weak links are now calibrated to +or- 5%) That value is always around 1.2G - if you don't believe it, read your manual. Hmmm... Must really go and check the manuals. Or my maths. IIRC mine (a newer AS model) says 750 or 800daN allowable, my flying weight is normally around 390kg. So that's close to 2g. We use 1000daN weak links for the ASK21 (empty 360kg according to AS homepage), so with two occupants around 540kg. That's also around 1.9g! Regards Marcel Dünner |
#64
I think you may be missing the point here.
The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). The acceleration on the ground should be safe. Too high and the inertia of the stick and the pilot's hand will cause backward movement, with self-evident results. Too slow and aileron authority is not achieved quickly enough to prevent wing drop and possible cartwheel! Typically aileron authority is present just below the stall speed so the acceleration should be sufficient to get to that speed before a wing can drop, say 2 seconds or so. Now do the math(s) for your glider. Typical stall speeds are below 35 kt (17 metres per second). This gives an acceleration of less than 1g which will comfortably be tolerated by any pilot. If continued the acceleration will have the glider fully flying and high enough to begin the rotation into full climb in another second or two. Broken weak links at the start of the ground run are generally due to a snatched All Out. The launch marshal must ensure that there is no slack in the cable before giving All Out by waiting for a genuine movement of the glider. The wing tip holder must move forward with the glider for as long as possible. The wing tip holder should abort the launch if he or she has to hold the wings level, they should do so naturally or the wing will drop on release. Best wishes JohnR-K |
#65
A few points to add to this.
1) The pilot should also be prepared to abandon the launch if a wing drops during the ground run. In the UK it is recommended that the pilot keeps his hand on the release knob during the ground run. 2) I always hold the stick in an appropriate setting for the glider type, generally always forward of centre, and then rest my arm or elbow against either my thigh or the side of the cockpit. That way I will not inadvertantly pull the stick back due to the effects of acceleration and inertia. 3) Always do your straps up as tightly as possible for a winch launch, and if the rudder pedals are easily adjustable, set them a bit closer than normal. If you need back cushions, make sure that they are made of a firm material. Several fatal winch launching accidents in the UK have been caused by pilots slipping back up the seat, or sinking back into soft foam cushions, again due to rapid acceleration and inertia. Possibly another good reason for limiting acceleration rates! Derek Copeland At 11:00 27 March 2009, John Roche-Kelly wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). The acceleration on the ground should be safe. Too high and the inertia of the stick and the pilot's hand will cause backward movement, with self-evident results. Too slow and aileron authority is not achieved quickly enough to prevent wing drop and possible cartwheel! Typically aileron authority is present just below the stall speed so the acceleration should be sufficient to get to that speed before a wing can drop, say 2 seconds or so. Now do the math(s) for your glider. Typical stall speeds are below 35 kt (17 metres per second). This gives an acceleration of less than 1g which will comfortably be tolerated by any pilot. If continued the acceleration will have the glider fully flying and high enough to begin the rotation into full climb in another second or two. Broken weak links at the start of the ground run are generally due to a snatched All Out. The launch marshal must ensure that there is no slack in the cable before giving All Out by waiting for a genuine movement of the glider. The wing tip holder must move forward with the glider for as long as possible. The wing tip holder should abort the launch if he or she has to hold the wings level, they should do so naturally or the wing will drop on release. Best wishes JohnR-K |
#66
On 27 Mrz., 12:00, John Roche-Kelly
wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). Yes, yes, of course. I didn't mean to give the impression I would like to be accelerated to the limits of the weak link - that would be quite frightful. But bildan was throwing wrong figures about and claiming (indirectly) the weak link limits the acceleration to safe levels. Marcel |
#67
Also the wing tip runner should hold the wing at the correct height, too
many hold a high wing too low and a low wing too high. At 11:00 27 March 2009, John Roche-Kelly wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). The acceleration on the ground should be safe. Too high and the inertia of the stick and the pilot's hand will cause backward movement, with self-evident results. Too slow and aileron authority is not achieved quickly enough to prevent wing drop and possible cartwheel! Typically aileron authority is present just below the stall speed so the acceleration should be sufficient to get to that speed before a wing can drop, say 2 seconds or so. Now do the math(s) for your glider. Typical stall speeds are below 35 kt (17 metres per second). This gives an acceleration of less than 1g which will comfortably be tolerated by any pilot. If continued the acceleration will have the glider fully flying and high enough to begin the rotation into full climb in another second or two. Broken weak links at the start of the ground run are generally due to a snatched All Out. The launch marshal must ensure that there is no slack in the cable before giving All Out by waiting for a genuine movement of the glider. The wing tip holder must move forward with the glider for as long as possible. The wing tip holder should abort the launch if he or she has to hold the wings level, they should do so naturally or the wing will drop on release. Best wishes JohnR-K |
#68
![]() "Alan Garside" wrote in message ... Also the wing tip runner should hold the wing at the correct height, too many hold a high wing too low and a low wing too high. At 11:00 27 March 2009, John Roche-Kelly wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). The acceleration on the ground should be safe. Too high and the inertia of the stick and the pilot's hand will cause backward movement, with self-evident results. Too slow and aileron authority is not achieved quickly enough to prevent wing drop and possible cartwheel! Typically aileron authority is present just below the stall speed so the acceleration should be sufficient to get to that speed before a wing can drop, say 2 seconds or so. Now do the math(s) for your glider. Typical stall speeds are below 35 kt (17 metres per second). This gives an acceleration of less than 1g which will comfortably be tolerated by any pilot. If continued the acceleration will have the glider fully flying and high enough to begin the rotation into full climb in another second or two. Broken weak links at the start of the ground run are generally due to a snatched All Out. The launch marshal must ensure that there is no slack in the cable before giving All Out by waiting for a genuine movement of the glider. The wing tip holder must move forward with the glider for as long as possible. The wing tip holder should abort the launch if he or she has to hold the wings level, they should do so naturally or the wing will drop on release. Best wishes JohnR-K To the tune of 'Donald whers yoo trooses' (Scottish folk song) "Let the wing go high let the wing go low"......you get the drift. JRS |
#69
Despite the alleged 'bildan tension spikes' from the automatic gearboxes
fittes to many current winches, in my experience weak link breaks during the ground run are extremely rare. If you do get a very overpowered launch, the weak link will normally break towards the end of the rotation or early in the full climb. The best video example I can find on youtube is: http://www.youtube.com/watch?v=jvK1ONl1CqE This launch was on a diesel powered winch (also favoured by bildan) where you typically get a rather slow initial ground run acceleration, followed by a sudden snatch into the air and often a considerable overspeed for lighter gliders. The video also shows what happens if you don't lower the nose quickly enough after a launch failure. The pilot allows the glider to stall, after which it never regains enough airspeed to round out. The glider (ASW15) suffered a collapsed undercarriage and other minor damage, and the pilot a bruised back. Fortunately nothing more serious, as it looks at one point as if the glider might spin. Otherwise weak links normally only break near the top of the launch, where they are doing their job in protecting the airframe. Derek Copeland At 16:07 27 March 2009, MaD wrote: On 27 Mrz., 12:00, John Roche-Kelly wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). Yes, yes, of course. I didn't mean to give the impression I would like to be accelerated to the limits of the weak link - that would be quite frightful. But bildan was throwing wrong figures about and claiming (indirectly) the weak link limits the acceleration to safe levels. Marcel |
#70
A Yahoo groups forum on Glider Winch engineering. Some posts review tension
control, ?? ....... http://dir.groups.yahoo.com/group/wi...eer/message/36 http://dir.groups.yahoo.com/group/wi...eer/message/38 and even one thinking about using battery power? http://dir.groups.yahoo.com/group/wi...eer/message/40 Did anyone get a electric battery launch before? David. At 08:30 28 March 2009, Derek Copeland wrote: Despite the alleged 'bildan tension spikes' from the automatic gearboxes fittes to many current winches, in my experience weak link breaks during the ground run are extremely rare. If you do get a very overpowered launch, the weak link will normally break towards the end of the rotation or early in the full climb. The best video example I can find on youtube is: http://www.youtube.com/watch?v=jvK1ONl1CqE This launch was on a diesel powered winch (also favoured by bildan) where you typically get a rather slow initial ground run acceleration, followed by a sudden snatch into the air and often a considerable overspeed for lighter gliders. The video also shows what happens if you don't lower the nose quickly enough after a launch failure. The pilot allows the glider to stall, after which it never regains enough airspeed to round out. The glider (ASW15) suffered a collapsed undercarriage and other minor damage, and the pilot a bruised back. Fortunately nothing more serious, as it looks at one point as if the glider might spin. Otherwise weak links normally only break near the top of the launch, where they are doing their job in protecting the airframe. Derek Copeland At 16:07 27 March 2009, MaD wrote: On 27 Mrz., 12:00, John Roche-Kelly wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). Yes, yes, of course. I didn't mean to give the impression I would like to be accelerated to the limits of the weak link - that would be quite frightful. But bildan was throwing wrong figures about and claiming (indirectly) the weak link limits the acceleration to safe levels. Marcel |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Safety of winch launch vrs. aero tow? | Gary Boggs | Soaring | 172 | November 13th 03 06:59 PM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
