Dan wrote:
cavelamb wrote: Dan wrote: cavelamb wrote: I remember Linda Rice's Lockheed had a really cool backlit panel overlay. The panel itself was heavy aluminum sheet, but then they added a plastic overlay that had an opaque cover. Legends and labeling was done by engraving the opaque layer. On the back side of the there were little cavities carved for grain of rice (well duh!) light bulbs. The effect was quite stunning. So does anybody know where to find this kind of plastic for the overlay? Thanks, Richard I use white plexiglass. Paint the face and edges black and have it engraved or engrave it then use a roller to paint the face and sides. Dan, U.S. Air Force, retired Ok, so other than good intentions and great karma, what kept the paint out of the lettering? If you paint it before engraving you won't have that problem. Using a roller to paint after you engrave means very little, if any paint gets into the lettering. I used a rubber roller like engravers use. I prefer the paint first method, but sometimes you need to repaint after adding engraving or damaged paint. I might mention painting the back of the plastic prevents light leaks. For the truly patient/crazy you can route grooves in the back for wiring. The number of lights required depends on the size of the panel and embedded wiring means you only have 2 wires hanging out the back. Military/commercial lighted panels have a little coaxial connector on the back that presses into a socket when you mount the panel. If you ever see one of this type of panel you'll notice a little plus sign on the front. The connector is directly behind it. Should lighting fail you can press there to see if the connection is bad. Older panels had light assemblies that screwed through the panel from the front. Dan, U.S. Air Force, retired Thanks, Dan. That's a possibility. |
| Thread Tools | |
| Display Modes | |
| 20B Panel | jcarlyle | Soaring | 21 | April 1st 09 11:57 PM |
| Panel Planner | [email protected] | Home Built | 6 | March 8th 06 12:48 AM |
| IFR PANEL | Flyhighdave | Home Built | 4 | January 18th 05 05:24 AM |
| IFR PANEL | Flyhighdave | Home Built | 4 | January 17th 05 08:15 PM |
| 182 panel | Jim | Owning | 2 | August 2nd 03 10:06 PM |
