Backlit panel
Old April 10th 09, 04:43 AM posted to rec.aviation.homebuilt
Dan[_12_]
Default Backlit panel
cavelamb wrote:
Dan wrote:
cavelamb wrote:
Dan wrote:
cavelamb wrote:
I remember Linda Rice's Lockheed had a really cool backlit panel
overlay.
The panel itself was heavy aluminum sheet, but then they added a
plastic
overlay that had an opaque cover. Legends and labeling was done by
engraving the opaque layer.
On the back side of the there were little cavities carved for grain
of rice (well duh!) light bulbs.
The effect was quite stunning.
So does anybody know where to find this kind of plastic for the
overlay?
Thanks,
Richard
I use white plexiglass. Paint the face and edges black and have
it engraved or engrave it then use a roller to paint the face and
sides.
Dan, U.S. Air Force, retired
Ok, so other than good intentions and great karma, what kept the paint
out of the lettering?
If you paint it before engraving you won't have that problem. Using
a roller to paint after you engrave means very little, if any paint
gets into the lettering. I used a rubber roller like engravers use. I
prefer the paint first method, but sometimes you need to repaint after
adding engraving or damaged paint.
I might mention painting the back of the plastic prevents light leaks.
For the truly patient/crazy you can route grooves in the back for
wiring. The number of lights required depends on the size of the panel
and embedded wiring means you only have 2 wires hanging out the back.
Military/commercial lighted panels have a little coaxial connector
on the back that presses into a socket when you mount the panel. If
you ever see one of this type of panel you'll notice a little plus
sign on the front. The connector is directly behind it. Should
lighting fail you can press there to see if the connection is bad.
Older panels had light assemblies that screwed through the panel from
the front.
Thanks, Dan.
That's a possibility.
The comm shops in USAF units was authorized an engraver for intercom
boxes face plates since the boxes had a bunch of pull-on volume controls
and had to be re-labeled for the specific location on the aircraft or
specific aircraft. Guess what? They just swapped out face plates when
replacing the boxes.
Another option you might try is the black on white plastic
trophy/engraving shops use for name plates. Granted it's thinner than
the plates we used which were 3/8" thick or so. I suppose an annunciator
light or illuminated tail number plate can be made if you make a bezel
to hold it with the lamps behind.
You might also consider LED instead of incandescent.
20B Panel jcarlyle Soaring 21 April 1st 09 11:57 PM
Panel Planner [email protected] Home Built 6 March 8th 06 12:48 AM
IFR PANEL Flyhighdave Home Built 4 January 18th 05 05:24 AM
IFR PANEL Flyhighdave Home Built 4 January 17th 05 08:15 PM
182 panel Jim Owning 2 August 2nd 03 10:06 PM
