Backlit panel
Old April 10th 09, 07:24 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Default Backlit panel
Dan wrote:
Orval Fairbairn wrote:
cavelamb wrote:
I remember Linda Rice's Lockheed had a really cool backlit panel
overlay.
The panel itself was heavy aluminum sheet, but then they added a plastic
overlay that had an opaque cover. Legends and labeling was done by
engraving the opaque layer.
On the back side of the there were little cavities carved for grain
of rice (well duh!) light bulbs.
The effect was quite stunning.
So does anybody know where to find this kind of plastic for the overlay?
Thanks,
Richard
If you wish to be more up-to-date, use red LEDs instead of the
grain-of-wheat bulbs. You CAN use clear plexiglass, with an inverted
bevel at the instrument holes. I would suggest painting both sides of
the plexiglass white, to contain the light, before the
cutting/engraving operations. The front face can be left whit or
painted in your desired color.
White plexiglass diffuses and spreads the light more evenly than
clear. One nice thing about LED illumination is you can install both
red and white LED so you can either make illumination switchable or you
can change you mind later with minimum wiring problems.
For the truly creative use blue-green LED so you can play special ops
with NVG.
Dan, U.S. Air Force, retired
Kool! LOL.
But the red/white back-light idea already crossed my mind.
I hadn't thought of the special ops angle tho.
I like the bevels suggestion too.
There are a couple of places that that might work real well.
This is actually the electrical control panel on my sailboat,
so weight is not quite as critical.
But being able to read it at night IS.
Richard
20B Panel jcarlyle Soaring 21 April 1st 09 11:57 PM
Panel Planner [email protected] Home Built 6 March 8th 06 12:48 AM
IFR PANEL Flyhighdave Home Built 4 January 18th 05 05:24 AM
IFR PANEL Flyhighdave Home Built 4 January 17th 05 08:15 PM
182 panel Jim Owning 2 August 2nd 03 10:06 PM
