Stiff rudder
Old April 14th 09, 11:08 PM posted to rec.aviation.soaring
Uncle Fuzzy
Default Stiff rudder
On Apr 14, 11:03*am, Steve Freeman wrote:
On Apr 14, 11:17*am, Mike the Strike wrote:
On Apr 14, 7:29*am, wrote:
On Apr 14, 9:06*am, Mike the Strike wrote:
On Apr 14, 6:49*am, Steve Freeman wrote:
My SZD 55 has a very stiff rudder. When the cables are disconnected it
moves easily. One suggestion has been that maybe the tubes the cables
ride in are full of dirt and contaminants and that cleaning them will
solve the problem. I remembered reading about someone replacing their
cables with a smaller diameter cable but could not find anything in
the archives. Anyone have any experience with this type of problem?
Years ago, when I had a Jantar 1, I accidentally drove a screw through
the rudder cable tube in the cockpit when installing a microphone. *We
removed the rudder cables to check for damage and found I had severed
several strands. *More interesting, we also found that the factory had
done the same thing *and I'd been flying with several strands missing.
I suggest that you remove the cables and check for damage. *If the
tube isn't damaged, it might be pinched. *I believe mine is not the
only report of this problem.
Mike
You should be able to determine if it's only one side that's tight.
Disconnect the cables from the rudder and get a helper to slide the
cables one at a time forward and aft.
In my case, the bad factory cable was the one I didn't damage. Given
the chance for factory-installed problems, *I suggest that you look at
both even if they move freely.
Mike
Short of going back to the factory, what do you suggest for a
replacement cable?- Hide quoted text -
- Show quoted text -
http://www.aircraftspruce.com/catalo...ntrolcable.php
1-34 Rudder Discus 44 Soaring 0 August 17th 08 05:10 AM
Right Rudder Ol Shy & Bashful Piloting 19 August 16th 08 05:38 AM
WTD. SGS 2-33 Rudder [email protected] Soaring 0 December 20th 06 05:31 AM
c-152 rudder??? houstondan Owning 39 December 21st 04 10:21 PM
c-152 rudder??? houstondan Owning 28 December 15th 04 10:55 PM
