NIMH batteries - slightly OT
Old April 15th 09, 03:17 AM posted to rec.aviation.soaring
Adam
Default NIMH batteries - slightly OT
On Apr 13, 11:46*am, Martin Gregorie
On Mon, 13 Apr 2009 07:50:26 -0700, jbourlandmd wrote:
Mr. Moore did not mention any specifics on how he detects peak.
I am using a very basic one stage peak charger similar to your Prodigy
II. *I charge my Eneloops at 2A. *Peak is not adjustable.
Looks like I just wasted my money on the Ansmann batteries, then, and
need to get a set of eneloops.
On last overnight discharge on the UBA III+ the Ansmanns managed 500 mAh,
but today (2.5 amp charge, 0.5A discharge on the Prodigy II) they would
only show a bit under 400 mAh capacity. Junk. NOT recommended. Avoid them..
Thanks for your data and advice.
martin@ * | Martin Gregorie
gregorie. | Essex, UK
org * * * |
AFAIK, Enelopes only real advantage is that they have a longer shelf
life due to new separator technology. But for that reason alone they
are good for cameras.
In my RC addiction, I often use what many of my fellow modelers would
call "garbage" $1 per nimh batteries made in China from Ebay. I
regularly see 1800-1900 mah from a 2000 mah rated pack charged on a
Triton. Not bad. I use the same batteries in a 10 cell (12 volt)
portable sailplane VHF radio with great results (12+ hours rx time). I
fly them in very expensive carbon fiber full house models using six
digital servos in DS applications down to 15F with no problems. So far
I have used 24 of these cells and have not had one dead cell or
problem in two years use. I cannot say the same for name brand cells.
YMMV.
I typically charge at 0.5 to 1C for small AA and AAA batteries like
these. Zapped sub-C traction batteries were charged at 2C plus.
I wonder about your chargers. The standard Triton 2 is a super charger
for the money and pretty much standard equipment over here. If you do
go that route, avoid the "jr" version as it has some limitations on
amperage (5A) and lipo cell count (4S).
/Adam
NIMH Batteries K M Soaring 23 December 9th 08 09:27 PM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
C & D NiMH Best Deal Larry Home Built 6 October 1st 04 01:41 PM
AA NiMH Best Deal Jim Weir Home Built 27 September 29th 04 08:39 PM
AA NiMH Best Deal Jim Weir Piloting 26 September 29th 04 07:51 PM
