NTSB urges grounding of all Zodiac CH-601XL's
Old April 15th 09, 07:17 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Default NTSB urges grounding of all Zodiac CH-601XL's
Brian Whatcott wrote:
150flivver wrote:
On Apr 14, 8:36 pm, Brian Whatcott wrote:
http://www.cnn.com/2009/US/04/14/nts...ane/index.html
Designed by Zenair.
Just saw it on CNN.
Karl
Ouch! Control flutter and reduced sick force per G at high g
Well, this is homebuilders heaven - so I suppose we could use a
reminder that balancing control surfaces, specially tail feathers,
can help stop the onset of flutter, that loose control wires
and rods can encourage.....
Brian W
How do you balance ailerons that aren't hinged?
You've got me: how DO the ailerons work on a CH-601XL?
Brian W
Go here and scroll about half way done the page.
But as I mentioned most if not all the accident aircraft had regular
hinges.
Old April 16th 09, 01:26 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Brian W
hinges.
I've flown a 701 with the hingless hinges.
The ailerons felt very stiff in flight.
I can well believe that set-up would prevent flutter -
or at least move the resonant response way up there.
Old April 16th 09, 03:41 PM posted to rec.aviation.homebuilt
Frank Stutzman[_3_]
A 701?
Hingless hinges can be done on the 6xx series planes, but the 701
(according to the plans) uses hinges. Not to say that someone couldn't
do it on a 701, but it would seem to be a diversion from the standard
designe that would be of dubious value.
Frank Stutzman
Bonanza N494B "Hula Girl"
Boise, ID
Old April 16th 09, 06:09 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
A 701?
Sorry, bad typo Frank, it was a LOW wing 601HD.
Panel urges Navy move some jet training -- perhaps to Kingsville Otis Willie Naval Aviation 1 September 10th 05 03:53 AM
AOPA urges allowing cell phone use in general aviation Eric Greenwell Soaring 7 March 30th 05 08:44 PM
Grounding of K-7 and K-10s in the UK. Robertmudd1u Soaring 1 May 28th 04 02:53 AM
Rabbi Urges Pig Fat on Buses to Stop Bombers Mike Marron Military Aviation 11 February 20th 04 11:37 PM
